Old 07-26-2016, 03:07 PM   #15
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Originally Posted by Docevil View Post
So when I go to a pump that says diesel (ultra lower sulfur) and there is no mention of B5, B20 or biofuel I am safe. All pumps with B5, B20 or any biofuel have to be labeled that way. Is that correct?
You are correct that the pumps should be labled. You are looking for "ultra low sulpher diesel" or ULSD. Some pumps are also labled No. 2 Diesel which is ultra low sulpher. You are also safe using B5 Bio Diesel but no higher.
c21bill is offline   Reply With Quote
Old 07-26-2016, 03:21 PM   #16
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
If they follow the law. See Post#7.
My dealer advised to avoid it if at all possible.
Old 07-26-2016, 10:49 PM   #17
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
In addition to Love's, QT, and Murphy's (at Walmart and Sam's) have BioDiesel. There may be others. It is always better to ask first. It shut me down on a trip to Alaska up in Wyoming.
guskmg
Old 07-27-2016, 10:50 AM   #18
Aircruiser's Avatar
2012 Interstate Coach
Westerville , Ohio
You can't rely on brand reliability. BP usually has straight diesel, but at an exit in Wisconsin a BP had B20. Fortunately I looked at the label just as I was inserting my credit card and saw the sticker. Went down the road a piece and found pure diesel. Can't be too careful. It was difficult in Minnesota to find non-bio, too.
Aircruiser is offline   Reply With Quote
Old 07-28-2016, 06:09 PM   #19
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
So fare I did not checked on the bio diesel always went for the cheapest and I am sure put many times B20 in but had no problem for 60k in 3 years now. It is not easy to get anything less the B20 in Illinois.
Peter
PSchw is offline   Reply With Quote
Old 07-28-2016, 06:31 PM   #20
Figment of My Imagination
Protagonist's Avatar
B20 is not an issue in older diesel engines, only in engines that comply with EPA Tier-3 emissions requirements, namely those that use DEF for exhaust treatment. So it is a problem for Airstream Interstates that have the BlueTec system— starting with the ones built on a 2011 Sprinter. Pre-2011 models can burn B20 without problems.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-28-2016, 11:36 PM   #21
73shark's Avatar
I've got a 2010 Sprinter in my 2011 AI and use DEF and it also says B5 max. I think the DEF started w/ the NCV3 in ~2007.
Old 07-29-2016, 12:19 AM   #22
PSchw's Avatar
Livingston , Texas
Mine is a 2013 on a 2012 Mercedes and uses DEF.
no problem yet but I will watch it from now on.
Peter
Old 07-29-2016, 05:26 AM   #23
I stand corrected. Thank you.
Peter
Your profile doesn't mention an Interstate, only a 2005 Skydeck. Sorry for the confusion.
WBCCI #1105
TAC LA-4
Old 07-29-2016, 06:56 AM   #24
PSchw's Avatar
Livingston , Texas
Yes but you only can list one. I wanted to sell my Interstate after purchasing the SkyDeck by decided 2 Airstreams are better then one special after the SkyDeck also serves as the home/house.
Peter
Old 08-04-2016, 01:10 PM   #25
2013 Interstate Coach
Poland , Ohio
Picked up our beautiful interstate on Friday. Son and I drove back from Tampa to Ohio with no real issues. Had an amazing time, spent a night in a truck stop using the generator and another night hooked up to shore power in a Virginia hillbilly campsite. Only issue driving along I4 in pouring down rain stopped for lunch. After our lunch rig was showing and abs eps error. At the same time heavy traffic kept getting series of blarring lights across the dash. Was worried I made a mistake and bought a lemon. Called owner and he said he always got the light s too and did not know what they were. My son and I figured it out in about 5 minutes, it was the front sensors. Obviously shut them off when we were in traffic. I'm an anal guy, previous owner was not. Anyway got a great deal and a great rig. Had it serviced in Ohio and they replaced a speed sensor to correct error codes under warranty. Looking forward to more travels.
Docevil is offline   Reply With Quote
Old 08-04-2016, 05:35 PM   #26
Boxster1971's Avatar
Fulton , Maryland
Picking up 2013 interstate ext on friday
Docevil - you bring up a good point that I hope folks with newer Interstates realize. Since the 2013 Lounge EXT model Airstream has been ordering their Sprinters with the Parktronic System. This system has proximity sensors on both front and rear bumpers. It is activated when you are below about 10 mph in either drive (D) or reverse (R). In slow moving/stop and go traffic the sensors are active and if anyone gets close to you the start flashing and sounding a warning.
Enjoy your new to you Interstate.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Picking up my first 2014.5 Airstream 3500 lounge EXT RICKBETTY Sprinter and B-van Forum 15 01-25-2017 06:48 PM
Picking up new Bambi Friday! Drake1949 2005 and newer - Bambi all models 7 06-05-2016 09:45 PM
picking up our 16 Lounge EXT in a couple weeks - excited but questions! jtrichel Sprinter and B-van Forum 11 07-06-2015 06:15 PM
Picking up my Lounge EXT today, any suggestions? ghaag Sprinter and B-van Forum 6 05-23-2015 06:25 PM
Picking up new Interstate Ext. on Friday 13th ;) k9jackie Sprinter and B-van Forum 54 02-21-2015 08:07 AM
