Old 10-04-2015, 11:33 PM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by tlundell View Post
What would be the power connection for these fans?
I use 92mm fans that have a stated draw of 0.2 amps @12V DC each. Attach them so that they are pulling the air, rather than pushing it as this is more efficient and allows you to position them directly at a vent outlet, again for better efficiency.
Old 10-05-2015, 05:42 AM   #16
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
[QUOTE=lewster;1692970]As the saying goes........'you can put lipstick non a pig.......'
Sorry, but no matter what Dometic, Norcold or Atwood do to a gas/absorption fridge, it's still ancient technology!!!!
/QUOTE]
Not to be too much a wiseacre, but mechanically compressed refrigerant systems ain't exactly a new idea, either.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-05-2015, 06:42 AM   #17
I'm replacing an ever increasing number of gas/absorption units with marine fridges using 12VDC powered Danfoss compressors.
Work 30 deg. off level and don't really care about the ambient temps. Get cold in a hour and STAY THAT WAY!!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Any particular brands that you recommend in the 4 cu ft range? West Marine carries Isotherm but it essentially has no freezer. Which means I'd still be carrying ice packs even if the fridge worked, because I need at least the size of freezer of the old Dometic gas fridges, if not larger.
Old 10-05-2015, 07:52 AM   #18
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Nova Kool makes a 3.0cf unit that is used in the Airstream Interstates, a 3.5cf unit, and a 4.3cf unit.
Nova Kool, refrigerators, freezers, Marine, RV, Truck
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-05-2015, 09:05 AM   #19
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Lew Farber
541-490-6357
Have you ever installed one of these larger versions in an Airstream trailer?
Cruise 195 : Isotherm Parts, Marine Refrigeration Parts
Kelvin
Old 10-05-2015, 09:50 AM   #20
lewster's Avatar
Kelvin
Several times. Also look at VitriFrigo. Both are made in Italy, and I use them interchangeably.....which ever one fits best for the application.
'Not to be too much a wiseacre, but mechanically compressed refrigerant systems ain't exactly a new idea, either.'
Not necessarily cutting edge technology, but one that works consistently well!!
No, but you don't hear many folks complaining about marine grade compressor fridges not holding temperatures when it's very hot out.
Old 10-05-2015, 09:54 AM   #21
Lewster specifically referenced 12VDC powered Danfoss compressors which is why I thought he might have make/model at his fingertips. When I go into those parts lists and spec sheets for Nova Kool, they don't state who makes their compressors. Unless it is buried in a place I haven't yet found. West Marine does cite Danfoss explicitly.
Old 10-05-2015, 11:18 AM   #22
lewster's Avatar
I'm pretty certain that Nova Cool units, like Tundra and other makers of marine units use Danfoss compressors, but since I don't install them, I have no practical knowledge of their components.
Lew Farber
541-490-6357
Old 10-05-2015, 01:53 PM   #23
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
What does "marine grade" mean, other than an opportunity to charge a lot more?
Old 10-05-2015, 02:28 PM   #24
lewster's Avatar
Specifically made for use in a marine environment. This generally implies heavier quality components, extensive use of non-corrosive materials like stainless steel and modern polymers and the specific ability to work for extended periods in the salt and moisture atmospheres found at sea........ also having electrical systems built to the ABYC E-11 marine standards for durability and corrosion resistance.
Lew Farber
541-490-6357
Old 10-05-2015, 06:52 PM   #25
iaqstuff's Avatar
2013 Interstate Coach
Yarnell , Arizona
In and Out
Ventilation is an exchange of air - what comes in goes out and what goes out comes in. The dealer who attempts ventilation by installing aux fans pulling/pushing air one direction doesn't understand ventilation.
iaqstuff is offline   Reply With Quote
Refer not maintaining temp. Dbones Sprinter and B-van Forum 42 07-26-2016 08:47 PM
Furnace Maintaining Temperature Erratically 10Smiles Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-07-2012 07:43 AM
Maintaining cooling system RetiredGuy Tow Vehicles 5 08-26-2009 06:00 AM
Maintaining your Batteries joshua32064 Batteries, Univolts, Converters & Inverters 17 04-29-2008 10:03 PM
General dometic refer temp regulation question wacnstac Refrigerators 12 04-12-2006 08:37 AM
