Old 07-24-2015, 11:06 AM   #1
AI owner since June 2013
2014 Interstate Ext. Coach
Lake Mary , Florida
Raising Clearance on AI
I have traveled a few hilly back roads recently in the AI which have caused some bottoming out scrapes, especially on the low hanging gen platform. Are there any air shocks (thinking back to my 60's muscle car days) or other means to temporarily raise the back end of the chassis a few inches to avoid damage on low speed clearance situations that may be recurring?
FlaBucki is offline   Reply With Quote
Old 07-24-2015, 11:22 AM   #2
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Are you sure it is the gen hitting or is it the drag bars in back?
Best thing you can do is go slow in these situations and take driveways or inclines at an angle.
Will be interesting to hear if there are any onboard adjustable shocks available for AI.
Ron_CA is offline   Reply With Quote
Old 07-24-2015, 12:13 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Ron_CA— Koni shocks are adjustable, and I have a set on my 2012 Interstate. But they don't give you a higher ride, only less of a squishy ride. You would need a lift kit or an air suspension to get a higher ride.
FlaBucki— If you're scraping pavement anywhere, you'll be able to see scratches where you've hit by crawling underneath. I'm with Ron_CA on this one, it's probably the drag bars on the underside of the hitch that are dragging, because you've got such a long overhang and low departure angle— there's a reason it's called the Airstream Interstate and not the Airstream Backroads!
The cheapest fix is to replace the drag bars with rollers; that won't keep the arse-end of the van from dragging sometimes, but will make it less traumatic when it does happen. You could get an air suspension installed to provide more lift, but that's an expensive retrofit. If your budget it up to it, it's probably worthwhile to do, judging from reports by those who have done it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-24-2015, 12:29 PM   #4
Lily&Me's Avatar
Normal , Illinois
What Ron said.
Maggie
Old 07-24-2015, 12:47 PM   #5
UKDUDE's Avatar
Sedona , Arizona
I've posted this before: rollers on a Great West Van Legend.
Old 07-24-2015, 01:12 PM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The Sprinter Store sells air bag assist springs. They are the only item short of of a full Air Suspension that can lift the back end of a XL Sprinter.
http://sprinterstore.com/air_bag_kit.htm
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 07-24-2015, 04:16 PM   #7
2016 Interstate Lounge Ext
il , Illinois
I have the VB air suspension and it takes some planning to use it to avoid tail dragging.
You have to stop and raise the car and drive very slow to keep the height.
I believe less than 5 mph an it takes some time to raise it.
mmmmm is offline   Reply With Quote
Old 07-24-2015, 05:51 PM   #8
I was hoping the originator would re-post that pic. Anyone have sourcing?? This is something I want to investigate further.
Old 07-24-2015, 06:45 PM   #9
UKDUDE's Avatar
Sedona , Arizona
I don't have these yet, but I know they can be obtained here:
http://www.etrailer.com/Skid-Wheels/...48-979014.html
Old 07-25-2015, 05:41 AM   #10
Raymond , Iowa
I can see rollers being better than skids. But on mine it would have been nice if the skids were at least the lowest point in the back. My trailer wiring box hangs lower than the skid. What a wonderful design! Fortunately the wiring box is more tolerant of dragging than is the LPG fill box - another design flaw. Low clearance between the front and rear wheels is unlikely to be a problem unless you are off-roading the AI. But the lowest hanging fruit in this area seems to be the black tank knife valve, then the macerator pump.
Titus is offline   Reply With Quote
Old 07-25-2015, 11:17 AM   #11
Lake Mary , Florida
Thanks Protag - do you know a source for rollers to replace drag bars?
Old 07-25-2015, 11:42 AM   #12
See post #9 from UKDUDE.
WBCCI #1105
TAC LA-4
Old 07-25-2015, 11:44 AM   #13
UKDUDE's Avatar
Sedona , Arizona
Google "Skid wheels" - you will find lots of places that sell them: bolt-on, weld-on, solid, caster, etc.
Old 07-25-2015, 11:48 AM   #14
Side note, if you have room for more than one roller on each side, put as many as will fit. The more contact surface, the better to spread out the load.
WBCCI #1105
TAC LA-4
Clearance clearance LEDs mayco Classic Motorhomes 55 04-29-2016 04:41 PM
raising a 345mh 345bill Classic Motorhomes 2 12-31-2007 10:32 AM
Raising the Flying Cloud dmaiden Axles 22 12-26-2006 04:15 PM
raising the trailer atvmcg Repairing/Replacing Floor &/or Frame 9 11-18-2005 09:10 AM
Raising Trailer Height John Sims Axles 2 06-24-2003 10:52 AM
