Old 07-26-2016, 08:47 PM   #43
lewster's Avatar
Naples, FL , Hood River, OR
Refer not maintaining temp.
Originally Posted by 73shark View Post
Obviously something needs to be done to remove more heat from the condenser. If the air flow is not somehow vented to the outside, I think it's a lost cause. Bottom line is in order to remove heat from the frig/freezer, that heat has to be moved somewhere, preferably outside. Otherwise you are just moving the heat from the frig and putting it in the cabinetry. Bigger fans won't help if they can't exhaust the heat from the condenser outside.
Sounds like a side wall or roof vent is in order with fans located on the vent to suck out the hot air.
Maintaining Exterior Finish BigGrey Airstream Lifestyle 5 05-07-2012 09:22 AM
Furnace Maintaining Temperature Erratically 10Smiles Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-07-2012 07:43 AM
Maintaining cooling system RetiredGuy Tow Vehicles 5 08-26-2009 06:00 AM
Maintaining your Batteries joshua32064 Batteries, Univolts, Converters & Inverters 17 04-29-2008 10:03 PM
General dometic refer temp regulation question wacnstac Refrigerators 12 04-12-2006 08:37 AM
