Old 03-12-2014, 01:44 PM   #1
JRC
2013 Interstate Coach
Pinconning , Michigan
Recall question
First thanks to you all for sharing your knowledge on the forum. We purchased a new Interstate last November and have learned much from all of you since then. With luck in a few years, I'll have accumulated a little knowledge and be able to share it the new members.
We recieved the recall notice along with most new owners a few months ago. It instructed us to call our dealer and schedule an appointment. The repair was to take about an hour. When we called the dealer, he said we can't take you for at least four weeks, I'll call you back. He never called after four weeks so we called him back today. Now he says we have to bring the Interstate in for an inspection, after which he will order the parts. Then we can come back in a couple of weeks and he will install the part. We live three hours away with no closer dealer. This would mean 12 hours of driving and at least two days away from work. Is this reasonable for a new vehicle?
Thanks for your thoughts.
Randy
JRC is offline   Reply With Quote
Old 03-12-2014, 01:57 PM   #2
weirdstuff's Avatar
2018 23' International
San Diego , California
The dealer should be able to look up your VIN number, and see that you're unit is indeed one that was recalled. And then, they should be able to order the parts for you. And when the parts come in, you go in and have the work done.
Seems simple, given that it is a recall, and they know what they need to replace.
I've had some similar hassles with getting work done on mine too.
weirdstuff is offline   Reply With Quote
Old 03-12-2014, 02:11 PM   #3
Newbie
joemikeb's Avatar
Fort Worth , Texas
That is pretty much what I have encountered with my dealer on warranty work. Airstream will not authorize the repair or ship the parts until the work has been inspected by the dealer to verify it can be done under warranty. The only difference is I have had to wait six to eight weeks for the initial appointment and in one case the part took four weeks, but it came from Fiamma not Airstream.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 03-12-2014, 03:11 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
My experience has been completely different, thankfully. When my 2012 was recalled, the dealer called me (not vice versa) to set up an appointment. They already had the parts in hand when I arrived, and the warranty work was done inside of 15 minutes.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-14-2014, 07:31 AM   #5
JRC
Thanks guys.
Dealer claims Airstream requires an inspection before they can order parts. I think I'm going to give Airstream a call. Anyone know who to contact there?
Randy
Old 03-14-2014, 07:50 AM   #6
2008 25' Classic
Sometimes it's Heaven , USA
Yep -- Call Jim Parrot -- He is the head of customer service for interstates ---937-596-6111 -- Ext 7409 --- He is very good at handeling these things ---
COUNTRYSONG is offline   Reply With Quote
Old 03-14-2014, 07:56 AM   #7
That's Parrett, I think.
WBCCI #1105
TAC LA-4
Old 03-14-2014, 10:50 AM   #8
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Yep.
Old 03-14-2014, 10:58 AM   #9
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
My dealer told me they need to take a look at the gas regulator, make a note of its serial number, and then contact Airstream. Presumably Airstream cannot correlate a specific regulator to a VIN number.
Old 03-14-2014, 11:06 AM   #10
73shark's Avatar
Won't they let you read the number and give it to them?
Old 03-14-2014, 12:32 PM   #11
UKDUDE's Avatar
Sedona , Arizona
They may - if I knew what to look for…..
I crawled under the Interstate on the driver's side - since that is where the lpg tank is located. And I didn't see anything that resembled any gas regulator I have at home (the house or the grill). I suspect it may be located in a very inaccessible place such as between the tank and the floor.
Old 03-14-2014, 08:55 PM   #12
Trying to Retire
MILATV's Avatar
Decatur , Illinois
I am 3 hrs from dealer also. Airstream is sending me the part and I am having a local RV shop install it.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 03-15-2014, 08:50 PM   #13
toskeysam's Avatar
Townsend , Tennessee
While in the shop for a new temp probe for my battery bank, the manager told me they had a new regulator for me. He also said that by the time they got in position to check the regulator, they might as well replace it....the added effort was minimal in comparison to the total effort. Soooooo, I have a new regulator....and battery temperature probe.
toskeysam is offline   Reply With Quote
Old 03-17-2014, 11:04 AM   #14
AI owner since June 2013
Lake Mary , Florida
Angry Propane Safety Recall
I have had a similar run around issue with RV One - the company that bought Bates in Tampa. They told me they have to inspect my rig first before they will know if I need parts replaced, and by the way - they can't get me in for at least two months! Seems outrageous for a propane related safety recall. I am going to call Jim Parrett to see what can be done - will update post as I go.
FlaBucki is offline   Reply With Quote
Thanks to the forum for Dometic recall info Kosm1o Refrigerators 1 06-17-2011 05:41 AM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
A question on selling awnings Airy Awnings 21 04-24-2011 10:37 AM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
