Old 12-21-2015, 12:45 PM   #1
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Rear Camera on 2014
Hi all, my issue is the rear camera on my 14. It is mounted just above the high brake/tail light and at night is rendered useless due to the glare from the red light. Has anyone found an easy relocation solution?
Bill
c21bill is offline   Reply With Quote
Old 12-21-2015, 02:37 PM   #2
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Bill,
It should be mounted below the center clearance light to avoid the red glare.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 12-21-2015, 02:46 PM   #3
Originally Posted by acstokes View Post
Bill,
That would put it on the rear door which can't happen.
Old 12-21-2015, 03:00 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The CHMSL should only be on when the brakes are applied. Even when it's on, I've never noticed any glare.
Old 12-21-2015, 04:22 PM   #5
Maybe I'll try adjusting mine up a bit
Old 12-21-2015, 04:37 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A bit of black electrical tape applied along the top edge of the center brake light might help. Just don't put enough tape to block the light completely.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-21-2015, 04:43 PM   #7
Good idea Pro, I'll try that
Old 12-21-2015, 05:33 PM   #8
Duh, I just figured out my problem. A while back I adjusted the camera downward to try to see closer to back of van but then I didn't drive at night for a while so hadn't noticed the light issue. I just adjusted it back up and it works fine now.
Thanks to all who responded.
Duh again!
Rear View Camera - Turn on Hazard and rear view flashes on and off. Tao Sprinter and B-van Forum 13 07-10-2015 05:01 PM
2014.5 Ext Backup Camera k9jackie Sprinter and B-van Forum 15 05-19-2015 01:54 PM
2014 AI EXT Rear view camera monitor problem tishaeisha Sprinter and B-van Forum 11 06-03-2014 07:07 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
