Old 05-20-2018, 03:18 PM   #701
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Smile
Originally Posted by Boxster1971 View Post
Don't know who that is or the reference.
That is the famous Cool McCool!! And one of his phrases is “Danger is my middle name”.
I was just trying to make a funny reference... but now the moment is gone...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 05-20-2018, 03:25 PM   #702
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Following your progress on relocating the LP Fill Panel with great interest. You are doing the same thing I was planning, but the next step is more of a challenge. How do you plan to cut that bracket with the LP lines attached?
Or are you going to empty the LP tank and disconnect the lines? That's the dilemma.
+1 Never scares me to do electricity live but I just petrified of tooling around/near any type of gas
Alex AVI is offline   Reply With Quote
Old 05-20-2018, 03:48 PM   #703
wachuko's Avatar
Orlando , Florida
Thumbs up
Originally Posted by Boom23 View Post
You might want to make the assembly a little more sturdy...
I just filled the propane for the first time and the attendant was pretty physical with the propane nozzle and the RV inlet. The whole RV was shaking.
The rivets might get loose over time. Maybe more overlap and two rows of rivets, or zig zag?
Just a suggestion.
Also, in case you have not thought about it, which I am sure you did, the bracket supporting the skirt would probably be a good place to mount the magnet to keep the opening closed.
Great Job! You are very brave with the mini hack saw.
I plan to do this modification also. Thank you for sharing.
I can also use bolts to secure it. Thank you for the suggestion. It needs to be as sturdy or more than when it was stock.
On the supporting bracket. Yes! That is why I wanted to see if I could cut right next to it. It will serve as the point where the magnet attaches to.
Thanks again!
Safe travels!
Wachuko
WBCCI #26769
Old 05-20-2018, 03:51 PM   #704
wachuko's Avatar
Orlando , Florida
Thumbs up
If you are thinking about silver trim pieces, here are a couple from a quick search:
https://www.amazon.com/Silver-Overla.../dp/B01E3COKK6
https://www.amazon.com/YIJINSHENG-3m...ASVS2NFYXEBX0T
Thank you. I will try touch up paint first... but most likely I will need to do the trim... I think it will look better than just leaving it without it... but I will try to find it in silver instead of chrome. To make it disappear... So I will order the second one on your post.
Safe travels!
Wachuko
WBCCI #26769
Old 05-20-2018, 03:53 PM   #705
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Agree. But a hacksaw or drill with lube oil should not produce any sparks. I would not recommend a grinder or cut-off disk tool. I'm going to have a closer look at my van now to see if I can get this done.
For relocating the quick-connect fitting I'll have to drill a large hole and get a proper bulkhead fitting. Not going to try to re-weld the old fitting on the panel.
An aluminum continuous hinge would also work for remounting the trim piece
- - Mike
Old 05-20-2018, 03:53 PM   #706
wachuko's Avatar
Orlando , Florida
Just hold my beer while I do this...
Safe travels!
Wachuko
WBCCI #26769
Old 05-20-2018, 03:55 PM   #707
wachuko's Avatar
Orlando , Florida
Thumbs up
^ This!!! Even a hack saw... I can use a small cutting disk with the dremel to make the path... and then use a hack saw to finish the cut... I am in no hurry and can take the time cutting it...
I got this hinge... should be here in a few weeks. Stainless steel. But as you mentioned, aluminum should work as well...
Safe travels!
Wachuko
WBCCI #26769
Old 05-20-2018, 03:55 PM   #708
Fulton , Maryland
Sorry - I was in college when the Cool McCool animated series ran on NBC (1966-1969). I didn't watch much TV during those years.
- - Mike
Old 05-20-2018, 04:24 PM   #709
Fulton , Maryland
Thanks for link to SS hinge, that would be stronger than aluminum. Here is the type of bulkhead fitting that might work to re-locate the quick-connect fitting.
https://www.amazon.com/Legines-Fitti...dp/B074FT9JJG/
- - Mike
Old 05-20-2018, 05:03 PM   #710
wachuko's Avatar
Orlando , Florida
I was not planning on relocating the quick disconnect. I was just going to place a spacer to push the whole thing back so that the connector clears the chassis.
And because of this, use bolts to secure everything together...
Makes sense?
Safe travels!
Wachuko
WBCCI #26769
Old 05-20-2018, 05:05 PM   #711
Huntington Beach , CA
Some more trim that might not be as shiny:
https://www.amazon.com/Protector-COS...lver+edge+trim
https://www.amazon.com/Matched-Moldi...lver+edge+trim
Boom23 is offline   Reply With Quote
Old 05-20-2018, 05:54 PM   #712
Fulton , Maryland
Makes sense?
Not sure there is enough room to do what you suggest. Might be if you use about 1/2" spacers. Definitely bolts required for this. I'll have to look close and measure. Sure would be easier if you don't have to re-locate that connector.
- - Mike
Old 05-20-2018, 07:42 PM   #713
Fulton , Maryland
Ok - looking at this closer I'm thinking a piece of 3/4" square tubing would make an adequate spacer. That also would mean mounting the panel about 1/4" lower than you suggested above. Not a big issue. Plan to spend some time tomorrow under van checking dimensions.
- - Mike
Old 05-20-2018, 08:05 PM   #714
Alex AVI's Avatar
You did such a wonderful job on that cut (freehand, you one brave cookie). I personally think the paint touchup will end up looking great coz the cut was clean and so the 2 edges will match up. Whichever way you end up finishing the edge, yours will look so much cleaner setup than the rest of us mortals.
2018 Jeep Eco-Diesel VS 2018 Expedition? Barretta2 Tow Vehicles 57 03-10-2018 03:39 PM
My Journey begins 4dougstream Member Introductions 5 05-03-2013 10:54 AM
The Journey Begins cozycan 1966 - 1968 Safari 4 06-19-2012 10:11 AM
The journey begins.... Pomfritz Classic Motorhomes 27 08-27-2010 05:53 AM
The journey begins.. tvadman1963 Member Introductions 6 03-19-2007 03:54 PM
