Old 05-29-2016, 12:21 AM   #1
2015 Interstate Ext. Coach
Lake Mary , Florida
Rear TV cable harness
Need help from my AI fellows!
This is a picture of the harness of my rear TV, which I removed and then decided to put back. I tried to tie the harness to foldable mount behind the display, however all my variations are making it jammed by the mount legs when folding the TV down to the wall.
Can anybody please make photopictures of your TV mount with tied up harness how the Airstream originally made it?
Thanks in advance!
Mr. B is offline   Reply With Quote
Old 05-29-2016, 09:44 AM   #2
2016 Interstate Lounge Ext
Heathrow , Florida
ID:	263430 If you need to check it out in person feel free to stop by and check it out.
Harleydeal is offline   Reply With Quote
Old 05-29-2016, 10:06 AM   #3
In our TV mount, the cables run through the hollow hinge arm itself and thus do not get squashed by it.
Bear in mind that ours is a 2007 model and this is the equipment that Airstream was installing at that time. Looking at your photo, I'm glad we didn't decide to upgrade the mount.
Old 05-29-2016, 10:53 AM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Nice! That mount in your 2007 looks a lot better than the one in my 2013. Is it made from aluminum?
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 05-29-2016, 12:20 PM   #5
Lake Mary , Florida
Originally Posted by Harleydeal View Post
Attachment 263430 If you need to check it out in person feel free to stop by and check it out.
Oh yes thank you!
Please call me and I will stop by for a minute!
Will look yours, will show mine.
Old 05-29-2016, 12:26 PM   #6
Lake Mary , Florida
Yes they are different...
I am gonna look if my mount has a hole inside to run the cable. Thank you!
Old 05-29-2016, 01:33 PM   #7
- - Mike
The parts that the wires go through, yes. Extruded.
The original Interstates from that time period came with big honking analog Sony TVs, bulkier and heavier than the newer slim digitals. That was likely the motivation for the heavier mounting hardware. I sold our original TV for ten bucks to some guy who wanted to cobble together a garage TV setup for himself.
Old 05-29-2016, 03:25 PM   #8
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
90* connectors usually will facilitate coax routing behind TVs.
Old 05-29-2016, 03:47 PM   #9
Lake Mary , Florida
Marc we are talking about the harness that jams by the mounting legs
Old 05-29-2016, 05:17 PM   #10
73shark's Avatar
I thought at least one piece of that harness consisted of the RG-6 or RG-59 coax. Since it's stiffer than the audio wiring, the 90* connectors usually allow it to route easier.
Rear Teelevision cable rear outlet white laker Audio, Video & TV 0 08-29-2015 07:24 AM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
7 Pin Wiring Harness Replacement Jake Electrical - Systems, Generators, Batteries & Solar 4 09-27-2005 08:05 PM
Seat belt/shoulder harness options guy99 Airstream Motorhome Forums 16 06-26-2004 06:59 PM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 08:25 PM
