Old 02-16-2015, 09:43 AM   #43
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Guess what, there is potential for the wheels to come off the ground anyway without the hitch wheels. You are only doing it so when you scrape at very very low speeds, you will roll imstead of drag. Doesn't mean you are supposed to keep going.
I haven't found the need for this yet but I am a driveway hog and any incline that looks like it could be a dragger is taken at an angle.
I have barely touched twice in 13,xxx miles using this approach. I just looked at my skid pads the other day and didn't even scrape the paint off.
Ron_CA is offline   Reply With Quote
Old 02-16-2015, 11:25 AM   #44
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Picking up new Interstate Ext. on Friday 13th ;)
I agree with Ron_CA and also try to take steep ramps at an angle when I can at a VERY low speed. I've scrapped the back end about 10 times in 50,000 miles. I also find the dealer's comment interesting because Airstream adds the steel loop skid bars to the hitch as installed on my 2013 EXT model. I'm sure they are still installing these items as seen in photo below. I plan to remove these, cut off the loop and weld on rollers and then reinstall. The rollers will end up at same height as the current skid bars.
Name:	ImageUploadedByAirstream Forums1424111140.977423.jpg
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 02-16-2015, 12:21 PM   #45
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I've seen hitch wheels clamped to the trailer hitch. I'm not near my Interstate at the moment to see whether it's feasible, but this picture shows them clamped under a Great West Vans Legend:
Name:	ImageUploadedByAirstream Forums1424114455.520096.jpg
Old 02-16-2015, 02:05 PM   #46
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Attachment 232539
I have to wonder about the utility of those wheels, considering how high they are compared to the bottom of the generator, and the hitch-mounted bar (supplemental bumper?).
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-16-2015, 02:26 PM   #47
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The AI generator is mounted forward of the spare so as long as you are looking at protection for a ramp, as opposed to a sharp change like a curb, the current loops should provide protection. Not sure why the GWV Legend has the generator so far back. Seems to be very exposed.
Since the AI is unibody, not body on frame, I'd be very careful about putting a lot of upward force on the rear end.
Old 02-16-2015, 05:44 PM   #48
Fulton , Maryland
Attachment 232539
That photo of GWV legend hitch roller is exactly what I intend to do. It almost looks like the same basic part that Airstream uses, except it has a roller rather than a loop of 1/4" steel as a skid.
- - Mike
- - Mike
Old 02-16-2015, 05:47 PM   #49
Fulton , Maryland
I think that is a normal length Sprinter, not an extended. The generator is where the spare would be normally located. I do agree with Protag's comment that the rollers don't make much sense for that geometry.
- - Mike
- - Mike
Old 02-16-2015, 06:10 PM   #50
73shark's Avatar
Maybe I'm missing something. I don't see the utility in replacing the loops w/ rollers.
Old 02-16-2015, 06:46 PM   #51
If done properly, there would be less friction as the rear end makes contact with the ground (rolling instead of sliding) when you reach the limit of your departure angle. Also less of a grinding noise that would inevitably make the driver wince as his precious expensive vehicle makes contact with the ground someplace other than the tires.
Absolutely not to be used as a wheelie bar for drag racing!
WBCCI #1105
TAC LA-4
Old 02-16-2015, 09:20 PM   #52
weirdstuff's Avatar
2018 23' International
Originally Posted by Boxster1971 View Post
Lots of places where you end up scrapping because of that lower trim that Airstream adds. And don't get me started on that crazy low propane fill panel. That black plastic cover is $80. I ripped mine off in Arizona last year and also snapped off the quick connect fitting.
We also cracked our plastic cover, but were fortunate enough to not damage anything inside. When we mentioned this to Airstream, they told us, "Nobody has ever complained about it being too low." BS!!!
That awful scraping noise makes us wince, and scares the s*** out of our dogs.
weirdstuff is offline   Reply With Quote
Old 02-16-2015, 09:23 PM   #53
73shark's Avatar
That awful scraping noise is warning you to stop before you really damage something. With the rollers, you might keep going and cause some serious damage.
Old 02-17-2015, 08:50 AM   #54
Fulton , Maryland
That's a good point - maybe it's not worth the effort. But then I have a welder and need some more practice. 😄
I've also looked at the air bag assist units now sold by the Sprinter Store. They would allow me to raise the back end up a couple of inches to clear most strapping situations.
- - Mike
- - Mike
Old 02-21-2015, 08:07 AM   #55
2400 a year in storage. I would get a quote to fix the driveway and reduce the angle. Might be 5-7 k at most and one time fee.
sterlin761 is offline   Reply With Quote
4CU 004 : Friday The 13th and More Rally! TBRich WBCCI Rallies & Events 4 03-16-2015 08:59 PM
2014 Airstream Interstate EXT Lounge New eBay Watch Airstreams on eBay 0 06-21-2013 08:40 AM
2014 Airstream Interstate EXT Lounge New eBay Watch Airstreams on eBay 0 06-09-2013 10:30 PM
it's friday the 13th! airstreamers Off Topic Forum 53 04-14-2007 03:53 PM
Friday the 13th Navigator Off Topic Forum 18 04-13-2007 08:41 PM
