Old 11-15-2014, 10:52 AM   #1
Glamper1's Avatar
Potable water hose
Hi and thanks for helping me this past week.
I'm a new owner.
Question...
When hooking hose to city water inlet
Do I need a potable white hose?
...even if I never plan on drinking from the sink?
Glamper1 is offline   Reply With Quote
Old 11-15-2014, 11:14 AM   #2
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
DO you plan to brush your teeth, wash your hands, shower, use for cooking....? The hose is a very minor cost compared to all other expenses. I carry one plain white water hose and a heated hose for those cold trips.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 11-15-2014, 11:19 AM   #3
toskeysam's Avatar
Sorry if that earlier post seemed sarcastic...not the intent. Granted most of us grew up drinking from garden hoses.......with no detrimental effects (we think). I went ahead and bought the hoses to be SURE....and to keep me from mixing up which hose is used to spray chemicals, flush black tank....and which is used for potable water.
FMCA # 436814
Old 11-15-2014, 11:22 AM   #4
Glamper1's Avatar
Yes to washing hands
I guess my question is that I know they recommend filling with a white hose
So if I am connected to a external water supply and therefore not using the pump, that hose too should be a white hose correct?
I'm jus not sure why a regular garden hose is bad even for just washing hands , shower, etc..
Also when city water is connected does it bypass the fresh water holding tank and just go directly to sink and shower?
Old 11-15-2014, 11:23 AM   #5
Glamper1's Avatar
And thank you Toskeysam
Old 11-15-2014, 11:28 AM   #6
toskeysam's Avatar
When you are connected to "city water" you do indeed bypass the freshwater tank (and pump). I would use the potable water hose for this connection also. The potable water hoses (typically white) do not release plasticizers and other plastic-related junk into the water. (Neither did the old rubber hoses from childhood.)
FMCA # 436814
Old 11-15-2014, 11:54 AM   #7
Kevin245's Avatar
Potable water hose
Why would you not use a potable hose? The cost difference is negligible and eliminates all risks.
Eleanor Roosevelt
Old 11-15-2014, 11:57 AM   #8
Glamper1's Avatar
Sounds good
I have a white hose and will use for everything thanks.
I should have bought a longer one
Heading to Half Moon Bay in Calif.
40 min from the house
First night in the AI
Old 11-15-2014, 11:59 AM   #9
Kevin245's Avatar
Make is a great one!!!!
Eleanor Roosevelt
Old 11-15-2014, 11:59 AM   #10
toskeysam's Avatar
Glamper1...Have a great trip! Remember to laugh at what goes on in your small home......
FMCA # 436814
Old 11-15-2014, 12:04 PM   #11
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
Hey Glamper,
Have a great time on your first overnight!
We are heading out Monday to California. Will be in Santa Barbara next weekend then to Monterey over Thanksgiving and then to Napa. Keep your eyes out for a Silver AI!
Keith
Kwils25 is offline   Reply With Quote
Old 11-15-2014, 12:25 PM   #12
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Sounds good
Two or three shorter hoses strung together are fine, and then you never have to use more hose than you need. I've never needed more than 35 feet of hose yet, so I carry a 25' and a 10' hose, which lets me choose 10, 25, or 35 based on where I'm parked relative to the service pedestal.
And in case you don't know (and apologies if you do know) when you're not using a potable water hose, the ends should always be capped or screwed together so that dirt, debris, and bugs can't get inside.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-15-2014, 12:29 PM   #13
toskeysam's Avatar
I can second that on screwing the ends together. I usually do just that, but once this past summer in a rush...I neglected to do it. It was the time of summer in Michigan when the June-bugs were everywhere.......including the several hundred that crawled up into the hose and plugged it. One new hose and one lesson later.....
FMCA # 436814
Old 11-15-2014, 01:29 PM   #14
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
I carry two white 25' hoses. On occasion I have needed the extra length. Also if one should fail I have a spare.
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Potable Water Hose... manda1215 Fresh Water Systems 32 01-28-2014 08:22 PM
Heated Potable Water Hose? SylviaJane64 Plumbing - Systems & Fixtures 7 09-04-2013 09:53 PM
Potable water balrgn All Argosy Trailers 4 03-11-2005 11:07 AM
Potable Water Tank Lee Pace Fresh Water Systems 4 09-01-2004 07:44 PM
