Old 06-01-2015, 09:43 PM   #1
2015 Interstate Ext. Coach
Chicago , Illinois
Parking brake release
Hi all, I just picked up my new airstream interstate lounge ext two days ago and I love it BUT...the Kenwood DNN991HD (which seems fantastic if I only knew how to access it's features) requires that the parking brake is on in order to access the keyboard. I applied the parking brake and now the brake won't release. The release button goes in but the brake is still on and the dashboard light indicates that as well. Has anyone else had this problem any if so, is there a simple fix that I'm missing? Great forum by the way!
buz118 is offline   Reply With Quote
Old 06-01-2015, 10:13 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Welcome to the Airforums.
To release the parking brake, you need to pull up, depress the button, and lower it to the fully released position. It works like a lot of two seater sport car parking brakes.
Enjoy your new conveyance.
Old 06-01-2015, 10:37 PM   #3
Chicago , Illinois
I knew right after I pushed submit that my post wouldn't read well. I was hoping that there was some correlation between the Kenwood requiring the parking brake being applied (keyboard access) and the brake not releasing properly. I've owned manual transmission vehicles before and have used the handle type parking brake numerous times but I guess I just have a defective brake. Thanks for the reply.
Old 06-01-2015, 11:56 PM   #4
73shark's Avatar
Maybe they didn't connect the wire from the parking brake to the radio so the radio can't tell when the brake is engaged.
My Tahoe has a speed senser that disables the nav entry capability. Real PITA.
BTW, you can edit for up to 30 minutes after you post.
Old 06-02-2015, 05:05 AM   #5
2016 Interstate Lounge Ext
il , Illinois
Also unlike other parking brakes that I am used to, you can actually push the parking brake lever down without pushing the button. So, if you are not pressing the button hard enough, it won't release the parking brake and you will just push the lever down.
mmmmm is offline   Reply With Quote
Old 06-02-2015, 05:18 AM   #6
Lineolated's Avatar
2014 Interstate Coach
Centre County , Pennsylvania
On mine, I have to push the button and yank up HARD. Sometimes it takes me 2 or 3 tries to release it.
Lineolated is offline   Reply With Quote
Old 06-02-2015, 06:55 AM   #7
Chicago , Illinois
Thanks again for the input. I will keep trying maybe I've been a little too gentle because it is new and it may have been sitting on the dealer's lot for a while also, who knows.
Old 06-02-2015, 07:35 AM   #8
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Found that my brake releases better if I add a little pull to the left when lifting handle....otherwise I look I am having a temper tantrum when I release the brake.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 06-02-2015, 09:19 AM   #9
Hi Buz118. I had the same exact problem. I tried to play with the stereo, which required the brake to be in place and I couldn't get it to release. The trick is to pull up really, really hard...way past the point you think you should need to. Then it should release when you push the button. Apparently this is normal, but it's very odd in my opinion and not like any car I have ever owned before. Mercedes dealership confirmed this was normal operation.
migriffin is offline   Reply With Quote
Old 06-03-2015, 08:31 AM   #10
Chicago , Illinois
I got it working now yahoo! Migriffin, that is exactly what I needed to do. My thanks to everyone here for helping me through this and I am looking forward to many great road trips with my new Airstream Interstate. I am so glad that I found this forum, the information available here is very helpful and the contributors are very kind to newbies with problems that are old news for RV veterans (parking brake issues). Stay safe and I'll see you on the road !
Old 06-05-2015, 04:49 PM   #11
Davydd's Avatar
Tonka Bay
Images: 13
I learned the hard way on this in a panic. If you have the swivel seat package for the driver's seat then you have what is called a "folding" parking brake. That means you can set the break and then push the button in to lower it back down so you can then swivel the seat and still have the brake on. That gives you the false impression that you have released the brake but that it is still on. What you have to do is pull it back up a tad higher than before and push the button in again to release it. To me it seemed rather hard to do to the point I won't put the brake on unless I have to.
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
Davydd is offline   Reply With Quote
Old 06-05-2015, 05:15 PM   #12
73shark's Avatar
Maybe mine's broken but I can push mine down without depressing the button. Otherwise it operates as Davydd explained.
Old 06-05-2015, 05:29 PM   #13
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not broken, it's supposed to do that. Pushing it down without depressing the button leaves the parking brake ON but gets the lever out of the way of rotating the seat. Pull up again farther than before and press the button while pushing down to disengage the parking brake.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
1.5 second delay with TT brake / release tintoaster Brakes & Brake Controllers 12 07-27-2014 07:09 PM
Courtesy parking or rental parking needed, Perris Valley, California skydiva Our Community 1 01-13-2011 06:13 PM
'89 345 LE-parking brake won't release ScrapIrony-2 General Motorhome Topics 9 04-17-2008 08:10 AM
cleaning up toilet tank release handle cindy Sinks, Showers & Toilets 0 10-19-2002 11:44 AM
