Old 05-23-2015, 08:30 PM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by unifreck View Post
I love the German engineering, takes me back to the AIR TIGHT VW that I had to crack a window to shut the door without slamming the door several times. Mercedes needs to have a one-way pressure valve for the Sprinter. (Protagonist, please tell me the proper name for that valve---I really appreciate your knowledge.)
Originally Posted by 73shark View Post
Check Valve maybe?
Pressure relief valve. Check valves block reverse flow; they don't necessarily relieve pressure.
Airstream Interstates already have one, though. Watch the small openable window on the sliding side door when you close it with the roof vents and all windows closed. The side window "burps" slightly as the excess pressure escapes. On my van, the only times I ever completely close my MaxxFan vent are in the winter when heat from my furnace would escape out the vent, and when I'm expecting a howling thunderstorm or mild hurricane while the van is parked at home. The rest of the time I leave it at least partially open because it's very rain-resistant unless it's raining sideways, and it helps the van from overheating— and provides pressure relief.
I don't think that's the cause. Tempered glass has a unique property; it doesn't crack, it only shatters. But there can also be a delayed reaction. An impact that would normally crack non-tempered glass causes stress to build up in the tempered glass but doesn't break it. That stress can continue to build over time until the glass finally shatters, possibly long after the impact that started the process. In this case, it wasn't necessarily slamming the door that broke the glass, it might have been some other impact beforehand that started it, and the door closing only finished the job. The original cause could have been a small rock thrown up by a lawn mower, a hailstone, or some other impact that you didn't even notice at the time.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-24-2015, 12:46 PM   #16
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
How does a pressure relief valve work?
73shark is online now   Reply With Quote
Old 05-24-2015, 12:57 PM   #17
The simplest form is a valve held closed by spring pressure; a calibrated spring that requires a known amount of force to compress. When pressure against the valve exceeds the pressure of the spring, the valve opens, and when the pressure drops, the spring forces the valve closed again.
WBCCI #1105
TAC LA-4
Old 05-24-2015, 01:00 PM   #18
73shark's Avatar
So basically a spring-loaded check valve then?
Old 05-24-2015, 04:48 PM   #19
Exactamundo.
WBCCI #1105
TAC LA-4
Old 05-25-2015, 08:24 AM   #20
2013 Interstate Coach
Flemington , New Jersey
Whoa! What a way to start the summer. Sorry sorry to hear about your issue. Please let us know of the outcome.
Recently insulated the space between the glass and the airstream panel with reflectex. Here are some close up pix. Looks like the window may be Mercedes. The edge is finished and looks to be factory painted.
Name:	ImageUploadedByAirstream Forums1432563816.830096.jpg
Name:	ImageUploadedByAirstream Forums1432563849.288312.jpg
Name:	ImageUploadedByAirstream Forums1432563873.285852.jpg
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 05-25-2015, 09:26 AM   #21
Boxster1971's Avatar
Fulton , Maryland
Yes they are factory installed. Another hint is that they are heated as controlled by switch on the dash.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 05-27-2015, 12:52 PM   #22
2014 Interstate Ext. Coach
Bound Brook , New Jersey
Attachment 239184
Attachment 239185
Attachment 239186
Mario,
Are you leaving the trim and shades off of the rear doors (AI really closes off the rear windows)? It seems that would be a better solution for driving and then putting reflectix in at night when you're camped. BTW did you get the reflectix locally?
SCARLET BISON
Silver 2014.5 Interstate EXT
scarletbison is offline   Reply With Quote
Old 05-27-2015, 01:18 PM   #23
bwpaint's Avatar
2015 25' FB International
my , house
Different situation but similar. Closed driver door on my brand new PU last year. Windshield cracked all the way across. Dealer said no warranty on glass, but we'll photo and send in claim request to see what GM says. GM had me file on my insurance and they (GM) paid my deductible. Worth a shot. Good luck, and sorry about your trouble.
bwpaint is offline   Reply With Quote
Old 05-27-2015, 02:04 PM   #24
2015 Interstate Ext. Coach
Waukesha , Wisconsin
New window installed today.
Airstream dealer was useless. Never asked how, or where or when. Just went right to, "Glass isn't covered, you should file with your insurance."
Not really what you want to hear 15 days after dropping 130K. Or a very prudent practice when the glass is only $300 installed.
Mercedes was helpful in getting it setup with OEM glass, and getting it done in a timely fashion.
Mordux is offline   Reply With Quote
Old 05-27-2015, 02:24 PM   #25
73shark's Avatar
Did MB cover it then?
Old 05-27-2015, 02:31 PM   #26
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
If the RV dealer you bought it from has a matching unit in stock have them just switch out the complete
door with the other unit.
1 Hour job
Old 05-27-2015, 02:32 PM   #27
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
so who might this fine Airstream dealer be, laddy.. local or not?
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 05-27-2015, 02:53 PM   #28
Local, the only dealer in the fine state of Wisconsin.
Winterizing: using a blowout plug TitusLivy Winterizing, Storage, Carports & Covers 30 01-16-2011 10:53 AM
tire blowout blew hole in wheel well munimula Roof 16 06-03-2006 10:05 AM
2001 Bambi tire blowout rcaldwel Tires 21 03-22-2006 04:19 PM
Tire blowout damage Les Staley Tires 6 05-06-2005 11:29 PM
Blowout John Brimer Airstream Motorhome Forums 3 08-27-2002 05:15 PM
