Old 09-12-2016, 12:41 AM   #1
tlundell's Avatar
2015 Interstate Ext. Coach
Los Gatos , California
Power Step Electrical
Here's a puzzler for the electrical wizards: Opened the sliding door on my 2015 Grand Tour, and the step did not come out. I assumed it might be the fuse, as had happened once before. Pulled the 15 amp fuse #10 and it looked fine. Stuck it back in the slot and I could hear the step extend on the other side. Hmmm. Suspected the fuse might be conducting intermittently, so replaced with fresh fuse. Tried again and same result. Step does not extend or retract (except when engine starts) unless I remove and reinsert the fuse. Ideas?
Tim
tlundell is offline   Reply With Quote
Old 09-12-2016, 10:24 AM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Possibly bad contacts in the fuse holder or bad wiring connection to the fuse holder. Next time, just try wiggling the fuse w/o removing it.
PS: Not a wizard yet, still working on apprentice.
Old 09-12-2016, 08:18 PM   #3
2017 Interstate Lounge Ext
- , VT, AZ, CA
Might not seem perfectly logical, but often problems like this arise from a bad ground.
don000 is offline   Reply With Quote
Old 10-21-2016, 11:47 AM   #4
tlundell's Avatar
Just for anyone who was curious about this puzzler: I have been living with the strange power step experience for the past several weeks by quickly pulling and replacing the fuse in slot 10 in order to extend or retract the step, but finally called Airstream tech support to brainstorm the problem. They got back to me very quickly with the diagnosis, though the repair is going to involve the hassle of a trip to the dealer. One of the two relays in the circuit for step operation is apparently stuck and only activates when power is cut then restored through the removal and replacement of the fuse. The responsible relay is either in the step well circuitry or in (behind, under) the kitchen cabinet.
Tim
2015 Interstate Grand Tour
WBCCI Member #5506
Old 11-01-2016, 01:18 PM   #5
2014 Interstate Coach
Corsicana , Texas
I'm having same issue with my 2014 1/2. I can manually pull steps in or out and when the sliding door is opened or closed you can hear the motor running but steps won't come out. Did you get your steps working?
aoldpiddler is offline   Reply With Quote
Old 11-01-2016, 03:23 PM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I was about to send a response that it was probably a relay - then I read your post and confirmed my suspicions. Good job!
Old 11-02-2016, 04:40 PM   #7
Beaufort , South Carolina
I am having the same problem with my 2015. I discovered the same that by pulling the 15 amp fuse the step will extend. Took the van to my dealer. All day and no one could figure it out. They thought it might be the contacts in the door but that was not it. Here is the funny thing. Three days ago everything started working correctly extending and retracting when it was suppose to VERY HAPPY. Then S___ it got stuck retracting half way. Would not do anything in or out. Started the van and it would not retract and now I had a beeping that would not quit. So I pulled the 10 amp beeping stopped. Pulled the 15 amp and put it back and still stick. Had to pull out a wrench and manually retract the step. Now it does not work at all.
Any ideas?
WBS248 is offline   Reply With Quote
Old 11-02-2016, 11:40 PM   #8
tlundell's Avatar
WBS-- Sorry that yours has gotten worse...we have lived with the inconvenience of pulling/replacing the fuse to get it extended, but have not had an issue with retraction on starting engine. Factory was quite certain that it is a relay problem, one of the two in the step motor circuit, but it will take trial and error to figure out which one. Until/unless my situation deteriorates further, I will defer the trek to the dealer until I have a couple of fixits to address. Good luck....your dealer should be able to diagnose and repair using the circuit diagram.
Tim
WBCCI Member #5506
Old 11-04-2016, 03:43 PM   #9
southjk's Avatar
midland , Texas
I've got the same problem in a 2015 GT. I've been manually pulling the step in and out as needed to avoid the insane beeping. Still haven't figured out how to stop the graveling sound of something in the step when pushed in.
southjk is offline   Reply With Quote
Old 11-04-2016, 03:44 PM   #10
southjk's Avatar
midland , Texas
Where is the fuse panel, the one in front or rear.
Old 11-04-2016, 10:56 PM   #11
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
The step 20 amp fuse is located in the Sprinter fuse panel under the driver’s seat, position F-10.
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 04:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 10:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 08:49 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 02:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 03:35 PM
