Old 04-19-2017, 01:16 PM   #1
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Preplexing TST TPMS Issue
First trip this year and the outer right rear tire sensor did not work. I changed the battery, sensor still not working, moved the sensor on that tire to the front tire sensor is working. So the problem does not appear to be the sensor. Also, this sensor has worked on the rear outer tire since installed in Jan 2016. Any ideas as to what the problem could be?
Dalwyn
Dalwyn is offline   Reply With Quote
Old 04-19-2017, 01:44 PM   #2
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
Has anything changed in that part of your coach? For example, have you installed a WiFi router, cell signal booster, etc. anywhere near there? I ask because based on your description, it sounds like it might be a RF signal issue and something is interfering with that sensor (which just happens to be the farthest away from your receiver).
FlyFishinRVr is offline   Reply With Quote
Old 04-19-2017, 02:26 PM   #3
Dalwyn's Avatar
No changes have been made to the RV. All other sensors are working fine and the inner wheel on the right side is working only the outer wheel is not.
Dalwyn
Old 04-19-2017, 02:55 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
When you removed the sensor from the rear tire did you hear air escape as you did. I ask this to determine that the sensor was in fact turned on while on that tire. Sensors do not transmit without seeing pressure.
2004 Excursion 4x4
Old 04-19-2017, 04:22 PM   #5
Dalwyn's Avatar
Yes, air did escape when removing. Manually checked the air pressure and it is registering ok. Appreciate the comment.
Dalwyn
Old 04-19-2017, 05:50 PM   #6
2011 Interstate Coach
Evansville , Indiana
One of the reasons I purchased a TST TPMS was due to the numerous comments of excellent customer service. Although I have not needed to contact them with my unit, I'll bet they'll take good care of you if give them a call.
BurntAsphalt is offline   Reply With Quote
Old 04-19-2017, 06:04 PM   #7
MikeandCarol's Avatar
Fair Oaks Ranch , Texas
I second this suggestion. I've had nothing but excellent customer service from them - give them a call. Mike
2016 Oliver Legacy Elite II #135
2016 Ram 1500 5.7L
MikeandCarol is offline   Reply With Quote
Old 04-19-2017, 08:14 PM   #8
Dalwyn's Avatar
I called them first and they suggested moving the sensor to another tire to see if it was a problem with the sensor. I did that and the sensor checked out fine on the other wheel. Since the problem is not the sensor but something on that particular wheel, not sure how they could help.
Dalwyn
Old 04-19-2017, 09:11 PM   #9
If the receiver doesn't pick up that tire's sensor when you hold it close to it, you could try to rule out the tire valve. Jack up that dually (or drive the inner tire up on a board) and replace the valve stem core. Of course you'll need a valve core wrench and a compressor to air the tire up.
Old 04-19-2017, 11:16 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Once one of our 6 sensors quit reporting. I replace the batteries in all sensors. One of the batteries turned out to be low voltage..
On another time, the battery contacts needed a little cleaning up...
On a third occasion the valve stem was dirty/jamming.. no airflow to the sensor but it still reported to the receiver.
We did have to add repeater because of the trailer / TV rig.
Finally, I cleared the monitor... and recalibrated / set each position. That has been 2 years now.. not a single failure...
You can certainly trust that Mike will help resolve...
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-20-2017, 05:52 AM   #11
Dalwyn's Avatar
Thanks everyone. I appreciate your suggestions and will try each one.
Dalwyn
Old 04-20-2017, 11:09 AM   #12
2017 27' International
Englewood , Colorado
I have the TST on my truck and double axle airstream. The back right sensor loses connection to the monitor on occasion. I double check to make sure all is well, then unplug and replug in the monitor. I have rotated the sensors across all 8 tires and it always the right rear. I assume it is a distance issue for me...
Tomhenritze is offline   Reply With Quote
Old 04-20-2017, 12:49 PM   #13
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I have TST on my TV and trailer. It took a couple times through the set-up to get it working right, but since then it has been a champ. I had a very similar frustration. I just went through the set-up again and it all came together. I have a full size truck and a 28' AS with back-up camera's and other electronics running and don't seem to have an issue. I regularly check my tire pressure before and during trips so I remove and replace sensor without a problem. It sometimes takes a bit to get them all synchronized with the monitor, so I try to remember to turn on the monitor 15-30 minutes before I get rolling. When I was having problems initially customer service sent me out a new monitor to see if that was it but as I said, it wasn't the issue. Try going through the set-up again.
VaTravelers is offline   Reply With Quote
Old 04-20-2017, 01:10 PM   #14
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I had the same type of issue - I added a repeater inside of the propane tank cover and problem went away. When talking to the manufacturer they told me that any type of signal could cause interference enough interrupt the TST signal. Since I was running a GPS, the wireless monitor for my camera, my cell phone on Bluetooth as well as other interference from the trucks internal electronics I am sure that was the initial issue. Here is video showing where I put it - I also added a switch and disconnect.
AStreamNerds is offline   Reply With Quote
Tst tpms mbenson1234 Our Community 30 07-05-2015 08:12 PM
Tire Minder or TST TPMS for 30' FC Beach Bum Tires 8 02-05-2015 12:25 AM
Voyager interferes with TST TPMS SteveSueMac Lights - Interior & Exterior 11 12-09-2014 08:03 AM
Tst tpms SilverEagle6 Tires 6 08-09-2014 06:22 AM
TST TPMS fit and repeater SteveSueMac Tires 6 08-17-2013 12:29 PM
