Originally Posted by felixkagi
This new 150W Renogy panel is compact and high quality. The bathroom fan isn't much of a killer but the +0.5" over the 39" is.
So, tell us what would you do different now that you know?
It's hard to get exact measurements if you follow rules 7 & 8.
When I went in to drain the swamp I thought I would have to raise the panel 2" to clear only the toilet exhaust.
After I bought the panel, my mockups seem to show that just wouldn't work and I needed to raise it by 7" to be sure.
After the final install, it looked like maybe it would have fit all along, by just a hair, raised only 2" But it's hard to fine tune the assembly as designed when it's 10' in the air.
It is 48" from the Fiamma awning to the road side roof rail; 50" if you extend all the way to the edge of the roof. That's why I settled for a 39" panel.
If I knew I was going to to have to raise the panel 7", then I would have raised it only 5", cleared the Fiamma awning and bought a 58" panel, maybe even a 200 watt one.
C'est la guerre...at least I now have a new panel that works.
