Old 08-30-2014, 10:57 AM   #1
paullovern's Avatar
2013 Interstate Coach
arlington heights , Illinois
Rear AC receptacle only works on shore power
We have a 2013 AI EXT. lounge version. I can't get the rear AC receptacle to work unless we are plugged in. Is that how its supposed to work?
Paul & Doris
paullovern is offline   Reply With Quote
Old 08-30-2014, 11:14 AM   #2
kaylorsan's Avatar
2012 Interstate Coach
Los Gatos , California
Which rear AC outlet? Some outlets are designed to work that way (not function via the inverter).
When you say 'only shore power' does that mean it does not function off of the generator?
If it does not work off of the generator you have a problem some where.
Other than that, it is probably functioning as normal.
On my 2013, I believe that the only outlets that work off of the inverter are
- the over cab outlet (TV signal boost)
- the one behind the drivers seat
- the rear TV
All of the van outlets work on generator or shore power.
In my ride, the outlet behind the drivers seat is a GFI outlet and controls some of the other outlets in the van. You might want to check to see if it is tripped. It may solve your problem.
Your layouts may be different even tho we have the same model year; it seems that the airstream crew lacks build consistency, especially when it comes to electrical.
kaylorsan is offline   Reply With Quote
Old 08-30-2014, 11:15 AM   #3
kaylorsan's Avatar
Ooops. Just noticed you have a '13. Mine is a '12. The above should still be applicable tho.
Old 08-30-2014, 02:28 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I think you can get that socket working along with some others if you turn on the inverter.
Old 08-30-2014, 06:36 PM   #5
Boxster1971's Avatar
Fulton , Maryland
My 2013 AI works as kaylorsan described. There is a fourth outlet powered by inverter under sink inside the galley cabinet. This is the one that Airstream uses for the refrigerator AC power for some strange reason. If you have an outlet not working check the ground fault as mentioned.
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
Old 08-30-2014, 07:17 PM   #6
BikerBill
Poconos of Pa , Pennsylvania
kaylorsan description is correct. The rear outlet down by the floor on the right side just in front of the couch is only on shore power OR generator just like the outside outlet.
Bikerbill is offline   Reply With Quote
Old 09-01-2014, 05:28 PM   #7
2005 16' International CCD
2015 Interstate Coach
Bandon , Oregon
I'm either dumb or blind or both, but is there an cig lighter accessory plug at the rear of the AI? There was in the AS trailer, but I just can't find one in the Interstate.
Rapa Nui is offline   Reply With Quote
Old 09-01-2014, 05:39 PM   #8
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
There's one on the psgr side rear corner next to the 110V receptacle.
Also one in the compartment over the driver by the TV antenna connection.
Old 09-01-2014, 07:43 PM   #9
Bandon , Oregon
Thank you! Blind it is.
Old 09-01-2014, 08:58 PM   #10
73shark's Avatar
There's also one below the ashtray/cupholder near the floor that I didn't find right away. It is always powered whereas the ashtray one isn't.
Old 09-01-2014, 09:05 PM   #11
Fulton , Maryland
My 2012 ext-lounge model only had the one 12v outlet in compartment above driver. I added two at end of galley and two below the rear curbside TV. It reAlly helps to have those extra 12v outlets in rear area.
- - Mike
- - Mike
Old 09-01-2014, 09:31 PM   #12
73shark's Avatar
What do you use all of them for? Just curious.
Old 09-01-2014, 10:31 PM   #13
kaylorsan's Avatar
I'm not with my Sprinter now, but I believe there is also a 12v outlet on the base of the driver seat (right side or front right) underneath the 'decorative flap' installed by Airstream.
Old 09-02-2014, 07:32 AM   #14
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Yes that's right driver seat base toward the isle. You have to lift the skirt.
Peter
PSchw is offline   Reply With Quote
My first warranty issue after three weeks--faulty shore power receptacle. Zymurbrian Electrical - Systems, Generators, Batteries & Solar 10 11-13-2012 09:09 PM
Plug Shore Power into Locker Receptacle for Generator BarnacleBill Land Yacht/Legacy Motorhomes 0 07-06-2012 08:39 PM
Radio Only Works With Ground Power robersonwill Classic Motorhomes 4 05-03-2011 04:24 AM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
