Old 05-23-2019, 09:29 AM   #1
2009 22' Interstate
Louisville , Home is where you park it
Project Alert! 09 Interstate Fire sale! Adventure VAN DIY
So I am super pumped on this purchase. I picked up a 2009 Airstream Interstate that only has 23,500 miles on it. The unit had an electrical fire in the back right rear corner. Apparently, there was a recall or TSB on something with the house battery cover. The short story is the seat belt for the rear bench in the back fell on top of the house battery and arced causing a fire. The previous owners got the fire out fairly quickly so that is a plus. Additionally, they had a fire restoration company clean all the fabrics, seats, etc.. so there is zero smoke smell in the unit.
Anyhow everything that burned in the back I would have taken out because I am going to build a platform bed at chest height and the bottom will be partitioned off for mountain bikes, road bikes, snowboards, toys, etc... Everything from the bathroom and galley forward I will keep the factory floorplan with one adjustment. I am relocating the jackknife sofa that was behind the galley and moving it in front of the galley instead of using the 4th bucket seat there.
The electric panel was cut out of the van so I have run all new 110v wiring and relocated the panel behind the bathroom compartment which is next to all the 12v wiring. I have tested most things like the lights, roof vent van other items independently and everything works so far.
Some questions and items I need right now are:
The drivers side, rear, T-Vent window. The bottom left glass is broken out. I can't find an individual pane or crank hardware anywhere. Also some of the internal framing is bent, so looking for a place to order random parts as opposed to an entire window assembly.
In the right rear, did the fire restoration company cut that hole in the floor, or was there a metal drop in piece, that two house batteries were sitting in flush with the floor?
Thanks in adVANce!
Here are some pictures starting at the first time I saw it up to today.
ID:	341433   Click image for larger version
ID:	341435   Click image for larger version
ID:	341437   Click image for larger version
ID:	341439   Click image for larger version
ID:	341441   Click image for larger version
Brandon is offline   Reply With Quote
Old 05-23-2019, 01:54 PM   #2
2011 Interstate Coach
Muskogee , Oklahoma
Congratulation on purchasing the vehicle that probably launched a recall campaign!
To answer your question, you will not be able to replace just that assembly unless you find a surplus window somewhere, which is likely not going to be the case. The entire window can be bought here.
The hole was where the original battery box poked through the floor. A very bad design. Get a machine shop to cut you a steel plate and bolt it back in place to close it off.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 05-23-2019, 02:53 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Thanks in adVANce!
Welcome to AIRFORUMS!!
Wow - that looks like a great project. I assume you got it for a good price.
There were three recalls on the 2009 Airstream Interstate. Here is list from NHTSA web site...
https://www.nhtsa.gov/vehicle/2009/A...RSTATE#recalls
Your will notice that NHTSA Campaign Number: 12V596000, Sofa Components may Contact Electrical Components is the one that caused the fire in your van. It wasn't the battery, but the inverter and other wires under the rear lounge seat. Your van may even have been one that led to the recall as gmillerok1 mentioned.
I'm attaching a copy of the three recalls that apply to 2009 Interstates for your convenience. The oldest one; NHTSA Campaign Number 08V334000, only applies to 14 vehicles so it might not apply to your van.
Regarding the broken drivers side, rear, T-Vent window: You can get parts from Airstream, but they will be expensive and might be challenging depending on how many part you need. If you need more than the T-vent glass it might be easier to just get a new window as gmillerok1 said.
If it is a CR Laurence window parts and complete windows are available from distributors at less than half of what Airstream will charge you. I had one of my rear T-vent windows shatter last year. I communicated with CR Laurence directly to get the part number, but they don't sell to retail customers. I ended up getting the replacement glass window from DK Hardware Supply in Florida. They can be reached at 877-509-8040. I worked with Gisel Depestre who was very helpful. They also carry full windows and might even have one in stock.
For a pricing example the glass with shipping was $88.99 plus shipping for total of $118.77. Airstream dealer wanted $173.09 plus shipping. They have to be special ordered through Airstream from CR Laurence.
Hope this helps and good luck with your new van.
- - Mike
Old 05-23-2019, 05:42 PM   #4
2012 Avenue Coach
Corpus Christi , Texas
Enjoy your re-build and get it just like you like it.
After all, notorious forum members like Wachuko, Interblog, Pahaska, and Alex AVI have ripped apart and modifed their perfectly good Interstates. So why can't you.
Sorry, I couldn't help it.
rowiebowie is offline   Reply With Quote
Old 05-24-2019, 08:58 AM   #5
2009 22' Interstate
Thanks guys! The previous owner stated they never got a recall notice and it caught fire in the summer of 2017. Anyhow, yes the window is an Atwood and from my research, i reached out to CR Laurence but no reply yet. I will try your guys in Florida once i get the part number.
Thanks for the recall links. I do have the air bag one outstanding, so looks like we are headed to Mercedes for a visit...
As far as the hole where the battery tray was, I was going to do that repair originally, but after looking at it, I was going to add two Aux batteries under the hood and then weld up a deeper tray in that right rear corner that would hold two batteries below floor height. Any reason/advice why I would not want to do that?
Old 05-24-2019, 04:21 PM   #6
Fulton , Maryland
Was previous owner the original owner? If not then unless they notified Airstream about their ownership they would not get recalls.
If you have Atwood windows then getting parts is probably not possible. You will need a new window. Atwood sold out their Sprinter windows to CR Laurence in 2009.
Here is link to DK Hardware page on Sprinter windows.
https://www.dkhardware.com/van-windows_ZC5M0P1.html
I'm attaching the CR Laurence info sheet on Sprinter windows that has all the part numbers of window assemblies. The Driver Side Rear Quarter Panel Window is Part Number FW623L.
- - Mike
Old 05-25-2019, 05:19 AM   #7
Welcome to the forum, Brandon! I'm one of the aforesaid notorious forum members, although my less-frequently-posting, mechanical engineer husband LB_3 is largely the brains of our operation, at least in terms of high tech. I'm more like chief cook and bottle-washer, the person who develops strategic goals that he then has to execute.
Actually that's not entirely true. I execute a lot of "van live-ability" projects without his assistance. But my husband is responsible for the core systems such as our solar-lithium retrofit.
Anyway, please continue to post your progress. We have not had a restoration project similar to yours on this forum to date.
Old 05-25-2019, 02:38 PM   #8
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
Congratulations! Your project is off to a good start. I look forward to seeing your modifications. I like the idea of a permanent bed. Setting up a jack knife sofa gets old quickly.
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 05-29-2019, 11:49 AM   #9
2009 22' Interstate
Thanks for the information. I was told by CR Laurence you can order just the replacement parts. However you have to get the right rep on the line because it's in their internal replacement parts catalog... I was able to get all the numbers and having a dealer get me a price quote.
Thanks! It is coming along nicely. Will update in a week or so with the current progress and will maybe get your husbands advice on solar options, and yours on other van live-ability projects lol.
Lisa
Thanks!
Old 06-17-2019, 03:49 PM   #10
2009 22' Interstate
Quick update of the conversion!
Got the electrical panels relocated from under the burnt bench over behind the shower/bath.
Ran all new 110 Romex.
Made a new compartment for electrical panels, transfer switch, Inverter, batt separator and 4 house batteries all in the passenger side rear.
Moved that jacknife in front of the kitchen galley.
Made a new floor to seal off where OEM Battery Box went.
Took out 3 windows that had some leaks, cleaned the gaskets and used RTV silicone just for extra insurance.
Pictures post 1 of 2.
ID:	343625   Click image for larger version
ID:	343627   Click image for larger version
ID:	343629   Click image for larger version
ID:	343631   Click image for larger version
ID:	343633   Click image for larger version
Old 06-17-2019, 03:51 PM   #11
2009 22' Interstate
Pictures 2 of 2
Forget to mention drove it from Kentucky to Southern California and spent 3 days buffing the entire vehicle, polishing the wheels, and mounted up some BFG All Terrains for future AdVanturing!
ID:	343635   Click image for larger version
ID:	343637   Click image for larger version
ID:	343639   Click image for larger version
Old 06-17-2019, 04:27 PM   #12
Fulton , Maryland
Nice progress! Looking forward to seeing the platform bed setup.
- - Mike
Old 06-17-2019, 07:49 PM   #13
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Can you share full specs on the tires?
Are those able to deal with the weight of the AI??
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is online now   Reply With Quote
Old 06-17-2019, 09:15 PM   #14
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
BRANDON - Good work, the type that some people who can't do it themselves may want to pay for to have done
What was the reason to move the rear jackknife in lieu of the original swivel captain's chair? The captain's chair affords more flexibility and better seatbelted position and it can swivel to face sideways. Now, unless you know you will never have 4 people and you have the other captain's also removed and replaced with other jackknife which then can flatten out to be a narrow front bed for the occasional extra sleeper. I sometimes do that in the rear when I am solo and too much trouble to power down the rear couch. I fit sideways using both jacknifes as my bed.
I am a stickler for tire profiles and tire stance. Those BFG's look awesome in the pics. Yes, as WACHUKO asked, pls. share the size you used so we can pull up if it is a proper option for when we are ready for tire replacement. How was the drive to So.Cal. on them? Aggressive lugs - how was the noise & comfort level compared to OEM? MPG? I did have BFG All Terrain T/A's many years ago on a Ford Econoline conversion but that technology & composition & pattern profile was way different than these new ones. The ones you have look fantastic on it if I was only judging by looks alone.
Alex AVI is offline   Reply With Quote
Mercedes Van Executive Van Airstream Interstate eBay Watch Airstreams on eBay 0 05-28-2012 02:20 PM
Mercedes Van Executive Van Airstream Interstate eBay Watch Airstreams on eBay 0 05-20-2012 10:50 AM
Mercedes Van Executive Van Airstream Interstate eBay Watch Airstreams on eBay 0 05-14-2012 05:30 AM
FIRE! Electrical Short and Slide-Out Controller Fire rjd Electronics & Connectivity 10 07-24-2009 07:47 AM
FiRe, FiRe, FIRE, in the AiRsTrEaM!!!! TheBigRedTruck On The Road... 41 12-13-2008 10:29 PM
