Old 09-26-2017, 05:53 AM   #15
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Smile
Something else that I forgot to add... bright red LED strip on the front TV/Screen... can't count the times I hit that sucker while looking at the unit they had at the local dealer . I don't even know why we need that one there? Most likely a newbie reaction, but thinking about removing that one...
On another note, saw that my wife had downloaded an app for RV parks and places... and already has a list of local parks to visit She has bought into it and is excited to start using it. Woohooo!!!
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 09-26-2017, 06:07 AM   #16
2017 Interstate Grand Tour Ext
Houston , Texas
Regarding lumps in the bed, we have no topper and don't find them troublesome. We use the RV Superbag https://www.rvsuperbag.com/
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
TayaraTravel is offline   Reply With Quote
Old 09-26-2017, 11:04 AM   #17
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
Originally Posted by wachuko View Post
And the suggestion of finding a spot/parking where the rear of the AI can overhang, to keep it from sticking out so much, was great.
Just be VERY careful when doing this. It is really easy to scrape the propane "box", or tear it off entirely. Until you crawl under there, or try to, you have no idea of just how little ground clearance there is back there.
FlyFishinRVr is offline   Reply With Quote
Old 09-26-2017, 11:08 AM   #18
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Good point. I have my wife go back and check for clearance when backing over a curb or parking stop.
c21bill is offline   Reply With Quote
Old 09-26-2017, 11:44 AM   #19
wachuko's Avatar
Orlando , Florida
Valid point... did not think about that. Looking under it (photos found online), there are a lot of places where things can get impacted... I am also seeing some components that are quite exposed... probably should make some sort of shields to avoid accidents...
Name:	Airstream Interstate - under protection required.jpg
Safe travels!
Wachuko
WBCCI #26769
Old 09-26-2017, 12:12 PM   #20
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I've lost one LP fill panel cover rolling over a big pothole and damaged another backing over a snow bank. That panel behind the RH rear tires is the lowest point under the van and very vulnerable. I considered trying move it higher for better clearance, but that meant unhooking the LP fill line which requires emptying the tank. I added air bags to rear axle that allow me to raise the rear for better clearance.
The low point in the middle are not as vulnerable.
- - Mike
Old 09-26-2017, 12:44 PM   #21
wachuko's Avatar
Orlando , Florida
Thumbs up
Thank you FlyFishinRVr and Mike... very clear now with this photo...
I did order it with the air ride... but can't risk forgetting to raise and taking all that out in the process...
Name:	Airstream Interstate - under rear-sm.jpg
Safe travels!
Wachuko
WBCCI #26769
Old 09-26-2017, 12:56 PM   #22
I thought I read somewhere that with the air ride, you can stop the van and raise the back up, but the moment you put it in drive or reverse, it automatically goes back to a "normal" ride height. If true, would the air ride really provide a benefit when parking, or does it just naturally ride a bit higher? Even 1" would be a big help.....
Old 09-26-2017, 01:05 PM   #23
Fulton , Maryland
That is true with the VB Airsuspension. Someone who has it on their van will have to clarify if it can be used to raise the rear in such situations to back over a curb. I installed a pair of Dunlop airbags that I sourced from the UK. With my remote controlled AirLift compressor I can adjust the ride height manually from the drivers seat.
- - Mike
Old 09-26-2017, 01:28 PM   #24
Good to know Mike, thanks! I thought the VB system was the only one that would work with our vans, so it's good to know there are options.
Old 09-27-2017, 03:40 AM   #25
MISGM's Avatar
Hephzibah , Georgia
Hello All: New to forum and posting - I too have just purchased a 2018 AI and bought the metal stems for my duallys. I need a recommendation from folks for a competent installer on east coast (yes I have the Alcoa Wheels).. Thanks in advance...
MISGM is offline   Reply With Quote
Old 09-27-2017, 05:26 AM   #26
wachuko's Avatar
Orlando , Florida
Originally Posted by Lineolated View Post
One more thing: new dually tire valves. Checking and airing up the duallys is a PITA. Hereís a link:
http://yourtireshopsupply.com/produc...yvalve-dl1spal
Iím assuming the 2018 still has the Alcoa aluminum wheels.
A few $ less from eBay
http://www.ebay.com/itm/Dually-16-St...-/361945587746
Safe travels!
Wachuko
WBCCI #26769
Old 09-27-2017, 05:29 AM   #27
Lineolated's Avatar
Centre County , Pennsylvania
Discount Tire in Richmond VA installed mine in new tires I purchased. They did a good job; Iíd go back.
Lineolated is offline   Reply With Quote
Old 09-27-2017, 05:32 AM   #28
wachuko's Avatar
Orlando , Florida
Smile
Can't help there, newbie here as well without my rig as I wait for delivery...
I ordered them and was going to ask the dealer to install them before delivery... Not sure what they would charge for this. Remove wheels, remove tire (or push to have the access without removing the wheel), install, guessing they will need to balance the wheels if the tire rotates in the rim, install it all back...
Welcome to the forum!!!
Safe travels!
Wachuko
WBCCI #26769
2018 Jeep Eco-Diesel VS 2018 Expedition? Barretta2 Tow Vehicles 57 03-10-2018 03:39 PM
My Journey begins 4dougstream Member Introductions 5 05-03-2013 10:54 AM
The Journey Begins cozycan 1966 - 1968 Safari 4 06-19-2012 10:11 AM
The journey begins.... Pomfritz Classic Motorhomes 27 08-27-2010 05:53 AM
The journey begins.. tvadman1963 Member Introductions 6 03-19-2007 03:54 PM
