Old 09-04-2015, 03:03 PM   #1
lamato's Avatar
2013 Interstate Coach
Sacramento , California
Please help
Somehow, since this morning our AC has stopped working. We had it on in the morning, drove about 100 miles and plugged into another park. Now it will not come on and the thermostat says it is 34 degrees in here which is not true. We tried a thermostat reset, but that did not work. Thank you all for any help.
Vince and Laura
lamato is offline   Reply With Quote
Old 09-04-2015, 03:07 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Have you checked the input voltage?
MICHAEL
Old 09-04-2015, 03:08 PM   #3
lamato's Avatar
What's the input voltage?
Old 09-04-2015, 03:17 PM   #4
AWCHIEF's Avatar
Images: 33
Your alternating current electric input. It should be 114 to 120 volts. Low voltage can be harmful to the AC unit and it may not start at all.
MICHAEL
Old 09-04-2015, 03:23 PM   #5
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Unplug & try your generator it may be power issue in the campground.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 09-04-2015, 03:35 PM   #6
lamato's Avatar
Generator will not run AC.
Old 09-04-2015, 03:40 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Does the thermostat have °F/°C settings? Because 34°C is about 93°F, so the thermostat could very well be correct if it's set on Celsius.
Also, go out to the service pedestal and feel the 30-amp plug. If it feels hot to the touch, that means that your shore power plug is not making good contact and it's actually arcing inside the socket. If there is a 50-amp socket— and if you have a 50-amp to 30-amp adapter— you can try plugging into the 50-amp socket, which is never as badly worn as the 30-amp socket due to being used less often. I've had to do that several times, usually but not always at State or National Parks.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-04-2015, 03:44 PM   #8
Apologies for two posts back-to-back, but when you are running the generator, you only have 20 amps available, not 30 amps, so you have to shut off everything else that uses 120vAC in order to start the air conditioner. While running it uses 15 amps, but while starting up it uses nearly the full 20 amps. Your Energy Management System (EMS) has a load-shedding routine that shuts off loads in a specific sequence if the load exceeds the power available, and the air conditioner is the first load to be shed. So if you have too many other 120vAC users running, the A/C won't even start; the EMS prevents it.
WBCCI #1105
TAC LA-4
Old 09-04-2015, 05:17 PM   #9
lamato's Avatar
Thanks Protagonist, everything was off.
Old 09-04-2015, 05:21 PM   #10
Lily&Me's Avatar
Normal , Illinois
You're sure it is not the thermostat?
I turn my AC on manually, the thermostat doesn't regulate it.
Maggie
Old 09-04-2015, 06:50 PM   #11
lamato's Avatar
Thanks everyone. We found an RV repair shop with a Dometic dealer. He seems to think it's the thermostat. Unfortunately, they don't have any in stock. A lot of places are closed for the weekend, so we're heading to our family reunion a week early so we can drop off the 18 cases of wine we have onboard.
Old 09-04-2015, 07:14 PM   #12
Lily&Me's Avatar
Normal , Illinois
Good luck.
Maggie
Old 09-05-2015, 10:14 AM   #13
lamato's Avatar
Miracle of miracles! We stayed in a hotel last night near a Camping World where we hoped to get some help in the morning with our AC. When we looked at the inside temperature this morning, it no longer read 32 degrees. It must have somehow reset itself. Maybe it had to reboot itself or something. We drove over to a KOA, plugged in, and had success! Then, we tried using the AC with the generator, and that worked too. We are going to stop for the day early, plug in for the night, and make sure everything is ok before heading to SC. Once again, we sure appreciate all your help.
Old 09-05-2015, 10:42 AM   #14
Lily&Me's Avatar
Normal , Illinois
I had mine freeze up a couple of times this year, simply from running it on low at its coldest setting.....an apparent no-no. It wouldn't run again, then, until it was good and ready.
Might touch base with someone re your thermostat, and be sure there isn't something going on that can be headed off by a quick repair, replacement, or words of advice,
You're going to want that AC in South Carolina.
Maggie
Please...Please...No Silicone Roadrunner Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-24-2014 08:00 PM
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
PLEASE, OH PLEASE, may I speak with the WIZARD??? WILDRTEXAS Stoves, Ovens & Microwaves 3 10-09-2009 10:27 PM
Moderators - Please... pretty please... Foiled Again Off Topic Forum 21 03-31-2006 04:29 PM
Closet Flange help! Please read and help! rocat1997 Plumbing - Systems & Fixtures 7 01-28-2006 05:40 PM
