Old 06-07-2019, 06:10 AM   #1
St amant , Louisiana
Plug it in for storage?
Got my 2017 Interstate out of storage after only two months of non use. It struggled to start and both the chassis battery and house battery were low. I know there are various battery draw items that have been discussed, but does anyone leave their van plugged in at storage. Whether it is plugged in 15 amp or 30 amp, what are the long term and short term effects on the batteries? Do you battery and electrical goo rouxs recommend leaving it plugged in or not?
Thanks for the opinions!
SwampRV is offline   Reply With Quote
Old 06-07-2019, 07:45 AM   #2
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
While I had mine in my driveway, it was always connected to a 15amp outlet. Red switch on. LP switch off. Fusion off (no kill switches at that time)... and I still saw issues with the batteries...
This was specific to the factory battery isolator that comes installed from Airstream. I replaced that with a Blue Sea ML-ACR 7622 and all those problems went away... plugged in... then I fixed the solar charging issues with a Victron BlueSolar 100/30 MPPT Charge Controller - 30 Amps / 100 Volts (new version is the Victron SmartSolar MPPT 100/30)
I still think that this are the two must-do mods for any AI owner to avoid issues with the batteries and improve solar charging efficiency...
Then doing the kill switches for the Fusion and an inside switch for the LP (this one more for convenience)
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is online now   Reply With Quote
Old 06-07-2019, 11:17 AM   #3
2015 Interstate Grand Tour
Lake Oswego , Oregon
I left mine sitting outside in a storage lot for three months and had a heck of a time getting it started. Not because the battery was low but I think I had stale fuel that needed to flush its way through. It would sometimes try to catch and stay running but would not. I must have tried ten times and finally it kept running and has been fine since. First thing I did was dash to the gas station so I could dilute the old fuel with new.
I too installed the ML-ACR 9622. https://amzn.to/2WkhubD
When I left it, I had the override switched to OFF. I also had the rotary switch in back turned to MAN OFF and my batteries were all healthy voltages after three months of idle. Good thing, cause I was cranking that engine over a lot of times to get it going.
Now then.... here's a curious observation perhaps worthy of a new post... I also have the Victron Solar SmartController 100/30 (and the Victron BMV-712 monitor) and the history revealed something very interesting. Only 30Wh were passed into the battery every single day, consistently, while it sat there. Someone tell me why it wasn't zero, or why it wasn't different each day.
Couple this with how I've noticed that, if the coach electrical load is light, the solar input is low even in full sun... if I turn on something, the solar jumps up significantly. Evidently, excess solar energy is dumped into the ether instead of adding too much charge. Someone correct me if I'm wrong about these assumptions.
Tronadora is offline   Reply With Quote
Old 06-07-2019, 11:52 AM   #4
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Plug it in
My two AIs have always been plugged in while in storage. The 2014.5 was modified with the Blue Sea ML-ACR 7622 and I have ordered that BIM for my 2018. The 2014.5 was also modified with an MPPT Blue Sky solar controller. That will be a near future change for the 2018.
The BIM that Airstream installs is a joke, as is the solar controller they install. Either can leave you with a partially charged battery, even with driving and 300 watts of solar on a bright day. The combination of both is pitiful. Odd thing is that better current products don't cost more than the poor products installed.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 06-07-2019, 01:48 PM   #5
wachuko's Avatar
Orlando , Florida
Originally Posted by Tronadora View Post
...Now then.... here's a curious observation perhaps worthy of a new post... I also have the Victron Solar SmartController 100/30 (and the Victron BMV-712 monitor) and the history revealed something very interesting. Only 30Wh were passed into the battery every single day, consistently, while it sat there. Someone tell me why it wasn't zero, or why it wasn't different each day.
Yes... demand based. So once it is charged it is wasted away in the ether... It works the same in mine.
Safe travels!
Wachuko
WBCCI #26769
Old 06-08-2019, 12:16 PM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Seems like a few good answers were given here that make sense. I would like to add that you should fill up your AI with nonethanol gas and put a can of Seafoam in it if you plan on storing it a few months at a time. Stabil never really worked for me or a golf course maintenance shop in Nashville. I've always had luck with Seafoam and keep 35-45 gal. of treated nonethanol gas in a ventilated area in case of emergency. It goes into my generator and power equipment then any left over after 8 months goes into autos.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-08-2019, 12:21 PM   #7
Craig,
The Interstate runs on diesel...
Maybe really early ones ran on gas (?)
Old 06-08-2019, 12:31 PM   #8
davidz71's Avatar
1986 25' Sovereign
I forgot, I had a 5 watt PulseTech solargizer solar panel connected to my dual batteries in my '77 Excellent 500. I had no parasitic draws on that trailer and that panel kept both Delco Voyager sealed batteries fully charged while in the driveway. If stored indoors, I would be inclined to add a BatteryMinder or BatteryTender multistage charger connected to the batteries to keep them up if plugged into a 15 amp. outlet. They come in a number of amp. outputs but don't get just a trickle charger. You need boost, desulphation and maintance phases to keep batteries in top condition. I drove a 43 passenger diesel pusher one day every three weeks and the two on board batteries were smaller than they should have been. I had our maintenance department install a Battery Tender 4 stage charger in the battery compartment and batteries were always topped off and ready to go.
Craig
AIR #0078
3.73 rear end
Old 06-08-2019, 12:34 PM   #9
davidz71's Avatar
1986 25' Sovereign
Craig,
Good point. Seafoam also works in diesel fuel to eliminate water. I always kept diesel additive in the bus at work.
Craig
AIR #0078
3.73 rear end
Old 06-08-2019, 04:39 PM   #10
Wow, good to know.. thanks for the tip !
Old 06-08-2019, 07:42 PM   #11
Life is a Highway's Avatar
2019 25' Flying Cloud
Lady Lake , Florida
Storage
Use a battery tender on the van and one for the coach batteries. They have a new 4 amp that does AGM WET CELL OR LITHIUM. I disconnect the battery switches and plug the charger(s) into a 15 amp power cord.
For gasoline please google k-100.com. It will treat ethanol non-ethanol and literally makes water burn. You cannot overdose with this product it’s great for generators. The D version is for Diesel.
Parasitic current draws cannot stop unless you disconnect the battery cables or use a smart battery tender.
Life is a Highway is offline   Reply With Quote
Old 06-10-2019, 06:47 AM   #12
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Craig,
The Airstream B-190s were on Ford e350s with gas 460s and '98 and later V-10s.
The Interstates have always been on Mercedes (Dodge/Freightliner) chassis with either an inline-5cyl diesel ('02-'06 OM612 or OM647 engine) or the various iterations of the V-6 engine since '07.
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 06-10-2019, 08:05 AM   #13
2012 Avenue Coach
Corpus Christi , Texas
Don't forget the Avenue models from '2010-2012 on the Chevy Express 3500 gas chassis. All ten of them.
Ok, more than ten made, but most likely only a few hundred.
rowiebowie is offline   Reply With Quote
Old 06-10-2019, 09:58 AM   #14
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Oh, geez... yes... all ten of them!
Old 06-10-2019, 05:24 PM   #15
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
I dont have option to plug in for storage. I drop by every 2 weeks and start the engine, turn on the lights, check the dehumidifying buckets, etc. After about 10 minutes, I shut it all back down. And sometimes I just bring it home for the weekend so I can plug in, run the AC or heat to keep it aired out. Technically it is only supposed to be parked in my driveway 2 nights per month per HOA, but I frequently break those rules.
Mansderm161 is offline   Reply With Quote
Old 06-11-2019, 02:05 PM   #16
Lady Lake , Florida
Today’s vehicles
Understand your dilemma. With today’s vehicles the Alternators are not battery chargers they can only maintain a full charged battery. It would be best to start your rig and drive it rather than idle it. At least 15-30 miles to warm up the engine oil and emissions exhaust system.
Have you considered a solar battery maintenance charger? Might be a viable option. To bad no electric at your storage unit.
Old 06-11-2019, 03:31 PM   #17
Actually, the Interstate's engine alternator is quite beefy (around 200A, I think) and designed to charge the house batteries. It is integrated into the coach electrical system and automatically receives or delivers a charge based on whether there is need or a surplus in the coach.
I watch my Victron battery monitor and routinely observe well over 50A being delivered into the house batteries while idling or driving. Add to that another 25A going into my Goal Zero 3000 through my onboard inverter plus another 10A to run fridge and separate freezer.
Old 07-22-2019, 12:14 PM   #18
2017 Interstate Grand Tour Ext
Midwest city , Oklahoma
I visited with AS techs on this issue after my interstate purchase in Nov 2017...advised to put 3amp charge on chassis battery and plug into 30 amp service for house batteries. In my second year and have had no problems with batteries what so ever...maybe lucky!!! Wishing you the best.
Tom
Tstidstfm is offline   Reply With Quote
Water heater drain plug dripping even with a new plug wmb Water Heaters, Filters & Pumps 20 01-20-2019 03:13 PM
Electrical Plug in during Storage? curnes Batteries, Univolts, Converters & Inverters 22 08-24-2015 08:58 AM
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
