Old 01-28-2019, 08:02 PM   #1
2018 Interstate Lounge Ext
College Station , Texas
Quick connect LPG to Coleman Stove
Has anyone had success using the quick connect from the LPG on the Interstate to a Coleman cook stove?
1st time RV is offline   Reply With Quote
Old 01-29-2019, 08:50 AM   #2
Lineolated's Avatar
2014 Interstate Coach
Centre County , Pennsylvania
Iíve used the quick connect for a grill (not a Coleman stove, sorry). Youíll need to remove the regulator from the stove, because the quick connect propane port is already low pressure.
Lineolated is offline   Reply With Quote
Old 01-29-2019, 10:54 AM   #3
Arroyo Grande & Central Point , California & Oregon
Ditto on Lineolated comments. You should be able to find a shut off valve to replace the pressure regulator on the Coleman.
c21bill is offline   Reply With Quote
Old 01-29-2019, 07:14 PM   #4
2017 Interstate Grand Tour Ext
Western , Tennessee
Yes, I have connected my propane Coleman 2 burner stove to the quick connect by the curb side rear tire. I bought the hose and quick connect, then needed to buy a female to female brass fitting. All was purchase at Lowe's or Home Depot. I did this project in the spring when Lowe's was first displaying outdoor grills, that is when the grill parts / hoses are not picked over.
I connected the double female fitting to the stove, then the hose with quick connect. I did not change any of the original stove parts, therefore I can return to small bottle propane. Be sure to seal fittings and check for propane leaks.
TN Princess is offline   Reply With Quote
Quick connect extra propane fitting Rich of SCal LP Gas, Piping, Tanks & Regulators 21 08-21-2016 01:10 PM
LPG Aux Quick Connect Mcrider Sprinter and B-van Forum 6 11-15-2015 10:12 PM
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 13 06-10-2015 05:20 PM
Quick Connect - water inlet? Kevin245 Fresh Water Systems 10 05-13-2009 05:26 PM
A new kind of quick connect 12V outlet Westfalia Electrical - Systems, Generators, Batteries & Solar 3 09-04-2005 07:26 PM
