Old 06-05-2014, 03:21 PM   #15
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I have used our local U-Haul for propane in the past, but is was a very busy and cramped place. This time I called a local propane company and got a fill-up for $3.39/gal.
- - Mike
Old 06-05-2014, 04:26 PM   #16
2005 19' Safari
GLENDALE , AZ
I filled one of our propane tanks at a Costco in Phoenix, AZ; and I think it was $2.39 per gallon, with no minimum. (Some places have a minimum charge, regardless of how little you buy.)
The attendant said that most of their business is from hot air balloons. They buy at Costco; because Costco is cheapest, and they use a lot of propane.
Old 06-05-2014, 05:05 PM   #17
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I get it from Camping World as they have 50% off days every mid-week. It last cost me $11-12 for a 30lb fill up.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-05-2014, 05:41 PM   #18
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
All very easy for you all with campers. You've got portable tanks. This message board is about the Airstream Interstate which is a Mercedes camper and our tank is permanently attached underneath the body of the van. We have to drive somewhere that they pump it in and measure it by the gallon, not weight. A little different than draggin portable tanks to a place where they may weigh the tank or they may just charge by the size of the tank.
Bikerbill is offline   Reply With Quote
Old 06-05-2014, 11:28 PM   #19
2005 19' Safari
GLENDALE , AZ
Costco sells propane by the gallon.
Old 06-06-2014, 06:05 AM   #20
Newbie
joemikeb's Avatar
Fort Worth , Texas
Maybe where you live, but not where I live.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 06-06-2014, 09:13 AM   #21
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Gas Buddy & propane
Originally Posted by AtomicNo13 View Post
Can gas buddy report LPG ?
I have the latest version of GasBuddy on my iPhone and it does not show propane.
I fill up at most any gas station I'm using to buy fuel. The procedure isn't complex or mysterious but I do watch the process closely as the tech does the fill.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 06-06-2014, 10:24 AM   #22
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I have an app called Propane Refill Station Locator on my phone. It displays a map showing your location and nearby propane refill stations.
Old 06-06-2014, 10:43 AM   #23
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
I pull into costco before every trip an top off my propane
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 06-06-2014, 10:54 AM   #24
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Oops, hit the send button. Anyway I pull into Costco they check the air in all my tires and then I top off my propane ($2.29 a week ago). If you have 2 30# tanks like I do, you shouldn't have to refill unless you're running the heater non stop. I can go 4 weeks on mine with normal use. If you fill before or after each trip you shouldn't have to worry about unless you're on looong trip or full timing.
Old 06-06-2014, 11:26 PM   #25
2012 Interstate Coach
norman , Oklahoma
Unfortunately in the Interstates our generators run on propane and with the roof top air running off of the generator the propane tank goes form full to empty in about 36 hours of run time in my experience. Not very convenient. Worst part is trying to find a propane fill station outside of business hours. I wish there was an online propane dealer directory but I've never found one. Better yet I wish we had diesel generators so we could fill up anytime anywhere.
russ240 is offline   Reply With Quote
Old 06-06-2014, 11:52 PM   #26
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
My local Costcos do not sell propane, but I will ask next time I fuel up: maybe they do at selected locations. I go to my local rental yard, I think it was over $4/gallon last time. Portable tanks go to the hardware store for an exchange.
OT: Costco formulates their own gasoline so it meets top tier standards; wish they had diesel for my other set of wheels.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 06-07-2014, 04:45 AM   #27
Figment of My Imagination
Protagonist's Avatar
They add five times the EPA minimum required amount of "deposit control" additives; otherwise they buy from local distributors in the region where the store is located. I wouldn't exactly call that "formulating their own." It's about the same as Chevron gasoline with Techron in terms of quality.
Back on topic, since I don't shop at Costco, I'd have to first become a member in order to buy their propane. I don't think I use enough propane for the cost of the membership PLUS the cost of the propane to be cheaper than the cost of propane elsewhere. But it's probably a good deal for someone who is already a member and shops there anyway.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-07-2014, 07:44 AM   #28
BikerBill
And Costco is not in EVERY part to the USA. Here in the Lehigh Valley of PA there is still a battle to let Costco in. They want to be here but they don't want to pay all the taxes so they're trying to get local municipalities to pay some of their taxes for the next 10 years. And it looks like it will happen. Now it'll be 2016 'till its built and opened. Then I along with the multitudes of others can pay a premium to be allowed to ship there.
Warranty-Service Bias or "You're a Nuisance if You Didn't Buy Your Trailer Here"? Fly at Night Our Community 17 04-27-2015 06:41 AM
Thank you! Thank you! Thank you! littlebird Winter Living 0 03-18-2014 07:48 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Would you/did you buy it? Breakaway switch joatmon Brakes & Brake Controllers 3 05-11-2005 11:57 AM
