Old 05-20-2019, 08:25 PM   #1
2011 Interstate Coach
Evansville , Indiana
Over the air antenna model
Anyone know the brand and model number of the over the air TV antenna thatís being installed on newer Interstates? Thanks
BurntAsphalt is offline   Reply With Quote
Old 05-20-2019, 08:44 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
google hoverman
there are plans to build your own flat antennae
waninae39 is offline   Reply With Quote
Old 05-20-2019, 09:17 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The 2018 owners manual indicates they are using the Winegard RoadStar. Copy of info from owners manual attached.
- - Mike
Old 05-20-2019, 09:38 PM   #4
Thanks Boxster. Looking for a small antenna footprint up on the roof to help with reducing solar panel shading. I was going to attach the old one to the A/C shroud like you did but got cold feet when I saw how thin the plastic is. I have visions of it becoming a flying saucer when driving through the Texas panhandle with 70mph winds.
Old 05-21-2019, 09:00 AM   #5
Fulton , Maryland
There is another option that would work, the Wineguard Flatwave antenna...
http://www.winegard.com/flatwave
I have one and several similar antennas in my home and have tested one in my Interstate. It worked just as well as the disk on top of my AC unit. There are also other models that are made from clear plastic. Or you could slip it behind the toilet/shower cabinet so it would not block any window. It I was doing it again this is the type of antenna I would do to eliminate the TV antenna on the roof.
- - Mike
Old 05-21-2019, 04:33 PM   #6
2017 23' Flying Cloud
Lakeport , Michigan
FYI, the Winegard Roadstar that AS has been installing for a few years is a very poor OTA antenna.
Unless you are near a urban area you will be lucky to receive any stations.
Motown is offline   Reply With Quote
Old 05-21-2019, 05:27 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Conventional antenna performance is related to the physical size of the antenna and directional antennas are better than omni-directional. Several on here have replaced the Airstream-supplied antenna with the King Jack. It is relatively small, amplified, and rotatable. It also has a signal meter built in to assist in pointing it.
https://kingconnect.com/product/king-jack-antenna/
Don't give up on mounting on the top of the AC. There may be a metal component under the plastic shroud you could bolt into through the plastic.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 11 04-03-2019 07:11 AM
King OA8200 Digital HDTV Over the Air TV Antenna PatandLane Airstream Classifieds 0 09-13-2018 03:44 PM
Over the air antenna GeocamperAS Audio, Video & TV 49 11-22-2017 10:24 PM
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
Over kill, or just over the top! airjeff Tow Vehicles 12 07-22-2010 09:13 PM
