Old 04-07-2018, 03:56 PM   #1
2012 Interstate Coach
Wayne , Nebraska
Question Project 2000 step source
Thought I had my step problem solved (motor fried) with a new motor only to find that it was totally different!!
Have tried doing a search on the internet for project 2000 steps or just the motor and am only able to find ones in Italy or Europe!
Is there anyone in the states I can get just the motor or the whole step if need be? Have tried contacting Airstream and have yet to get a reply.
Ron
Ron W is offline   Reply With Quote
Old 04-09-2018, 03:15 PM   #2
Wayne , Nebraska
Exclamation Project 2K step
Just got an answer from Airstream, "contact a dealer, should be able to get you just the motor". "Need to contact the dealer for cost". "The part number for the motor only is 512450-103 MOTOR ONLY FOR P2K STEP 512450"
Am going to contact dealer in Des Moines Iowa
Ron
Old 04-10-2018, 06:26 PM   #3
2015 Interstate Grand Tour
Hilliard , Ohio
If step is not working, pics show where wiring controller is located inside cabinet. Also can access the wiring to switch out the door maginet and wiring. Screen door had to be fully removed to gain access to then panel.
MWallOhio is offline   Reply With Quote
Old 05-06-2018, 01:55 PM   #4
Wayne , Nebraska
Question Step motor
Got a replacement motor, got it installed, now no power to it!
Fuse OK, relay operates, but no power to the motor. Is there something in- between the relay and the motor besides the switches (door and step)?
I am flying this blind (do have some electrical trouble shooting experience),
a wiring diagram should would be helpful!
Ron
Old 05-20-2018, 07:15 AM   #5
Wayne , Nebraska
Smile Step Motor
Found my problem, burned "open" "land" on the controller PC board! Got that repaired and am ready to hit the road!
Ron
Old 05-20-2018, 09:48 AM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Ron
Thank letting us know you solved the problem. Was this done by a dealer?
- - Mike
Old 05-21-2018, 06:08 AM   #7
Wayne , Nebraska
Step source
No, did it myself. Have had to repair may a radio or power supply with the same problem.
Was going to take pictures, but put it all together before I thought about it!
Old 08-02-2018, 02:39 PM   #8
Dalwyn's Avatar
Southaven , Mississippi
I'm having problems with the step in my 2015 GT, sometimes it works, sometimes it doesn't. I have had it into the dealership twice to have it fixed, the last time the tech put stronger magnets on, not sure why.
My question is there another type of step that would work better than the Project 2000?
I am considering just having the electric disconnected and operating it manually if I can't find a reliable solution.
Any recommendations would be greatly appreciated.
Regards
Dalwyn
Dalwyn is offline   Reply With Quote
Old 08-02-2018, 03:36 PM   #9
Lake Oswego , Oregon
Just this week my step was binding, not fully closing unless we pushed on it when it was retracting. Then it wouldn’t come out but then it finally did with some coaxing while repeatedly closing and opening the sliding door. I got on the ground and could see there was a pebble stuck above the sheet metal that is the top portion of the step enclosure. It was pressing down on the sheet metal which was hanging up the step ever so slightly.
Removed stone. Used a screwdriver to pry up on that enclosure top to try and return it to its proper position.
Fixed. I was lucky. No fuse had blown and no motor burned out.
Tronadora is offline   Reply With Quote
Old 08-02-2018, 07:57 PM   #10
mrgolf's Avatar
2017 Interstate Grand Tour Ext
Charleston , South Carolina
I also am having trouble with the Project 2000 step on my 2017 Interstate. I spoke to Airstream today in Ohio and they offered helpful information regarding the step setup via the attachments I've provided here. My problem is that the step works sometimes fully and sometimes only partial movement. The fuse and the magnet are not the issue. Airstream service believes the step needs to be lubricated even though it is only 2 years old. One of the attachments says to only use grease to lubricate, but the tech person said his colleagues at the factory have used silicone spray lubricant effectively on the step. The attachments provide pretty good explanation of the way in which the step is attached, so I will give it a try. Perhaps these attachments will be helpful to others who have challenges with the Project 2000.
File Type: pdf Thule to Project 2000 Step Changeout.pdf (1.37 MB, 55 views)
mrgolf is offline   Reply With Quote
Old 08-03-2018, 05:31 AM   #11
Dalwyn's Avatar
Thanks mrgolf, appreciate the info.
Dalwyn
Old 08-03-2018, 05:24 PM   #12
Fulton , Maryland
MRGOLF - good info thanks for posting.
- - Mike
Old 03-16-2019, 08:09 AM   #13
GREAT ESCAPES
scott.semone's Avatar
2014 Interstate Ext. Coach
Tenafly , New Jersey
Side Step Interstate Project 2000 Not Working Properly
I'm currently have a weird issue with the side step on our 2017 Interstate Grand Tour Tommy Bahama; where it doesn't open when I open the sliding side door, however it opens only after I close the sliding side door?
Once it is out, it doesn't retract when I shut the sliding side door; almost as if the "HOLD" switch is activated? In fact, it will only retract if I start the vehicle via the ignition. It's almost like the motor is out of sync in terms of it thinking it is retracted vs extended???
I did see that there is a "reset" procedure within the owners manual, however it didn't work at least the way I tried running through it. The weather is a little warmer today, so I'm planning on spending sometime troubleshooting it - however I wanted to see if anyone had experienced this same problem?
Thank you to the user that posted the schematics which AIRSTREAM Ohio sent out, this is extremely helpful in addition to supplement the electrical wiring already within the owners manual.
scott.semone is offline   Reply With Quote
Old 03-16-2019, 08:58 PM   #14
Raymond , Iowa
I remember having a similar problem. I started and stopped the engine, cycled the step hold switch, and opened and closed the sliding door. I don't remember the order that I did those three things, but some combination of them fixed it.
Titus is offline   Reply With Quote
Project 2000 Retractable Step MN CakeEater Sprinter and B-van Forum 19 05-28-2018 03:08 PM
Fiamma F65 Eagle and Project 2000 Step jim.waters Sprinter and B-van Forum 5 11-02-2017 07:43 AM
Project-2000 Electric Single Step jamming felixkagi Sprinter and B-van Forum 0 07-19-2017 08:36 AM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
