Old 11-21-2015, 11:09 PM   #1
2014 Interstate Ext. Coach
Monroe , Washington
Problems with Carbon Monoxide detector on 2014.5 Interstate
Is everyone having problems with the Carbon Monoxide detector???
I'm on my fourth?? one in 18 months. They last a couple or three months, and then die. When they die, they beep every 20 seconds, which is their failure mode. Actually, it's not a beep or a chirp, it's a full-on 1 second alarm every 20 seconds. We bought a $15 battery-operated detector from Home Depot, which we use after the Airstream one has died and before I can get it replaced by the dealer (under warranty).
Now, this might be related to the disaster that is my van's electrical system, but for some reason, this Interstate eats these detectors. That's four I've had, I think, in the van's 18-month life. The dealer just keeps replacing them.
Is this common? Anybody else?
coder is offline   Reply With Quote
Old 11-21-2015, 11:13 PM   #2
Monroe , Washington
P.S. After the first two or three died, I completely unplug it, remove its battery, and store it in the drawer when the van is not in use.
Old 11-22-2015, 03:22 AM   #3
UKDUDE's Avatar
Sedona , Arizona
Mine failed once, and the dealer replaced it with a different model from the same manufacturer. Been fine so far.
Old 11-22-2015, 06:49 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
On my 2012 model, the detector isn't hardwired to the house system, it's battery-only, and works just fine going on four years as long as I replace the batteries annually. If all else fails, you can replace your hardwired-with-battery-backup detector with a battery-only model, and that may help.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 11-22-2015, 08:12 PM   #5
FunWaggin's Avatar
Raleigh , North Carolina
We have a 2014.5 and our CO2 detector failed almost immediately. Ordered same model from Amazon and it has been fine for almost a year now.
FunWaggin'
FunWaggin is offline   Reply With Quote
Old 01-01-2016, 02:53 PM   #6
2013 23' Flying Cloud
Bainbridge Island , Washington
We have a 2013 Flying Cloud 23D. I want to replace the 9V battery in my battery-only CO2 detector (made by Costar) however I can't get it off the wall mount. The directions and the printing on the face of the unit both indicate which way to turn it to remove it. However I've tried several times and I am convinced if I twist harder I am going to break something.
Is there a secret I should know?
2001 BMW X5 4.4i (TV)
2004 BMW 330/Ci 6-spd
2005 BWM R1200ST
1977 Cessna C177B
warmrain is offline   Reply With Quote
Old 01-01-2016, 03:36 PM   #7
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
You might check for either a removable locking pin or a release clip that needs to be depressed to allow it to rotate.
By any chance do you have any instructions for it or if not, check the web.
Old 01-01-2016, 03:40 PM   #8
Gainesville , Florida
Locking pin.
Old 01-02-2016, 10:45 AM   #9
Thank you both, I found the looking pin only by standing on the bed, LOL. It's mounted that high on the wall. All is well!
2005 BWM R1200ST
1977 Cessna C177B
Old 01-02-2016, 11:26 AM   #10
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I had this problem and just did a reset that is listed on the instructions.No more beep
Combination Carbon Monoxide and Smoke Detector Recall PaulnGina Off Topic Forum 4 02-14-2015 08:32 PM
Carbon monoxide detector/alarm replacement Alphonse General Repair Forum 6 02-04-2013 06:43 AM
Carbon Monoxide Detector and strange smell frscott Furnaces, Heaters, Fireplaces & Air Conditioning 11 10-19-2009 09:22 AM
Carbon Monoxide Detector Silver Threads LP Gas, Piping, Tanks & Regulators 29 06-20-2007 12:24 AM
Carbon monoxide detector...mystery story drcharles2 General Interior Topics 9 11-21-2005 02:50 PM
