Old 06-04-2014, 08:38 PM   #15
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Just a thought. It really sounds like there's problem w/ the A/C unit itself.
Old 06-04-2014, 08:51 PM   #16
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Yep, going in to the dealer on Monday.
Ron_CA is offline   Reply With Quote
Old 06-04-2014, 09:20 PM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by 73shark View Post
Not sure how it can cool 35* below ambient when the advertised evap. temp. drop is only 21*. Mine struggled when it was 95* out to maintain 85* w/ the chassis A/C on Max/Recirc. One thing I didn't try was to crack a rear vent to push more air from the front to the rear.
Air conditioners are yet another thing that varies from one Interstate model year to the next— but I may have mis-remembered it slightly; maybe it was only 30°? Anyway, my Coleman rooftop air conditioner cools pretty well, though it's a bit noisy. Who makes yours?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-05-2014, 06:55 PM   #18
Ron_CA's Avatar
AC Fixed.......Don't ever under estimate the power of persistence. My Wife got us bumped up to today @ 1:00. This is right when the tech that the dealer wanted to look at the issue came back form lunch. We dropped her off and did some pleading and threw some bribes out there (pizza) and the service advisor called @ 3:45 and said DONE....
On generator power we are now @ 12-13 amps and cooling nicely. Pretty stoked this got resolved so quickly. Oh the power of pizza.
Old 06-05-2014, 08:20 PM   #19
73shark's Avatar
Mine is made by Dometic. Wished I could get a 30* drop on mine. Big difference.
I even removed the outside cover to check for any debris blocking the condenser but found none. Pulled the inside cover to see if anything might be blocking the air flow which isn't that great and found the junction box that AS used to make the 120V connections in was just hanging by the wiring right in front of the evaporator air flow. Moved it out of the way but didn't notice any big increase in air flow. Just another example of AS's slipshod workmanship.
I might check out the Coleman. Do you know the model number?
Old 06-05-2014, 08:23 PM   #20
73shark's Avatar
By any chance did they tell you what the problem was?
Old 06-05-2014, 08:25 PM   #21
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
AC Fixed
Great to hear its fixed, but did you ever get an explanation? We'd love to hear any details - beyond the pizza
Old 06-05-2014, 08:58 PM   #22
Ron_CA's Avatar
On the Power Control System gauge, they removed the 4 screws, pulled it out of the cabinet and disconnected both sets of wires to do a "reset". Proceed with caution if you attempt this as I believe one is power and the other is communication so not sure of the shock factor. Seems like there would be another way but this may have been the easiest.
Old 06-05-2014, 09:09 PM   #23
73shark's Avatar
Must be something on the new models. I don't know what the Power System gauge is.
Do you know what brand your A/C is?
Old 06-05-2014, 09:21 PM   #24
Ron_CA's Avatar
It is the gauge that shows if you are on Gen, 30A or 20A power and shows how many amps you are drawing.
My AC is a Dometic Duo Therm.
Old 06-06-2014, 09:19 AM   #25
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I think Airstream added the current power monitoring system in 2012. It is called the Power Control System built by Precision Circuits Inc. to monitor the AC loads. See attached brochure and photo of my Airstream Interstate unit.
Name:	Power Control System Panel.jpg
- - Mike
Old 06-06-2014, 12:37 PM   #26
Maybe in 2013. My 2012 doesn't have it.
WBCCI #1105
TAC LA-4
Old 06-07-2014, 11:20 AM   #27
73shark's Avatar
Since the 2015 has the Dometic A/C, was wondering what model your Coleman is.
Old 06-07-2014, 06:06 PM   #28
Senior moment strikes again! It's not a Coleman, it's a 13,500BTU Carrier air conditioner. Coleman, Carrier, I knew it was one of those "C" names! As dumb as that makes me feel, I'd have really felt like an idiot if it had been a Dometic after all, though…
Apparently Carrier no longer makes them, either, so I had better make sure I don't scrape mine off with a low-hanging branch any time soon!
WBCCI #1105
TAC LA-4
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
cool, but not cold nuff' happypill Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-23-2009 07:21 AM
carrier v low cool vs high cool rvlover Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 08:20 PM
Dometic RM 66 is to cold Mike B Refrigerators 10 03-25-2003 09:58 AM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
