Old 02-13-2015, 09:54 PM   #29
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Unless they quit doing it, you should get a soft side portfolio w/ the MB Owner's Manual, Airstream Interstate Owner's Manual, and the instructions for all of the installed by Airstream equipment.
Old 02-14-2015, 07:10 AM   #30
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by k9jackie View Post
Attachment 232372 crate fits without removing a chair. Yay
There should also be a tie-down ring at the base of the driver's door B-pillar, that you can use to fasten the dog crate in place so it doesn't slide.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-14-2015, 07:20 AM   #31
Lily&Me's Avatar
Normal , Illinois
A how-to video is a really, really, excellent idea.
Maggie
Old 02-14-2015, 08:07 AM   #32
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Thanks! I didn't try that... I will try in the morning.
Also, I feel like my 14.5 is missing a screen door and the front window cover. Do these come with the AI or do I have to buy them?
They don't come with screen doors, at least not the 14.5 Interstates.
You should have a case with a folding front windshield cover and front side window covers.
Congrats on getting her home. Bummer about the driveway though.
Ron_CA is offline   Reply With Quote
Old 02-14-2015, 08:47 AM   #33
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Any chance of building a small ramp to lessen the approach onto your driveway? If the road is city property, how about asking them whether they can do anything. You won't know if you don't ask!
The 14.5 models moved away from cab curtains that were of a silly design and introduced shades similar to those from accessory companies.
Old 02-14-2015, 11:29 AM   #34
2005 22' Interstate
san clemente , California
Suggest you have heavy duty roller/wheels welded to tow hitch frame so you don't damage rear of the AI.. Not very costly and your driveway will probably not be the only place you may drag your rear end.
unifreck is offline   Reply With Quote
Old 02-14-2015, 12:41 PM   #35
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I agree on rollers added to hitch. I'm planning to add them to mine when it warms up a bit. I added wood blocks but have already ground off two sets already. Also have damaged the lower trim on the back corners. Lots of places where you end up scrapping because of that lower trim that Airstream adds. And don't get me started on that crazy low propane fill panel. That black plastic cover is $80. I ripped mine off in Arizona last year and also snapped off the quick connect fitting.
- - Mike
Old 02-14-2015, 05:21 PM   #36
k9jackie's Avatar
Great Falls , Virginia
I tried backing up but the approach is too steep
Name:	ImageUploadedByAirstream Forums1423959527.912254.jpg
ID:	232426 Click image for larger version
Name:	ImageUploadedByAirstream Forums1423959554.324562.jpg
ID:	232427Click image for larger version
Name:	ImageUploadedByAirstream Forums1423959572.199620.jpg
ID:	232428Click image for larger version
Name:	ImageUploadedByAirstream Forums1423959585.206890.jpg
Sad 1st day home... Had to take it to a storage place $200/mo to park it outdoors.
Name:	ImageUploadedByAirstream Forums1423959655.276569.jpg
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Old 02-14-2015, 05:59 PM   #37
Ron_CA's Avatar
I think you can make it up that driveway with a little planning. You just need some boards to set down and back up onto. This will lift the back end up just enough and once you are more parallel to your driveway you will be Ok.
Just get a couple 4 foot 2x12s and back up just like you did. Put the 2x12s lengthwise behind each out board rear tire. Slowly back up onto the boards which will raise the rear of your interstate up 1 1/2" and may be enough. If not you can put another board ontop of the first to raise you up 3". From the looks of your pics this would work. Still kind of a PIA.
I have to do the same to get my lowered Viper up on to my carlift. Without 2x10s to drive up onto 1st, the nose would scrape terribly.
Tow truck drivers use the same strategy when pulling a car up onto a flatbed tow truck.
Old 02-14-2015, 07:09 PM   #38
73shark's Avatar
Wouldn't putting the 2X12 under the outer dual put a lot more stress on the lugs than if placed under the inner?
Old 02-14-2015, 07:36 PM   #39
Ron_CA's Avatar
It probably will but be a lot easier to reach. I don't think it will be an issue for the time it will take to back up and get on solid ground again. Others have driven long distances with a flat inner tire.
Old 02-15-2015, 02:39 PM   #40
GuyGene's Avatar
Columbus , Mississippi
She looks great k9!! Hey man, ye can get'er up that drive! Use boards, then if that doesn't work, keep figuring it out, ye'll get'er done! There's gotta be a few rednecks in NJ ye can call over... Just keep an eye on them old boys, they'll have the rear jacked up before ye know it!
That old man, he don't think like no old man.
"He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive". Dirt, it's nothing but dirt, I tell ye...
"I thought I was wrong one time, but I was mistaken." Command Sergeant Major Jim
GuyGene is offline   Reply With Quote
Old 02-15-2015, 10:15 PM   #41
k9jackie's Avatar
My dad told me about the redneck way ... Hahaha!!! but I don't want to do it myself and mess her up! We'll probably try it when he comes up to visit.
Old 02-16-2015, 09:21 AM   #42
k9jackie's Avatar
So I wrote the dealership and they said it shouldn't be done on my airstream interstate. Here is the email:
"Good morning,
After discussing the installation of skid wheels on a class B we
unfortunately do not have any products that will accommodate your request.
The wheel base is too short, when the skid wheels it the ground there is
potential for the motorhome wheels to come off the ground, bend the frame,
or do damage to the hitch. I apologize about this.
4CU 004 : Friday The 13th and More Rally! TBRich WBCCI Rallies & Events 4 03-16-2015 08:59 PM
2014 Airstream Interstate EXT Lounge New eBay Watch Airstreams on eBay 0 06-21-2013 08:40 AM
2014 Airstream Interstate EXT Lounge New eBay Watch Airstreams on eBay 0 06-09-2013 10:30 PM
it's friday the 13th! airstreamers Off Topic Forum 53 04-14-2007 03:53 PM
Friday the 13th Navigator Off Topic Forum 18 04-13-2007 08:41 PM
