08-26-2019, 01:06 PM
#1541
2013 Interstate Coach
Poland
, Ohio
Update had to have both NOX sensors replaced 1500.00 ouch. At least my scan tool gave an accurate diagnosis. Love the rig but hate the maintenance costs.
08-26-2019, 01:24 PM
#1542
2018 Interstate Lounge Ext
LV
, Nevada
DOCEVIL87 - 1500 for 2 sensors? YIKES! Hate it when the failure happens just outside of it's warranty window. Just think of it as a $300/yr. maintenance item and put that it the kitty jar every year for the next time so it doesn't sting as bad
08-26-2019, 02:11 PM
#1543
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
Yeah! Ouch!!
08-26-2019, 02:28 PM
#1544
Orlando
Does not look like I will be able to go riding this weekend... so the plan for this weekend changes to tackling some honey-do tasks at home and try to remove some from the AI pending list:
- Change oil in Generator
- Install mesh in the intake opening to minimize critters making a nest inside the air-cleaner housing
- Install louder horn
- Build storage under AI for leveling blocks. Looking at some of those lift-top coffee table hinges to see if I can install those upside down and be able to pull down and out the base of where I store these... to make it easy to retrieve and store. Will still require a lock pin of some sort so it does not come down accidentally, but might work and make it easier for me...
- Reconfigure bar area. Leaving space for two bottles and re-purposing the rest for storage of spices, espresso pods, and witche's potions. Still have not figured out what to replace that with... but just removing the Lexan will get rid of the awful noise it makes going down the road.
- Replace rust prone screws in the bathroom mirror... hate to see (and have to polish clean) the streak of rust coming down from the screws in the mount...
- Replace the wood discs on the floor with the Turtle plates we got
08-26-2019, 05:03 PM
#1545
LV
, Nevada
Originally Posted by wachuko
[*]Build storage under AI for leveling blocks. .
WACHUKO - the support brackets for driver and/or passenger running boards should hold them with no issue since they are pretty light. I use that for my plastic outdoor sink
08-31-2019, 03:00 PM
#1546
Orlando
Horn installed. It cannot be installed on the stock location... no way to make it fit.
You could, however, install the Denali SoundBomb Mini in the stock location if you do not want to deal with routing wires and installing a relay... I have this one on my motorcycle and it is a great improvement over stock.
But I had the Stebel purchased already... so decided to push forward with that one...
Ended up installing next to the air compressor... wished it was facing outside (between grill and engine) but could not find a suitable place for the install...
Much louder than the stock unit. If on the road is still not enough, I will get the Denali to add to the stock location and have both...
Photos attached. Did not explained the removal of the grill since Alex did an excellent job on that with his thread ( Front Grill AI Project). But just quickly, remove two Torx25 bolts, plastic clips, swing the grill a bit, insert your hand and push out bottom clips... and it is out.
Oh, and I could not find a harness adapter to match the stock connector on the Mercedes horn harness so ended up cutting the wires and using some standard male/female wire connectors... then taped over it, and placed inside plastic loom to protect them...
08-31-2019, 03:10 PM
#1547
Orlando
Also took the time to install the mesh over the intake opening...
Before
Made some holes to be able to pass the tie wraps...
After
Initially I was just going to stop by the local hardware store and grab some mesh... turns out that I had this piece of plastic grate that came in a motorcycle mirror package... perfect!
08-31-2019, 10:32 PM
#1548
Orlando
At 28 hours... changed the oil in the generator and the air filter.
And to be completely transparent... changed the air filter because I overfilled the oil and had to do it all over again... .63 quart!! Got confused with the generator at home that you fill until the oil shows in the filler neck... Stupid, I know...
This is why I have a checklist for maintenance, but did I look at it!!??? No!!... so had the pleasure of cleaning everything!! Changing the oil again... and placed a new air filter...
Everything started fine and working as expected.
Just because I will not be okay until I do it... getting a couple of spark plugs (Spark plug NGK BR6HS) to replace the one in there, and to have a couple spare...
And yes, just done with this now... could not go to sleep knowing that I messed up... had to make it right. We have the RV full of diesel and LP and ready to go if we have to evacuate due to Dorian... looking like it might miss us if its stays on the current path...
Good night!
08-31-2019, 11:08 PM
#1549
2012 Avenue Coach
Corpus Christi
Been there, done that. I probably wouldn't have slept either, so best you got it done.
Hope you don't need to bug out.
09-01-2019, 05:43 AM
#1550
Waterloo
, Iowa
Any idea if the Nox sensors need to be calibrated to the emissions control system after installation? If so I suspect this is something that only MB can do with their STAR code gadget, not something that can be done with other code readers. Also, I suspect the MB has somehow fixed it so that you have to buy their NOx sensor at a price of $1500 for two, even though a $370 one at Partsgeek is advertised as:
OES Style connectors and wire lengths. The Genuine oxygen sensor is the same exact product supplied by the automotive dealer and is provided in the vehicle manufacturers branded packaging.
After my recent experience with a wheel speed sensor bought at Partsgeek I am skeptical of their 'genuine' products.
09-01-2019, 06:26 AM
#1551
Orlando
Those are plug and play and reset codes... not calibration needed.
09-01-2019, 06:28 AM
#1552
Orlando
Thank you. And on the positive side, now I can answer the question "What happens when you overfill the oil in your generator?"
Lot's of smoke
Shuts down after 15 minutes
Oil fills the air filter
You get to do it all over again!
On my way to get the spark plugs
09-01-2019, 07:21 AM
#1553
2011 Interstate Coach
Evansville
, Indiana
Titus,
As a devout DIYer, I've done a lot of reading on this subject. My understanding is that the Mercedes system requires that the Nox sensors have to be "married" to the vehicle with the STAR/Xentry or similar (Snap On) diagnostic tools, which are prohibitively expensive.
I hope the "Right to Repair" movement eventually becomes federal law. Since just about every product has software now, more and more manufacturers are locking us out of the ability to repair our own property.
09-01-2019, 08:39 AM
#1554
Orlando
Originally Posted by BurntAsphalt
Titus,
As a devout DIYer, I've done a lot of reading on this subject. My understanding is that the Mercedes system requires that the Nox sensors have to be "married" to the vehicle with the STAR/Xentry or similar (Snap On) diagnostic tools, which are prohibitively expensive...
I can't spend what that system costs to go the DIY route with these parts... that sucks big time. So what I read was older Sprinter then?
09-01-2019, 10:20 PM
#1555
Orlando
Annoying noise be gone! Still work in progress but removed the bar, got rid of all the rattle noise making plexiglass...
Before:
After:
09-02-2019, 03:37 PM
#1556
Poland
, Ohio
Like to consider myself a DIYer however felt the NOX sensors was above my pay grade.
Too much down side if it needed Dealer programing. Installed my valvo max, but don't know how to download pictures asking for a url?
09-03-2019, 08:40 AM
#1557
Orlando
Use the option of Manage Attachments when you do a posting... click on that button and upload the image to the post.
And here are the instructions posted in the FAQ section of this site. Just follow those steps:
http://www.airforums.com/forums/f138...tml#post612569
I also got the ValvoMax... waiting for the next oil change to install. Thank you for the recommendation
09-03-2019, 08:46 AM
#1558
Orlando
09-03-2019, 11:00 AM
#1559
Poland
, Ohio
Thanks wachuko,
here are my photos of the valvo max installed.
09-05-2019, 04:32 PM
#1560
2017 Interstate Grand Tour Ext
Gulf Breeze
Thanks wachuko,
Can you use the ValvoMax for the generator or is it just for the engine?
