09-04-2015, 03:03 PM
2013 Interstate Coach
Sacramento
Please help
Somehow, since this morning our AC has stopped working. We had it on in the morning, drove about 100 miles and plugged into another park. Now it will not come on and the thermostat says it is 34 degrees in here which is not true. We tried a thermostat reset, but that did not work. Thank you all for any help.
Vince and Laura
09-04-2015, 03:07 PM
Biloxi
, Mississippi
Have you checked the input voltage?
MICHAEL
09-04-2015, 03:08 PM
Sacramento
What's the input voltage?
09-04-2015, 03:17 PM
Biloxi
, Mississippi
Your alternating current electric input. It should be 114 to 120 volts. Low voltage can be harmful to the AC unit and it may not start at all.
MICHAEL
09-04-2015, 03:23 PM
2016 25' Flying Cloud
Venice
Unplug & try your generator it may be power issue in the campground.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
09-04-2015, 03:35 PM
Sacramento
Generator will not run AC.
09-04-2015, 03:40 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Does the thermostat have °F/°C settings? Because 34°C is about 93°F, so the thermostat could very well be correct if it's set on Celsius.
Also, go out to the service pedestal and feel the 30-amp plug. If it feels hot to the touch, that means that your shore power plug is not making good contact and it's actually arcing inside the socket. If there is a 50-amp socket— and if you have a 50-amp to 30-amp adapter— you can try plugging into the 50-amp socket, which is never as badly worn as the 30-amp socket due to being used less often. I've had to do that several times, usually but not always at State or National Parks.
09-04-2015, 03:44 PM
From All Over
Apologies for two posts back-to-back, but when you are running the generator, you only have 20 amps available, not 30 amps, so you have to shut off everything else that uses 120vAC in order to start the air conditioner. While running it uses 15 amps, but while starting up it uses nearly the full 20 amps. Your Energy Management System (EMS) has a load-shedding routine that shuts off loads in a specific sequence if the load exceeds the power available, and the air conditioner is the first load to be shed. So if you have too many other 120vAC users running, the A/C won't even start; the EMS prevents it.
09-04-2015, 05:17 PM
Sacramento
Thanks Protagonist, everything was off.
09-04-2015, 05:21 PM
Normal
You're sure it is not the thermostat?
I turn my AC on manually, the thermostat doesn't regulate it.
Maggie
09-04-2015, 06:50 PM
Sacramento
Thanks everyone. We found an RV repair shop with a Dometic dealer. He seems to think it's the thermostat. Unfortunately, they don't have any in stock. A lot of places are closed for the weekend, so we're heading to our family reunion a week early so we can drop off the 18 cases of wine we have onboard.
09-04-2015, 07:14 PM
Normal
Good luck.
Maggie
09-05-2015, 10:14 AM
Sacramento
Miracle of miracles! We stayed in a hotel last night near a Camping World where we hoped to get some help in the morning with our AC. When we looked at the inside temperature this morning, it no longer read 32 degrees. It must have somehow reset itself. Maybe it had to reboot itself or something. We drove over to a KOA, plugged in, and had success! Then, we tried using the AC with the generator, and that worked too. We are going to stop for the day early, plug in for the night, and make sure everything is ok before heading to SC. Once again, we sure appreciate all your help.
09-05-2015, 10:42 AM
Normal
I had mine freeze up a couple of times this year, simply from running it on low at its coldest setting.....an apparent no-no. It wouldn't run again, then, until it was good and ready.
Might touch base with someone re your thermostat, and be sure there isn't something going on that can be headed off by a quick repair, replacement, or words of advice,
You're going to want that AC in South Carolina.
Maggie
09-05-2015, 10:54 AM
2002 30' Classic S/O
Fleming Island
Now that you mention it I saw a post about someone who had rain or condensation in the unit and it stopped working. Given time to dry out, it got well.
Al
09-05-2015, 03:16 PM
2015 Interstate Ext. Coach
Chicago
We were in Pensacola recently and had to run the AC constantly. I either read in a manual or in a posting to open all the vents and run fan on manual, not automatic ... to keep it from freezing.
09-05-2015, 03:42 PM
Sacramento
By "constant" what do you mean? Did you run it 24 hours? We have ours on for about 4-10 hours in the evening when we've stopped. Depending on where we are it usually shuts off sometime during the night. We have it on AUTO.
