Old 09-27-2014, 07:38 AM   #15
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
Had a brand new Worthington 20# that the check valve/ OPD stuck. I'd just finished polishing so they looked really good. The propane guy flipped it upside down and banged it a couple of times on the ground. He stopped when I let out a "That was my Christmas gift!" it filled fine after that. I'd go with Andy's approach.
Good luck,
Roy
64airstream is offline   Reply With Quote
Old 09-27-2014, 07:54 AM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Just had a mental flash of the propane filler flipping the OP's four-ton Airstream Interstate upside down and banging it on the ground to shake loose the valve! Too funny!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-27-2014, 08:51 AM   #17
2012 30' Classic
Homosassa , Florida
I would just get a new valve changed by a certified dealer, have the tank inspected and move on. If it won't take propane I would stop immediately and get it fixed properly. No boom is a good thing.
Tater is offline   Reply With Quote
Old 09-27-2014, 10:37 AM   #18
mefly2's Avatar
2015 25' FB Eddie Bauer
Just what I expressed earlier; +1 for Tater
Old 09-28-2014, 06:13 AM   #19
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Interesting that most of the replies come from Airstream TRAVEL TRAILER people. This post started about an underbody permanently mounted horizontal propane tank. Slightly different from the travel trailer kind that can be removed and easily looked at and worked on.
Bikerbill is offline   Reply With Quote
Old 09-28-2014, 07:37 AM   #20
HowieE's Avatar
Princeton , New Jersey
Images: 12
The convenience of access does not change the characteristics of the valve in question. The government had this great idea that we should all have a valve that failed more often then the older valve. That is progress.
2004 Excursion 4x4
Old 09-28-2014, 08:37 AM   #21
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
BikerBill is right: Fixed-mount horizontal cylinders as found on motorhomes are completely different from the removable cylinders found on towables, just starting with the valves, which are wholly different from one another and require different connectors at the propane filler's side as well.
As far as the government is concerned, there is no federal rule on the valves for these RV cylinders. The valves are from recommended designs from either the American Society of Mechanical Engineers (ASME) or the National Fire Protection Association (NFPA). The latter organization is the one that first recommended the use of OPD valves on the vertical cylinders; it was the manufacturers of new cylinders as well as the individual states -- and not the federal government -- that adopted this recommendation (or not).
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 09-28-2014, 09:10 AM   #22
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Last summer, I'd posted a link on our FB page to a site with a nice cut-out view of a propane cylinder on a RoadTrek. Took me a while to go back through and locate the link! Anyway, I assume these are pretty much like the tanks on Interstates. (It's not as if Airstream designs, builds and installs its own special tanks.)
The Innards of your RV Propane Tank | Roadtreking
Lynn
WBCCI 21043
Old 09-28-2014, 09:31 AM   #23
Gainesville , Florida
Great link. When we had our interstate there were places that couldn't or wouldn't fill the propane. Our AS dealer said that was because these places used improperly trained workers. There was some kind of valve behind the tank that had to be used to properly fill. One particular KOA in New Mexico told me the tank couldn't be filled because the design was flawed and dangerous. What an idiot. Got it filled when I got home with no problem at the AS dealer. Never had a problem except when we were on the road somewhere. Even the local gas stations here in Fl could fill it with an adapter with no problems. Get out west and it seemed no one had a clue. This was just one other minor thing amongst many that caused me to sell my interstate. The vehicle was fine, just that one except AS or a large RV dealer could do anything with it. Mine was an 06 I believe. I understand now that since b vans are more common that a lot of the problems we had no longer exist. Jim
Old 09-28-2014, 04:46 PM   #24
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Lynn
Thanks for posting that Roadtrek link. The main difference on the Interstate is the main fill connector and bleed valve are mounted remotely for the tank by long hoses. The tank is on the drivers side between the wheels and the fill panel is on the passenger side right behind the rear tires. In my view this is a terrible location and many owners on this forum, including myself, have ripped off the fittings on this panel during normal driving around potholes or curbs. I intend to file a complaint on this design to NTHSA.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 09-28-2014, 05:19 PM   #25
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
I've seen that kind of remote location on a good number of motorhomes, mostly on upper-end units of varying lengths. It's a little unusual, but not unique at all.
Lynn
- - Mike
WBCCI 21043
Old 09-28-2014, 06:23 PM   #26
New Orleans is the pothole capital of the free world, but I've never had a problem with damaging the propane fill port or even the black plastic cover, except once when I almost backed it into a curb that was about a quarter-inch too tall for the unit. Fortunately I remembered at the last moment and got out to check the clearance before I backed the rest of the way in.
Mounting it in a body cutout right below the floor level would probably be better than putting it underneath the edge of the body. Only thing is, the door to the cutout couldn't have a keyed lock; by regulation, the solenoid has to be readily accessible to firefighters. Airstream is unlikely to offer a retrofit package to move the fill ports; they best anyone could hope for is that they would relocate them for new models.
WBCCI #1105
TAC LA-4
Old 09-28-2014, 06:40 PM   #27
Fulton , Maryland
Lynn
Sure it's not unique. But I doubt any of the motorhomes you are talking about have the propane fill panel located right behind the rear wheel only 6 inches from the ground. It's the lowest point on my van. See attached diagram, item 4, for location on the Interstates.
Name:	Interstate Exterior Curbside.jpg
- - Mike
Old 09-28-2014, 06:49 PM   #28
Fulton , Maryland
No need for a body cut-out. They could just raise it about 4 inches into the plastic lower trim molding and make a cover out of the existing molding. I'd like to make this mod myself but I have not looked at what it would take to disconnect the fill hose and not get propane leaking all over -- nasty! Maybe I could have the tank emptied. The mounting panel is just riveted to the Sprinter inside body panel behind the wheel.
It may have needed to be as low as it is on early Interstates that had the vertically stacked battery box right above it.
- - Mike
Water Tank won't fill from outside map-it Fresh Water Systems 6 08-10-2014 10:11 PM
2010 interstate LPG won't fill despite being empty lanzjx2 Airstream Motorhome Forums 4 05-29-2014 11:57 AM
Thetford Aqua Magic pedal push won't fill bowl. handn Sinks, Showers & Toilets 3 02-04-2012 08:07 AM
Propane re-fill denied kfrere LP Gas, Piping, Tanks & Regulators 5 09-20-2011 12:43 PM
'93 Limited 34' Water Heater won't fill GeraldVG Fresh Water Systems 5 10-23-2008 05:59 AM
