07-02-2015, 12:25 PM
2015 Interstate Ext. Coach
Tigard
, Oregon
Raining in our Interstate - You Too??
Have had our 2015 Interstate Grand Tour Ext. for 4 months. Since purchase every time it rained we have had water leakage problems. First around the refrigerator. Then we had water coming in through the bath vent when the vent was closed. We have had it into the dealer 3 times, and each time they say they have looked at all the seals, etc., recaulked areas and that it was fixed. So, we left home on a 5 week trek across America. My first shower came while camped and sleeping, with water running down off the port side under the storage area into my face. Nice wake up call. No leaks while raining, even intense rain when we are moving, but when parked we have had water coming through the air conditioning unit, both left and right sides, and through the bath vent. (Have video of each) While it was dripping through the AC, I took a flash light and looked to find the source and it appears the water is entering somewhere on the roof and "riding" the ceiling and directing itself downstream based on the angle and slope we are parked at. ie, a 1 degree slope to starboard and water heads that way. Called the dealer to get into another dealership, but it is the 4th of July and they could not get me an appointment, but if we stop someone "might get a chance" to look at it. Ironically, we took the factory tour on this trip and I watched closely an AS being water tested. They do it perfectly flat with what appear to be fire sprinklers. I wonder if they tilted the vehicle, if they would have more issues? Now, after 4 months of leaking, what other damage is done? We now have squeaks in the floor. The water was discolored dropping through the AC. Is the particle board deteriorating? Are wires rusting? Are we now subject to mold? How do we handle this? Lemon law?? Looking for suggestions, and anyone else with an Interstate seeing this........thank you!!!
"The more you think you know...........The more close minded you will be"
07-02-2015, 01:04 PM
Normal
Boooo!
I am sorry for those troubles, because an Interstate really is the way to go, in my opinion.
Have had ours 8+'years. We had roof leakage, too....around the Fantastic Fan vent and the black water tank vent....the latter of which let copious amount of rain into the closet, where our clothes were.
I believe your dealer, and/or Airstream, have an OBLIGATION to find the source of the leaks, and then FIX them. Period. Also any resulting issues as a result of the leaks.
Ours were finally tracked, by my husband, to installation problems.
He finally took things apart, down to the roof, and they looked like they had each been installed by chimpanzees playing with a drill for the first time. Seriously.
The original holes in the vent fan had been ignored in favor of new holes, the original ones caulked but insufficiently to keep rain out.
The black tank vent did not fit the area it was crammed into on the roof, holes were drilled every which way, the vent broken and cracked to fit, and the whole mess covered with caulk.
All the caulk in the world will not prevent leaks from improper installs.
My suggestion is that you have a conversation with Jackson Center about the problems, confirm in an email, and insist that they coordinate with your dealer to fix your problems.
They monitor these forums, someone from JC may jump in here and offer their assistance.
You should not be having these issues with a new rig.
Good luck, and keep us posted.
Maggie
07-02-2015, 05:52 PM
Muskogee
, Oklahoma
Welcome to the world of Airstream quality control, where the customer is the unpaid employee used to find the things the installers in their hurry to crank out product did wrong.
The AC is more than likely leaking around the perimeter of the unit itself. The roof is not flat; it has ribs, but the AC is designed for a flat roof. That's one problem. When stationary, the water will flow around the unit and find its way inside if there is the slightest leak.The other is that the flat part that the unit sits on is sealed with a foam strip, and if the installers forgot to tighten it down, it will leak. Mine did exactly the same as yours on a early dawn morning. I seriously doubt Airstream water tests these units before they go out the door.
On inspection, I found they had not tightened down the bolts that hold down the AC unit on the roof, so the foam strip was not water tight. The bolts were less than hand tight. I'm lucky the thing didn't fall off. In the corners, there was a minimal attempt to seal the unit between the ribs with some Sika221-but very minimal.
I tightened the bolts, and added a bit of Sika 221. Haven't had a problem since.
The leak around the plumbing is probably something similar. Get up there and take a look, and you will likely find the problem is inadequate sealant. Get a tube of Sika221 and do a better job than the installer, and you will likely fix that, too.
Good luck.
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
07-02-2015, 11:07 PM
Jeff
2013 Interstate Coach
Seattle
Speaking of leaks. Another place to look. Since we bought our AI couldn't figure out why water was leaking out from under the bath area periodically forward and rear depending if the AI was parked nose down or rear down. Checked all the pipes and fittings I could get at including the bathroom sink plumbing accessed by the removable section just below the wardrobe. After a more thorough examination earlier this year discovered that both bathroom sink water line connectors were loose and leaking, either not tightened down properly from the factory or shook loose as the AI aged (we bought it new 16 months ago.) The leaks were small enough even under pressurization not to be that noticeable under routine scrutiny. Leakage into the main living area apparently happened after enough water had pooled deep enough on the floor under the bath area. Discovered the leaking connections by making sure the fittings had no condensation (dried thoroughly), then wrapped the pressurized hot and cold water fittings in paper towels for a short period of time. Soaked. Tightened both connections and no water problems since.
07-03-2015, 03:47 AM
2009 Interstate
Bethesda
, Maryland
Check the windows as well. Sometimes driving down the road in the rain with the AC on doesn't reveal leaks because of a slight pressurization. I had two windows that leaked only when sitting still . One was really small and fixed in place, the other right rear window involved taking it out and reinstalling properly. I also had a small bath vent leak that was fixed with a little caulk. Keep in mind the the caulk is Sikaflex P21 typically not available at the local home improvement store.
2009 Airstream Interstate
07-03-2015, 06:09 AM
League City
As a general measure for all Interstate owners, I suggest pulling your screws whenever you happen to be working on something on the roof, even if pulling screws is not required of the task at hand. Sometimes you find leak problems about to occur, or problems that had begun to manifest that you hadn't learned about yet.
Here is a pic of one of ours. The screw looked like this but the water hadn't yet made it all the way inside. For whatever screwy reason, we had this result at the Fantastic on the starboard side but the port side showed no evidence of any corrosion or incipient water penetration. If we'd only pulled one of four screws to check this, we would have had a 50% chance of missing the issue entirely.
07-03-2015, 06:51 AM
Normal
The bottom line, tho, is the OP has a brand new Interstate.
They are under warranty and Airstream needs to fully resolve these leaks and any resulting interior issues.
It is really sad and hard to read of all this, and difficult to imagine that someone did not know of these problems before it was sold.
Airstream needs to step up.
Maggie
07-03-2015, 01:39 PM
2008 Base Camp
Elizabethtown
, Kentucky
When we bought our brand-new Airstream Basecamp in 2007, we also had problems with leakage and worried about what damage was being done behind the walls. This really should not be happening with brand-new Airstreams. We finally solved our leakage problems with Captain Tolley's Creeping Crack Cure on all the exterior seams (for visually undetectable cracks, through capillary action). I learned about this product years ago on the forum. Product — Capt. Tolley's Creeping Crack Cure
07-03-2015, 05:29 PM
Madison
, Alabama
This is a cadmium plated screw, not suitable for external use.
I personally installed a Fan-tastic vent fan in the roof vent of my Featherlite. The co. supplied a stainless steel screw for each mounting hole. 6 years in service and no leaks for that installation. No rust on the screws.
There can be no excuse for use of the fastener shown in the photo.
07-04-2015, 05:47 AM
League City
I agree with you, but so far, we have not located a stainless steel screw ANYWHERE in the Airstream-built portions of our Interstate. And we've pulled it apart extensively. Each time we get set to do maintenance or upgrades, we have to spec the hardware that we will need to replace corroding hardware. Sometimes it's best to order that stuff off the internet so it has to be done in advance of a project.
Case in point. We have a T1N Interstate, and they were built with running boards. The running boards are held on in two ways - via a series of structural struts attached to the chassis, and then stabilized with about 40 screws (20 on each side) securing it tight to the frame.
You would think that, if Airstream were going to use more durable hardware anywhere, it would be directly beneath the vehicle because that's the area of highest corrosion potential. But no. We have to retrofit all the running board hardware because the heads are rusting off the existing screws to the point where pretty soon, the only way to get them out will be to over-drill. Our Interstate has only 28,000 miles on it and it is garaged, so it hasn't been subjected to extremely corroding conditions.
The reason for Airstream's choice is easy to surmise: stainless hardware is expensive. This pic shows the replacement hardware for the running boards (project to be done as soon as I figure out what product will work best to re-seal the underside of the fiberglass of which they are constructed). The handful that is shown here probably totaled around a hundred bucks in cost.
07-04-2015, 06:56 AM
Tigard
, Oregon
Thanks to all that have responded!! We are still on the road and fortunately have not encountered any additional rain. We bought a new Interstate because, in part, of Airstream's reputation and the MB Sprinter powertrain, etc.. (FYI, on our way we traveled over the highest road in the U.S., within Rocky Mountain National Park. 12,250 feet, no guardrail, with sheer drops of thousands of feet off the road. The MB diesel was flawless, even at over 2 miles altitude.)
But, we expected, with all the components to have the usual glitches. Water leakage was not one of them. I appreciate the knowledge shared here, and the ability to tear into your rigs to ascertain what is going wrong, sharing that insight. The issue we have with a new rig is how should AS be stepping up? Obviously this is a problem which started while it was being manufactured. As I mentioned water can cause mold, rust, deterioration of particle board, etc.. When these issues present themselves down the road how do you prove it was related to the initial leakage? (if, in fact they can find and fix the leaks)
So, we now are faced with confronting a dealer who inherited the problem from AS. They may handle this well, but maybe not. We just didn't buy an AS to have these problems. We, as many of you, have been around the block a few times and most situations are handled appropriately, but there are the 5-10% where you have to use a bigger stick when you are correct. This is so disappointing to have this on our mind through a vacation we have planned for years. Are we going to have to battle AS over a congenital defect in one of their units that could have caused internal damage related to all the leakage. (some of the water dripping is discolored)
I would be interested in hearing what you believe should be the appropriate response from AS, given we have had it into the dealer 3 previous times with water leakage issues in our first 4 months of ownership, and it was obviously not resolved. (Although, I believe they gave it genuine effort-it was not enough, obviously)
Thanks to all for your responses, we find this "extended family of AS owners" extremely helpful and very useful.
PS: A while ago there was a book called "In Search of Excellence". They interviewed CEO's about why their companies were successful. I remember one from an airline who said: "If a passenger sits down in their seat and the tray table comes down crooked, what will they think? If we can't fix a tray table, what are we doing with our engines?" I always remember that. In the AS factory, the floor was covered with scrap metal, rivets everywhere. I was surprised they didn't make more of an effort to sweep. Possibly I was wrong about AS, and they would be OK with crooked tray tables. I will keep you all posted on how it is handled.
07-04-2015, 07:41 AM
League City
Originally Posted by Oldforester
... In the AS factory, the floor was covered with scrap metal, rivets everywhere. I was surprised they didn't make more of an effort to sweep. Possibly I was wrong about AS, and they would be OK with crooked tray tables. ....
What you note about associative quality is generally true. I've been an industrial consultant for more than 20 years, and have seen the inside of somewhere between 100 and 200 manufacturing and heavy service facilities. The attitude that shows in the workSPACE is most often reflective of the quality that gets transmitted into the workPIECE. There are certain exceptions for specific reasons (some historical, some logistical), but this is most often the case. All totaled, it sounds to me like Airstream might need to seriously clean house where their QA/QC process is concerned.
07-04-2015, 07:59 AM
Durango
A couple of years ago, we decided to look at Sprinter based class B units. Having owned a 2006 Airstream, complete with leaks and construction trash, an Interstate was not on the short list. We were able to compare the quality of the Interstate with another make at the dealership. We went with the SOB and 2 years and 10,000 miles later, we have had ZERO defects. Our unit is built in Canada by Mennonites and there is currently an eight month wait time for delivery. In fact, I can sell mine for the same price that I paid.
If I were to make an observation, it would be that the pressures Thor has put on Airstream along with their other individual brands to contribute to corporate profits has created the situation described by Oldforester and others.
If you don't go first class, your heirs will!
07-04-2015, 08:43 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
For the benefit of those who don't have QA/QC experience, QA is quality assurance. QC is quality control. The difference is that the manufacturer does quality control. The customer, or a representative of the customer, does quality assurance. At least that's the distinction made by the Corps of Engineers. The guy who welds the frame needs to perform quality control on his welds, and own up to any mistakes and fix them. The guy who sets the rivets needs to do quality control on his rivet work, and be willing to own up to any mistakes and fix them. And so on.
There also have to be inspectors, who come along behind the workers, and perform an independent check on the quality, to assure themselves— and the customers— that the quality control has been done. If the QC is done properly, the QA is easy and cheap. If the QC isn't done properly (or done at all), proper QA runs up the cost of the total job because of all the work that has to be done over.
My guess is that the less-experienced workers don't know how to do QC, and have a vested interest in hiding their own mistakes rather than owning up to them. I would also guess that the Airstream QA inspectors have a vested interest in keeping costs down rather than keeping quality up, and so don't do their job the way it's supposed to be done.
I would like to see every Airstream product come with a list in the set of owner's manuals, that identifies exactly who did what, so that you know that John Doe installed the air conditioner and Joe Blow set the rivets, and Anon Y. Maus performed the final inspection on the Airstream. Then when repairs are needed that can be traced back to a factory defect, Airstream would know exactly who messed up, and thus would know who needs additional training to keep it from happening again— or if one person is responsible for an inordinate number of defects, who needs to be fired to make room for someone better.
07-04-2015, 09:01 AM
Normal
To answer the OP's recent question, I think you need to contact JC, advise them of the problems which have not been resolved by your dealer, and ask how they will handle and resolve them.
You are under warranty, and they are ultimately responsible for their product.
Start with JC, as you have already been to the dealer three times.
They may need to authorize something the dealer needs to do.
Get names, email addresses, document everything in writing, and follow up.
Maggie
07-05-2015, 04:49 AM
2022 16' Basecamp
Chapel Hill
, North Carolina
OK Folks, this is a distrubing thread to a chap who just 2 weeks ago picked up his new 2016 Grand Tour. On the surface, the fit and finish looks excellent BUT from what I'm reading here, that's like lipstick on a pig.
Sounds like a new owner needs to:
Interior: Get into all compartments and crannies checking joints/connectors/drains for poor workmanship trying to prevent a problem generated by the factory crew.
Exterior: Get up on the roof and replace all screws with stainless steel and be sure chalking is correct, or as implied on this thread, re-chalk all seams.
Check the running board attachment to MB body - refit with stainless hardware.
Odd that Airstream notes repeatedly in the literature to the new owner about the dangers of condensation, mold, rot, etc, yet doesn't do their part in preventing it in the first place. I feel secure in saying there is far less risk from my exhalation of moisture from breathing or my wife's cooking vapors causing mold than a leak at the roof air conditioner, bath vent fan or other fitting!
In short, I bought a $158K+ rig to use it, not to spend my time repairing what Airstream choose to cheat the buyer on - quality craftsmanship. At 68 years of age, the last thing I expected when I wrote the check to pay for the GT was climbing on the roof to learn what was not done correctly!
07-05-2015, 07:36 AM
Muskogee
, Oklahoma
The running boards re not attached the same way on your model.
I would not replace all the hardware this time. And there are no seams on an Interstate to seal (one of the things that can get confusing when trailer owners respond to an Interstate topic).
I wouldn't worry about anything at this point. Enjoy it, and who knows, maybe the crew did most of the install correctly. What they didn't do right will make itself known soon enough after a trip or two. Then have the dealer fix it under warranty. This is typical with most if not all of the manufacturer's. You may get lucky and have zero defect unit (I doubt every one made has the same issues). Forums like this tend to bring out those folks who have problems and not those who don't and have not had any at all-and there are many of them.
Owning any RV requires ongoing inspection, repair and maintenance. So, don't worry, be happy, and enjoy.
07-05-2015, 08:38 AM
League City
Originally Posted by Protagonist
I would like to see every Airstream product come with a list in the set of owner's manuals, that identifies exactly who did what, so that you know that John Doe installed the air conditioner and Joe Blow set the rivets, and Anon Y. Maus performed the final inspection on the Airstream. Then when repairs are needed that can be traced back to a factory defect, Airstream would know exactly who messed up, ....
This is a nice summary, and the general procedure is, of course, done that way with a wide variety of other consumer products and especially industrial deliverables where the potential ramification and liability can be much higher. (Even if those worker names are not revealed to the customer, the employer sure as heck knows who they are... and their managers).
If someone's turbine throws a blade, there's no telling what could happen. In the case of United #232, the answer was the loss of 111 passenger lives. But, you say, that was a DC-10 and these are just Airstream Interstates. Sure, but smaller-scale analogous situations are easy to imagine. If someone's black water vent shears off under normal use because of a defect and their tank is spewing water within inches of their electrical converter, that's a situation that could become a danger to the passengers.
I've worked with some operators who simply would not change their corporate culture until one of two things happened:
(1) They got sued
(2) Their insurance costs ballooned to become unmanageable
The most common pathway seems to be (2). The type of corporate culture that engages in messy workmanship in the product and leaves rivets and scrap metal on the production area floor tends to be a culture in which the employee injury rate will eventually catch up with them. I've seen companies screw up to the point where they began struggling to pay their Workers' Comp. That's when the epiphany tends to occur. But it can take years to proceed through that cycle and emerge in state of higher operational quality.
07-05-2015, 09:13 AM
2011 Interstate Coach
Overland Park
, Kansas
If you are worried about leaks on the roof, I would simply check all of the Sikaflex caulking around all of the penetrations. On mine while the appearance is pretty sloppy, it does seem to be functional.
Unless yours is new from the factory, the first thing to check would be the capacity of the house batteries.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
07-05-2015, 09:46 AM
Durango
Protaginist said, "I would like to see every Airstream product come with a list in the set of owner's manuals, that identifies exactly who did what, so that you know that John Doe installed the air conditioner and Joe Blow set the rivets, and Anon Y. Maus performed the final inspection on the Airstream. Then when repairs are needed that can be traced back to a factory defect, Airstream would know exactly who messed up, and thus would know who needs additional training to keep it from happening again— or if one person is responsible for an inordinate number of defects, who needs to be fired to make room for someone better."
My LTV Unity came with a 100 page loose leaf owner's binder specific to my model that included not only all of the components, but the serial numbers of said components and the name of the employee who signed off on the installation.
