Old 05-28-2015, 10:22 AM   #29
2013 Interstate Coach
Flemington , New Jersey
Originally Posted by scarletbison View Post
Mario,
Are you leaving the trim and shades off of the rear doors (AI really closes off the rear windows)? It seems that would be a better solution for driving and then putting reflectix in at night when you're camped. BTW did you get the reflectix locally?
Hi Grant,
No. I re-installed the rear panels.
The reflectex is a semi-permanent installation. Not only is it secured by the tension of the Airstream back window panels, but also with some heavy duty outdoor type velcro strips located on the metal window frame.
Last year I tried some cheesy camping world relfecetex squares stuck to the rear windows with some low grade velcro squares. They lasted a day. A days worth of sun exposure melted the velcro adhesive and let the sqaures slide down the window. Messy and sticky. Found that with this new installation, with the rear facing the sun (as it does in my driveway), it blocks a substantial amount of heat.
Bought the relfectex in a Home Depot near Shoreline, Washington. Then brought the whole damn roll with me in the teardrop trailer While I was out there I did manage to cut some side window panels, of which one is also semi-permannetly installed in the window behind the galley.
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Winterizing: using a blowout plug TitusLivy Winterizing, Storage, Carports & Covers 30 01-16-2011 10:53 AM
tire blowout blew hole in wheel well munimula Roof 16 06-03-2006 10:05 AM
2001 Bambi tire blowout rcaldwel Tires 21 03-22-2006 04:19 PM
Tire blowout damage Les Staley Tires 6 05-06-2005 11:29 PM
Blowout John Brimer Airstream Motorhome Forums 3 08-27-2002 05:15 PM
