06-09-2016, 11:48 AM
Galveston
Problem with Onan Generator
Having an issue with our Onan generator. Took the 2013 AI back to the dealer to have some tiny things repaired and discovered the generator could not start. They diagnosed the starter needs to be replaced but said we need to take it to a Onan dealer. We live close to Houston - does anyone know a place we should use for this work??
Just taking the AI out of storage - where it has been sitting since October. Maybe we should have been exercising it every month or so. Just hard to do when it's 45 miles away. Darn it.
06-09-2016, 11:50 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Doubt that not exercising the starter made ot fail.
06-09-2016, 12:19 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I have ten bucks that says it wasn't actually the starter that failed.
Superat stultitia.
06-09-2016, 12:23 PM
Overland Adventurer
2009 34' Panamerica
Telluride
I was thinking that myself.....
Troubleshooting skills are at an all time low.
06-09-2016, 01:06 PM
1972 31' Sovereign
Benton
, Arkansas
Yep.
Not to say that Onan wont change the starter, but I am betting that they find another problem "also".
Superat stultitia.
06-09-2016, 01:24 PM
2014 Interstate Ext. Coach
Sedona
Did you check the Cummins Onan website for local dealers? I would probably choose one of them.
http://power.cummins.com/sales-service-locator
06-09-2016, 01:32 PM
2024 Interstate 19
Fulton
, Maryland
What are the symptoms? Does it crank at all? Is your battery voltage up above 12V?
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
06-09-2016, 02:00 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
The Onan website includes a dealer locator. I'm pretty sure there is at least one in the Houston area.
06-09-2016, 02:35 PM
Adventure Gypsy
2015 Interstate Grand Tour
Phoenix
Possible link
Here is a link to a service in Houston that should be able to help with Cummins Onan generator service and repair.
http://www.funroads.com/coachcare/houston/
Hope this helps. Let me know, as I have one here in Phoenix that I would consider using.
Kenneth
2015 AI Grand Tour on 2014 MB Sprinter
06-09-2016, 02:50 PM
League City
I looked it up. FWIW, that is not a location in which I personally would leave my Interstate unless the vendor would agree to store it in a warehouse and they had on-site security. One or two of my clients in that area keep their gates manned at all times.
06-09-2016, 04:49 PM
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark
, Delaware
I had a similar problem with my 2007 AI. The generator wouldn't start the day I brought it home from the dealer. Multiple trips to Colonial Airstream until they decided I needed to go to an Onan service center. Took it to Camping World who pulled the generator, kept if for over two weeks, and then charged me over $400 to reinstall the brand new generator. They said it was installed improperly by Airstream.
Multiple letters and emails to Colonial were fruitless. Finally I called Airstream and my money was refunded. It took over two years for me to get my money back.
06-09-2016, 08:20 PM
2024 Interstate 19
Fulton
, Maryland
Wow - glad you got reimbursed by Airstream.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
07-19-2016, 04:12 AM
Boca Raton
I'm getting low oil pressure warning when run generator on a sloped angle But runs ok when level.
Just low oil??
And what oil recommended if so?
07-19-2016, 07:06 AM
2009 Interstate
Bethesda
, Maryland
+1 on checking the oil level which won't allow a start if the level is too low. Possible they ran the starter too long when the manual says not to run it for long periods. Even a slightly low oil level will allow the Onan to start but stall when you add a load like the AC.
2009 Airstream Interstate
07-19-2016, 09:20 AM
2015 Interstate Ext. Coach
San Diego
Just low oil??
I didn't anticpate any freezing temperatures and used Pennzoil 30w when I changed mine.
07-19-2016, 06:31 PM
Boca Raton
I'm pretty sure it's low oil. But the question is what oil was used when it was last changed.
Onan doesn't recommend mixing oils.
07-19-2016, 06:36 PM
Boca Raton
07-28-2016, 11:24 AM
Boca Raton
Yup
Low oil
A few syringe squirts of Onamax 15-40 did the trick.
07-28-2016, 12:26 PM
1987 Avion 34W owner
Good Ol'
, USA
I'm guessing that Onamax oil is expensive, like everything Onan?
Tractor Supply Co.'s Traveller brand of 15W-40 oil is service rating CJ-4/SN ( high service rating ) and is usually at a very good price.
Just passing that along if you'd like a very good oil at a reasonable price.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
I this great country!!!!
1987 Avion 34W
07-28-2016, 02:05 PM
Boca Raton
PaulnGina
1987 Avion 34W
Thanks PaulnGina,
Actually it was more reasonable than I thought. $6 quart plus tax.
