Old 06-08-2014, 11:05 AM   #1
2012 Interstate Coach
Manassas , Virginia
Overhead console enclosure/Audio system input
On the 2012 Interstate (and other years), there is a rectangular enclosure in the front overhead console, above the interior cab lights/glasses holder. It has a grey plastic cover plate. Inside, there is a four conductor connector.
I haven't seen a thread on this or a picture with something in this special enclosure.
Is this for a video/audio device, a CB radio, camera, or what?
I want to connect our portable XM radio to the audio system (Kenwood DNX7180) which has an audio input. I just can't find where to connect my XM radio to that Kenwood audio input. The RCA connectors in the large front overhead compartment connect to the front TV. We can listen to the XM through that TV, but the TV shuts off every 15 minutes.
Any information would be greatly appreciated.
vagem55 is offline   Reply With Quote
Old 06-08-2014, 11:53 AM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Welcome to the Airforums.
I noticed the wires in there when I pulled the cover to see if it would work for CD storage but didn't determine what they were.
Why does the TV shut off every 15 minutes?
Old 06-08-2014, 12:34 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
That overhead enclosure is for equipment like a CB radio. The attached file has some details on the connector.
For hooking your portable XM radio to the Kenwood head unit you need to get to the Kenwood's AV input. Do you have the Aux input cables in your glove box? On my 2013 this cable uses the AV input, but mine only has the older iPhone and USB connectors. Depending on your set-up you may need to pull the head unit to get to the connectors on back of the unit.
You can get the manuals with details at this Kenwood web site. The quick start manual has the details on connectors built into back of unit.
http://manual.kenwood.com/en_contents/search/keyword
Hope this helps.
File Type: pdf Sprinter - Equipment Book FF8 page 120.pdf (5.3 KB, 62 views)
- - Mike
Old 06-08-2014, 12:51 PM   #4
Figment of My Imagination
Protagonist's Avatar
Originally Posted by Boxster1971 View Post
[COLOR=black][FONT=Verdana]That overhead enclosure is for equipment like a CB radio. The attached file has some details on the connector.
However, I have yet to find a CB radio that will fit. That enclosure might make a good place to install an aftermarket tire pressure monitoring system, though…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-08-2014, 01:46 PM   #5
73shark's Avatar
My computer is not feeling the love for this file. Two blank pages w/ an error message on the 2nd page.
Old 06-08-2014, 02:50 PM   #6
Fulton , Maryland
I uploaded the wrong file -- my computer was giving me no love today.
Here is the right file.
File Type: pdf Sprinter - Storage Slot under roof liner.pdf (287.3 KB, 86 views)
- - Mike
Old 06-08-2014, 04:19 PM   #7
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
I would love to open it. How is it attached? Velcro? And how did you "pull" it. No room around mine to get something behind the edges.
Bikerbill is offline   Reply With Quote
Old 06-08-2014, 04:52 PM   #8
It just snaps in. Use a pocketknife blade to pry it open around the edges.
WBCCI #1105
TAC LA-4
Old 06-08-2014, 05:28 PM   #9
ben322's Avatar
2009 Interstate
Bethesda , Maryland
It's the size of a single-din head unit so the possibilities are many. I put a DVD/digital media player with an 8" screen and powered it from a house battery lead found above the front headliner. It gives the second row passengers a separate entertainment option as I placed the speakers favorably towards the second row.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 06-09-2014, 07:27 AM   #10
Manassas , Virginia
Boxster1971, thank you for that information. I assumed it was for a CB radio, thought the red was probably power (don't have my VOM on this trip), and hoped the others might go to the speakers.
Where did you get this information, and do you have a link to the full document? The information I could Google was severely lacking.
I saw the connections in the Kenwood document that came with my unit. I only have the Apple connections in my glove box. I had a problem with the head unit not coming on, but it started again as I was going to the dealer for repair, so they said they couldn't do anything. I paid to have it pulled and the tech confirmed the A/V input was connected. I just don't know where the connected wires go.
I am hesitant to mess with it myself, though I have the skill. At that time, it was under factory warranty and now it is under extended warranty.
I did try to pull the head unit with the special tools and got nowhere. The tech told me he had to remove the trim and unbolt the unit. I'm not sure how he removed the trim and sure don't want to mess anything up and have them void my warranty.
73Shark, as for the 15 minutes and shut off, I assume the TV shuts off every 15 minutes (we timed it) because it isn't getting any video input, so it must think there is no signal and it times out. My wife had to reach back and turn it on as we're traveling, or I do it with the remote if we're stopped. Besides the PITA, it would be nice to have the nice sound/volume control/rear speakers of the audio system rather than the TV.
Old 06-09-2014, 10:59 AM   #11
Fulton , Maryland
... Where did you get this information, and do you have a link to the full document? The information I could Google was severely lacking.
I collect all the Sprinter tech data I can find. Even older documents are fairly accurate as the basic design of current Sprinter has not changed much since 2008. You can read about Sprinter history here:
http://en.wikipedia.org/wiki/Mercedes-Benz_Sprinter
The page I posted came from the 2011 Sprinter Equipment Book (2 volumes) uploaded by a poster on the Sprinter-Source forum, her is link:
http://sprinter-source.com/forum/showthread.php?t=16289
I tried to extract just the single page but the document is locked and can only be viewed and printed since it is an official M-B document. So I scanned it from a printed page - thus the poor quality.
To help get your XM radio connected to the Kenwood AV input I need to know what specific portable XM radio you are using and what connections are available on that radio. It may be possible to get an adapter set-up that will work.
- - Mike
Old 06-09-2014, 03:57 PM   #12
Now THAT would be a great place for your rearview camera monitor, so that you can have both an inside rearview mirror AND a rearview camera!
WBCCI #1105
TAC LA-4
Old 06-09-2014, 04:28 PM   #13
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
This is exactly what I was thinking.
Ron_CA is offline   Reply With Quote
Old 06-09-2014, 05:40 PM   #14
73shark's Avatar
Other than keeping an eye on the miscreants in the back, a rear view mirror isn't of much use due to the high placement of the rear windows. I use the mirror on my sunvisor for keeping the young ones under control.
Excella overhead console wiring Linus Electrical - Systems, Generators, Batteries & Solar 4 05-24-2013 04:22 PM
USB Input available with Audio/Video Upgrade package Wayward Audio, Video & TV 4 04-30-2013 05:39 PM
AM/FM/DVD/IPOD audio input receiver info needed oldtrucksrul Audio, Video & TV 16 02-17-2009 08:05 AM
Externial Audio Input thru Stock Stereo? Bambi_Bandit Audio, Video & TV 7 07-17-2005 10:37 AM
Overhead hole in console AccessMaster Airstream Motorhome Forums 2 04-29-2003 08:58 AM
