Old 07-09-2014, 06:28 PM   #1
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
Paper towel holder
I know this seems like a weird question.. But has anyone attached a paper towel holder? I'm afraid to attach one above the sink... Not sure if I will hit an internal wire while trying to screw it in...
Mjgman is offline   Reply With Quote
Old 07-09-2014, 07:05 PM   #2
1974 Argosy 20
Kooskia , Idaho
I hate to put screw holes in my trailer so I use double sided heavy duty mounting tape from Scotch to mount a lot of things, including the paper towel holder. I mounted my solar charge controller with it too. In the TV, I used it to mount the brake controller.
I generally use the gray, outdoor type. It has a red backing liner so it looks red in the package. When removed, it will come off most surfaces without any damage to them. If you make a mistake in where you put the item mounted, you can remove it and with new tape, re mount it.
Old 07-09-2014, 07:09 PM   #3
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
You can carefully drill thru the metal over the kitchen in our Interstate Motorhome. Wrap some tape around the drill bit about 1/8" up from the end. When drilling, stop when you get to the tape and you will not be getting into the wires above. We've done it. I use a s drill-stop-guide which can be accomplished with tape too. I then use a tap and cut threads into the metal and use stainless steel threaded screws, I believe size #2 or #3.
Bikerbill is offline   Reply With Quote
Old 07-09-2014, 07:16 PM   #4
No. 13's Avatar
2012 25' FB Flying Cloud
Orange County , California
Only 2 screws
No. 13 is offline   Reply With Quote
Old 07-09-2014, 07:38 PM   #5
Rollster's Avatar
Saint Augustine , Florida
Originally Posted by No. 13 View Post
Only 2 screws
I like this! Right now we just use a stand-up holder that sits on the counter in a corner.
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
Rollster is offline   Reply With Quote
Old 07-09-2014, 07:38 PM   #6
Boxster1971's Avatar
Fulton , Maryland
Only 2 screws
I used the same one in my Interstate. Mounted it against the side wall just forward of the sink in galley. Mounted it on laminated/wood panel next to wall. Click image for larger version
Name:	ImageUploadedByAirstream Forums1404956290.404975.jpg
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 07-09-2014, 07:40 PM   #7
Mjgman's Avatar
Bradenton , Florida
Awesome thank you all!!
Old 07-09-2014, 08:06 PM   #8
2005 22' Interstate
Pittsburgh , Pennsylvania
Do you have trouble with the roll unwinding as you drive?
avanti is offline   Reply With Quote
Old 07-09-2014, 08:53 PM   #9
Sebastopol , California
I bought mine on amazon, it clips over the cabinet door. We reverse it into the cabinet when we travel so it won't unwind. I actually bought two different styles, one holds the paper towels horizontally the other vertically. We prefer the horizontal mount.
Sebtown is offline   Reply With Quote
Old 07-09-2014, 09:13 PM   #10
No. 13's Avatar
No...I put it in the cupboard.
Old 07-09-2014, 11:19 PM   #11
2012 Interstate Coach
norman , Oklahoma
I mounted mine on the bottom of the table top so that when the top is in the stored position on the right side of the sink cabinet the paper towels are right there next to the sink. On the rare occasion that we use the table top, we take the roll off of the holder and the holder has not been in the way. I mounted it with double sided tape. I flatten the roll a bit and it doesn't unwind. The holder I used has little round rubber balls on the ends that provide a bit of resistance.
russ240 is offline   Reply With Quote
Old 07-09-2014, 11:25 PM   #12
withidl's Avatar
2002 31' Classic
Houston , Texas
Here's my solution (go to bottom of the string): http://www.airforums.com/forums/f46/...der-76355.html
withidl is offline   Reply With Quote
Old 07-09-2014, 11:35 PM   #13
Fulton , Maryland
No trouble with it unwinding because where mine is mounted the roll is against the side wall panel. There is enough friction with the wall to prevent unwinding.
- - Mike
Old 07-10-2014, 03:24 AM   #14
Figment of My Imagination
Protagonist's Avatar
I put my paper towels and paper plates (and dish towels & place mats) in the microwave while en route.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Toilet paper roll holder Nealrap Sprinter and B-van Forum 24 07-26-2014 04:27 AM
Can't Figure Where to Hang Paper Towel Holder Frank&Mike Cabinets, Counter Tops & Furnishings 36 06-25-2012 07:45 AM
Toilet Paper Holder? Kyle General Interior Topics 9 05-10-2011 08:46 AM
Paper Towel Dispenser Concealment withidl General Interior Topics 3 12-05-2010 06:00 PM
Vintage travel trailer/airstream/shasta paper holder eBay Watch Airstreams on eBay 1 03-14-2009 08:16 PM
