Old 03-15-2016, 07:12 PM   #1
Teamaron's Avatar
2014 Interstate Ext. Coach
Boca Raton , Florida
Rear view mirror and camera
What I'd like to do is move rear view camera screen off rear view mirror to able to to view rear of coach.
Anyone done this or have ideas to a suction cup or bracket to remove screen from rearview mirror???
Teamaron is offline   Reply With Quote
Old 03-15-2016, 07:26 PM   #2
Teamaron's Avatar
Name:	ImageUploadedByAirstream Forums1458091605.126905.jpg
Old 03-15-2016, 07:27 PM   #3
Airstream Obsessed
AVDESIGN's Avatar
2006 30' Classic
1989 29' Excella
Sandy , Utah
I plan on doing the same thing on my Ford F150. When I do it I'll let you know how it goes.
AVDESIGN is offline   Reply With Quote
Old 03-15-2016, 07:32 PM   #4
2011 Interstate Coach
Muskogee , Oklahoma
If it's the Pyle unit, it just has spring loaded clamps. You just push them apart and it comes off. But you will have to unhook the cable by removing the overhead compartment and finding where it connects to the camera. It is removed by gently pulling down on the curbside side (the overhead compartment is held in with spring loaded clamps on that side, and with flat legs on the other. Pull it down, and then to the curbside (right as you face it) and it will fall away. Then follow the wire from the monitor and unplug it.
It's easy to do. You can, if you want, re-route the cable and display the rear view camera image in the Kenwood deck.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 03-15-2016, 07:55 PM   #5
Teamaron's Avatar
Not looking to remove it
Just install next to rearview mirror
Old 03-15-2016, 07:56 PM   #6
Teamaron's Avatar
Originally Posted by Teamaron View Post
Attachment 258822
That's not my mirror
Just an example
Old 03-15-2016, 10:39 PM   #7
Muskogee , Oklahoma
It is held on to the mirror with two spring loaded clamps. You can pull it off and put it anywhere you were wish, but you will have to figure out some way to mount it.
Old 03-15-2016, 11:44 PM   #8
2015 Interstate Ext. Coach
Lake Mary , Florida
Yes, there is the original Sprinter mirror underneath, and aftermarket one simply hangs on it. Just pull it out by hand.
Mr. B is offline   Reply With Quote
Old 03-16-2016, 10:46 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Or have the rear view camera image show up on your Kenwood double DIN-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-16-2016, 01:34 PM   #10
Lake Mary , Florida
m.hony, do you know how to wire it? If yes, can you share it with us?
Old 03-16-2016, 03:57 PM   #11
Muskogee , Oklahoma
You have to get an RCA jack video extension cable, run it from the RCA out from the camera located overhead in the compartment, and run it to the back of the Kenwood deck's RCA video input.
I actually have a RCS jack dual splitter, and display both images, one on the camera and the other on the Kenwood deck because the picture on the mirror/monitor is so poor.
Old 03-16-2016, 05:05 PM   #12
m.hony's Avatar
2013 30' Classic
What he said.
Take it to a car stereo store.
Around here labor might be $65.
I have 2 cameras using my Alpine double DIN as a monitor with an a/b toggle switch.
Up is the truck's backup camera.
Down is the camera on the back of my trailer.
TAC #MS-10
Airforums #70955
Old 03-16-2016, 06:43 PM   #13
Lake Mary , Florida
Thanks you Gentelmen, and I would prefer to do it my self, not because of the money but in order to safe parts or some clips, etc, that they will most likely brake. The most challenging is to remove the Kenwood unit...
Old 03-16-2016, 06:47 PM   #14
Ron_CA's Avatar
San Diego , California
I am with you, just haven't gotten around to it.
Not sure if there is room but was thinking about fabricating a bracket and mount it over the mirror.
Ron_CA is offline   Reply With Quote
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 03:14 PM
Rear View Camera - Turn on Hazard and rear view flashes on and off. Tao Sprinter and B-van Forum 13 07-10-2015 05:01 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
View from your rear view mirror.... valmog On The Road... 2 08-23-2011 10:20 PM
Rear View Camera and Monitor. cooperhawk General Motorhome Topics 19 04-18-2008 04:10 PM
