Old 11-22-2015, 08:22 AM   #15
2015 Interstate Ext. Coach
Boynton Beach , Florida
I removed the connection on the relay so our step opens while the engine is running when we open the sliding door. Found the tutorial here on this forum just search. It makes a huge difference and should bet set this way from the factory in my opinion. Also need to disconnect the relay alarm for the step. This alarm will not affect the awning alarm on 2015 models.
CraigL is offline   Reply With Quote
Old 11-22-2015, 03:50 PM   #16
nesoutlook's Avatar
2013 Interstate Coach
Boca Raton , Florida
Where is this relay located? I can't tell you how many times I wished the step was out when the engine was running. I am surprised I haven't twisted my angle.
nesoutlook is offline   Reply With Quote
Old 11-23-2015, 06:38 PM   #17
2012 Interstate Coach
Elk River , Minnesota
Since I see my original post has gotten some attention. I should probably follow up with what I did to address my original issue.
I ended up taking it to a local mechanic that does side work on rv's. He took the step off and opened it up and found the gears stripped. In his humble opinion, the mechanical parts inside the step needed to be "beefed up"!
After finding out the cost of a new step, he decided to machine new parts and re-assemble the box. It ended up costing me about half of what a new step would've been and I believe I have a nicer set up now!
MN CakeEater is offline   Reply With Quote
Old 03-28-2018, 04:35 PM   #18
Fort Wayne , Indiana
Hello, the retractable step recently stopped working on my 2014 Interstate. I could hear the motor running itís cycle but no movement of step. I could manually push step in. I decided to investigate as it is a challenge to find a good service outlet this time of year in SE FL. I dropped the step assembly out, drilled out the rivots that hold the step case together and found the gear loose on motor. Tighten Allen set screw on motor shaft and reassembled. I must add, this project was a 3 hour project. But I had motivation to fix it when I heard a new step assembly is $800.
Text me if you have questions. 260-433-9300
Rvorderman is offline   Reply With Quote
Old 05-19-2018, 09:03 PM   #19
2018 Tommy Bahama Interstate
Huntington Beach , CA
Just FYI, the retractable step plug is located behind the drawers under the microwave on the 2018 AI. I was looking for the propane wire and there it was!
Boom23 is offline   Reply With Quote
Retractable electrical power cord replacement Excella CM Electrical - Systems, Generators, Batteries & Solar 4 07-19-2013 11:30 AM
Actuating Arm for Retractable Step(1988-345) robersonwill Classic Motorhomes 3 06-22-2012 07:44 AM
retractable cables gregcarleton General Interior Topics 25 08-16-2007 05:06 PM
Need 30 amp retractable GlenCoombe General Motorhome Topics 12 01-10-2006 05:35 PM
Retractable TV antenna jack simons Audio, Video & TV 1 11-01-2003 09:55 AM
