Old 02-28-2016, 06:32 PM   #1
2015 Interstate Coach
MEDFORD , New Jersey
Pyle Monitor w/rear View camera
i'm having a problem with my Pyle monitor Rear view camera on my recently purchased 2015 Lounge Ext, with 3300 mi. i drove it back from Florida with no problem, just today it started to flash on /off. Seems like a lose connection somewhere.
Has anyone experience this problem?? It did come off the sprinter's rear view mirror and was hanging for a short time.
RICKBETTY is offline   Reply With Quote
Old 02-28-2016, 07:11 PM   #2
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
You can check the connection by pulling the light cover off. If it was dangling it is possible to have loosened up but IMO not likely but worth a look. Couple minutes or less.
Ron_CA is offline   Reply With Quote
Old 02-28-2016, 07:25 PM   #3
2011 Interstate Coach
Muskogee , Oklahoma
Better yet, who hasn't?
The problem is likely the fuse holder to the camera which has a weak spring holding it in place. Airstream crams it, along with a rats nest of excess wires, in the area in the upper overhead compartment on the street side inside wall. Stress on the wire makes the connection loose and intermittent. To fix it you you have to remove the side wall with four screws, find the wire which should be found stuffed on the area and just below the floor of the shelf, and secure the connection. While at it also check the connections to the monitor above the overhead map light holder.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 02-28-2016, 07:27 PM   #4
73shark's Avatar
Overland Park , Kansas
The Pyle has had a checkered history. Mine quit completely after about two years. Others have found a loose connection that Ron and gmiller referred to.
Old 02-29-2016, 09:04 AM   #5
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by gmillerok1 View Post
Better yet, who hasn't? ....
I haven't had any issues with the Pyle display in over three years of use. Must just be luck?
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 02-29-2016, 02:28 PM   #6
2014 Interstate Ext. Coach
Las Cruces , New Mexico
I replaced the OE within the first year of ownership. Same problems, but it was the unit and not any wire connection issues. As I live some six hours away from the dealer from whom the AI was purchased, I went on Amazon and found the unit on line for a very reasonable price. The next time I was in Scottsdale, AZ, went to the dealer and received a replacement for the original. I now have a back up.
JJKinnerup is offline   Reply With Quote
Old 02-29-2016, 02:50 PM   #7
The Pyle was mentioned over a year ago, and not completely favorably, when we were putting in our rear and side camera system (our rig was born without any cameras). I don't yet have a concise blog post with full sourcing information for that project, but for those contemplating replacing their OEM component(s), here is that thread. I love the system we put in - huge monitor, easy visibility, image flips right and left when the turn signal is actuated, and no malfunctions (knock wood).
Old 02-29-2016, 07:32 PM   #8
Evansville , Indiana
Since this thread is located in the same neighborhood, I have a question about the overhead map light console just above the rear cam monitor in our 2011 AI. There is a 2" x 5" plastic panel that looks like it is a blank cover for some type of Sprinter option. Any ideas what could go there?
BurntAsphalt is offline   Reply With Quote
Old 02-29-2016, 08:46 PM   #9
UKDUDE's Avatar
Sedona , Arizona
I know a couple of folks who have installed a TPMS monitor there. Theirs went in quite neatly.
Old 03-01-2016, 10:34 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It's exactly the right size for any 1DIN car electronics, such as a CB radio. And there is a 12v prewire behind the pop-off panel as well. The wires are very small-gauge and so might have to be replaced with something more substantial, but they're there.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-01-2016, 03:57 PM   #11
iaqstuff's Avatar
Yarnell , Arizona
Our camera has a connection problem at the camera. Moving it around to make connection and then making sure it wasn't disturbed has fixed it for now.
iaqstuff is offline   Reply With Quote
Rear View Camera - Turn on Hazard and rear view flashes on and off. Tao Sprinter and B-van Forum 13 07-10-2015 05:01 PM
Ohio Pyle State Park, Pennsylvania Air Cruiser On The Road... 14 04-30-2015 05:36 AM
2014 AI EXT Rear view camera monitor problem tishaeisha Sprinter and B-van Forum 11 06-03-2014 07:07 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
Rear View Camera and Monitor. cooperhawk General Motorhome Topics 19 04-18-2008 04:10 PM
