07-07-2013, 04:34 PM
Normal
Rainstorm knocked out frig! HELP!
We drove through a hellatious rainstorm for about an hour in SD today, with heavy winds and blinding rain.
Now parked in Pierre, the frig will not work on electricity or propane. Nothing.
Doug removed the external vent, and mopped up a lot of water that had collected in there. He has left the vent off to help dry everything out.
There was also some water in the storage area under the frig, presumably blown in thru the refrigerator vent?
He replaced the frig fuse, although the one in there looked okay. All the other fuses seem to be okay.
The Dometic manual says not to spray water in through the outer vent when washing the vehicle, so water apparently causes problems.
What to do? Suggestions, please.
Maggie
07-07-2013, 04:55 PM
Naples
Your control board probably shorted in the deluge. You can bypass the board for 120VAC electric use, but you will have to operate it manually, as you will have no thermostat. Verify that you have 12VDC power at the connection block for the fridge. If you have it there, the board is probably toast.
Find the 2 wires connecting the electric heating element to the board, remove the 1/4" push-on plugs from the board. Make a jumper cable that will allow you to connect the hot and neutral leads from the 120VAC outlet in the fridge plenum directly to the heating element.
This will provide 120VAC power to the heating element that will provide the heating source to keep your fridge cold.....but it will be running WIDE OPEN! and will freeze the contents of the fridge.
If you modulate the power to the element, perhaps 1/2 hour on, then 15 minutes to 1/2 hour off by unplugging the jumper from the 120VAC outlet, you can manually regulate the temps.
Before retiring for the evening, get the fridge very cole and DO NOT OPEN THE DOOR until morning....with the element disconnected.
Hopefully, you can get a new control board ASAP!
lewster
07-07-2013, 04:59 PM
Normal
A neighbor here has just looked at things, says the GFI switch won't reset, probably due to moisture somewhere.
We have everything opened up. The area underneath the frig is quite wet.
We have unplugged from electricity, hoping the frig will start off the propane.
Maggie
07-07-2013, 05:04 PM
Normal
Lewster, you may as well be speaking Russian.
We haven't a clue what you are talking about or how to do those things.
There is an RV dealer near here. May have to head there in the am.
Thanks for your help.
Maggie
07-07-2013, 05:09 PM
Normal
The GFI switch reset, now that we are not plugged into electricity.
Don't know if this will at all affect the frig working off the propane.
Maggie
07-07-2013, 05:36 PM
Normal
Lewster, what is the control board, and where should it be located?
Frig is not lighting, Doug has headed to get ice so we can empty the frig and freezer into the soft-sided coolers we keep for emergencies.
Maggie
07-07-2013, 05:40 PM
Naples
Sorry, I was caught up.....I guess speaking in tongues! Too technical?
Anyway, if you have no 12VDC power to the fridge and your control board, IT WILL NOT WORK! That is irrespective of having 120VAC thru your GFCI or not.
The control board uses the 12VDC to regulate all of the functions of the fridge.
There should be a white terminal block at the back of the fridge with 2 heavy wires entering and a couple coming out. Check for 12VDC there.
lewster
07-07-2013, 05:52 PM
Normal
Okay, then that is behind the vent Doug removed, and which had a lot of water in it.
We saw those white cords, but seriously don't know enough to touch them and mess with them.
Putting everything on ice, and going to this RV place tomorrow.
Note to self: when caught in heavy rainstorm with winds up to 50mph, pull off road and park so rain and wind are anywhere but on driver's side where frig is located.
Maggie
07-07-2013, 06:47 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Doug & Maggie,
Can't really help just wishing for an easy fix and safe travels. Lessee SD with time to kill, been to Wall Drug or at least seen the Wall Drug signs?
Good luck.
Gary
07-07-2013, 06:56 PM
Normal
Thanks.
I'm really looking for a magic wand, but none has come forth.
We have been to Wall Drug, on a previous trip.
We have precious few problems with this rig, but it really takes the wind out of one's sails when something major like a frig goes out.
In the city park here, the neighbor who came to help lost the cover to his AC, parked here in the same storm that swept us in.
May be a pile of us at the RV dealer in the am.
Maggie.
07-08-2013, 05:20 AM
Normal
Got up this am, and the GFI switch reset. Apparently, everything dried out on the night,
Frig has been on 25 minutes, all seems well.
We are going to go by the RV place here in Pierre in a bit, and have them take a look at things. We have had high winds blow the frig out in the past, but never rain.
Maggie
07-08-2013, 05:23 AM
1995 30' Excella
Bowie
, Maryland
For some reason, I thought the Interstates used a compressor fridge... not true, apparently? (If it runs on propane...)
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
07-08-2013, 05:33 AM
Normal
I don't know what a compressor frig is. Doug says it is like the one at home.
We have a Dometic, runs on electricity or propane. The guy here in the Lexington said it is exactly like his.
I'm tired. We didn't sleep terribly well.
Maggie.
07-08-2013, 05:39 AM
1995 30' Excella
Bowie
, Maryland
A compressor fridge is what you have in your house at home - it uses a compressor to move the refrigerant around, making it far more effective. This is usually what you hear running in your fridge at home.
An absorption fridge, what they usually use in campers, has no moving parts - the fluid moves via convection and gravity alone and can use any heat source (hence how they can run on 120 volt, propane, or even 12 volt if you have a lot of patience). The advantages are they use very little energy and can use different sources, and they're usually silent or close to it; the disadvantages are that they're not as amenable to being opened and closed all day and are usually slower to cool down initially - although, I have to say, the Norcold in our trailer is much better about both of those things than the fridge in the B190 was.
Newer absorption fridges have a 12 volt control board in them so they always require 12 volt power while operating, even if you're using propane (the one in my old B190 didn't have a board and so could run without any electricity at all). There's good and bad in that; it's usually not a problem though since almost everything else needs 12 volts too, and they don't draw much power.
07-08-2013, 05:41 AM
Normal
Thanks for the info, Skater.
We are a bit technologically challenged.
Maggie
07-08-2013, 05:43 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
Maggie
Something similiar happened to a friend this spring. Blowing a hair dryer (not too close) on the control board cured the problem. within a few minutes Apparently they don't like getting moisture on them and are mounted in a vulnerable place.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
07-08-2013, 05:45 AM
Normal
Thanks for that bit of info, Rick.
The Lexington guy recommended a hairdryer, too, but we don't carry one. May have to start.
Maggie
07-08-2013, 06:26 AM
1999 34' Excella
Hillsboro
Here is a thought and possible money maker,,,
Go to a sheet metal shop and have them fashion a hood to cover the fridge door? I think that would be a great idea! I am going to have one made for our 34 Excella!
Peace and Blessings..
Channing
WBCCI# 30676
07-08-2013, 06:37 AM
Normal
Hmmm, that's a good idea.
Frig is still on. We are talking ourselves out of going to the RV place, as the problem seems resolved and we have interior cleanup to do from the flooding in here yesterday.
A phenomenal amount of water came in thru that vent, bringing with it 7 or so years of accumulated crud from the area under the frig.....the recesses unseen and uncleaned all this time. Looked like the mighty, muddy Mississippi came through here. The rugs were soaked and muddy water has now dried on the edges. That has never happened before.
A trip to the laundromat and a wash of the floor is first on our agenda this a.m.
I am wondering about putting a gasket of some sort around the exterior of that outside vent. ?? That has to be where wind and water are coming in, as the louvers or whatever are angled downward. ??
Maggie
07-08-2013, 06:51 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Not necessarily. Louvers angled downwards are fine when parked, but may not be as effective when moving, depending on your slipstream. Water could have still come in the louvers while driving.
You may want to fashion a cover that's shaped like a box, to cover the entire door, except with an open bottom, so the louvers are out of your slipstream. This plus the gasket you're contemplating.
I wonder if this is one reason why late-model Interstates have 12v/120v Nova Kool refrigerators instead? No outside vents, but no option to run the fridge on propane while boondocking, either.
