Old 04-20-2015, 10:14 AM   #1
2015 Interstate Ext. Coach
Boise , Idaho
Refer not maintaining temp.
We are on our initial trip with a 2015 Interstate. The refrigerator will not maintain temperature but the freezer works well any trouble shooting suggestions?
Dbones is offline   Reply With Quote
Old 04-20-2015, 10:41 AM   #2
Tuco's Avatar
1988 32' Excella
Ojai , California
Make sure and level the rig to the refrigerator. If ours isn't within half a bubble of level it will not cool properly.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 04-20-2015, 10:59 AM   #3
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
The fridge in an Interstate is electric only (compressor type) and doesn't need to be level.
Is this a Grand Tour with separate fridge and freezer?
Take a look at this recent thread for ideas:
http://www.airforums.com/forums/f240...on-132410.html
Old 04-20-2015, 06:06 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Is it a Grand Tour model that has separate refrigerator and freezer units? Or a regular Interstate that has one Nova Kool fridge with a tiny freezer tray on top?
I ask because on another thread, someone with a Grand Tour had the same problem. Come to find out that someone at Jackson Center had failed to hook up the 12vDC circuit for the fridge, so it would only work on 120vAC, but for the freezer, both 120vAC and 12vDC circuits were hooked up.
So, troubleshooting tipÖ check the fridge in both 12vDC and 120vAC modes, and see if it's a problem with both power sources, or just one. To check in 12vDC mode, shut off the 120vAC circuit breakers; that forces the fridge into 12vDC mode by default.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-20-2015, 06:49 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I highly suspect that it's a double unit (Grand Tour) since in the single unit, the freezer is what cools the entire unit. So if the OP's freezer is working and the frig isn't, they must be separate.
Old 04-21-2015, 04:28 AM   #6
Not necessarily. I've had it happen in my single unit. Once. The culprit there was the fridge was loaded to the gills, packed tight without enough space left for proper air circulation. That was back before I had my toad, and I was trying to pack enough food for a nine-day trip to avoid having to break camp for a grocery run. That plan kind of backfired.
WBCCI #1105
TAC LA-4
Old 04-30-2015, 08:29 AM   #7
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I installed a wireless temperature prob to monitor constant the fridge. It works well but I can see a difference between 12v and 120v so I just run it on 12v all the time.
PSchw is offline   Reply With Quote
Old 04-30-2015, 08:35 AM   #8
tlundell's Avatar
Los Gatos , California
Is there a way to make the switch from 120v to 12v (other than by disconnecting shore power)? I haven't compared the temp performance between the two, but would obviously like to select the mode which maintains temp the best. Thanks.
Tim
2015 Interstate Grand Tour
WBCCI Member #5506
tlundell is offline   Reply With Quote
Old 04-30-2015, 05:39 PM   #9
73shark's Avatar
Some folks on this forum have simply unplugged the 120 volt line on the reefer. also it will run on 12 volts DC if the inverter is not on and you're not connected to shore power and the generator is not running.
It's also more energy efficient to run it on 12 volts DC as the 120 volt line is inverted in the refrigerator to 12 volts DC.
Old 05-02-2015, 08:12 PM   #10
PSchw's Avatar
Livingston , Texas
I installed on if the outlet switches. If the light on the switch is on I am running 120v if it on so when I boondock I make sure it is off and run the inverter keeps the batteries above 50% next morning.
Old 05-02-2015, 09:15 PM   #11
73shark's Avatar
Since the inverter runs off of the batteries, how does running the inverter keep the batteries above 50%? Or did I misinterpret what you wrote?
Old 05-04-2015, 10:51 AM   #12
PSchw's Avatar
Livingston , Texas
If I boondock leave the fridge on 120v running the inverter will leave me in the morning with some tv usage under 50%. So turning the 120v off will leave me above 50%.
Old 06-12-2015, 05:04 PM   #13
Tega Cay , South Carolina
We are on a trip and are in Texas . 90 plus degrees weather and my refrigerator cools to 47 at night plugged into the campground and 53 during the day plugged into my daughters house. The freezer is working perfectly. Do I have a problem that needs to be addressed or is this normal with the heat.
Gloria
gghayes is offline   Reply With Quote
Old 06-12-2015, 05:28 PM   #14
UKDUDE's Avatar
Sedona , Arizona
Gloria
I would say it's a problem. Recommended temperature for a refrigerator is 37F wherever you are. The food will be rendered unsafe to eat at a much higher temperature.
Is this a Grand Tour? It seems a few are complaining of issues with the refrigerator.
The air inside needs to circulate, so if it's overloaded with food, that could also affect it.
Have you noticed whether it seems to operate better when you're not plugged in? Wondering whether running on 12V makes any difference.
Maintaining Exterior Finish BigGrey Airstream Lifestyle 5 05-07-2012 09:22 AM
Furnace Maintaining Temperature Erratically 10Smiles Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-07-2012 07:43 AM
Maintaining cooling system RetiredGuy Tow Vehicles 5 08-26-2009 06:00 AM
Maintaining your Batteries joshua32064 Batteries, Univolts, Converters & Inverters 17 04-29-2008 10:03 PM
General dometic refer temp regulation question wacnstac Refrigerators 12 04-12-2006 08:37 AM
