Old 03-05-2016, 02:47 AM   #43
2015 Interstate Ext. Coach
Lake Mary , Florida
Yes the "hidden" outlet was found, and it can be more usable if not covered by the leatherette seat cover material ))). But any way it is good to know it is there )
Mr. B is offline   Reply With Quote
Old 07-12-2016, 05:09 AM   #44
Chicago , Illinois
Originally Posted by 73shark View Post
Watch the outside rib on the fronts for excessive wear that show up around 10K-15K miles.
If you get that, get the camber set as close to zero as the spec allows which may require the special camber bolts from MB for about $8/ea.
at 5K miles, I had our AI aligned by a MB authorized independent shop (the MB dealer couldn't do it originally) A year later, at 15K miles, the inside edges of the front tires were pretty worn. So I replaced them with Michelins, and had it all aligned again (this time the MB dealer did it, but they sent out to a nearby shop)
Recently on our first trip after the alignment, we noticed our hands on the steering wheel vibrate a bit. It's not uncomfortable, but visually very noticeable. I can't remember if they did before? Should the wheel /and hands on it, be perfectly smooth if aligned properly? Or is some, very visible, shaking normal? Or could this even be a balance problem?
Would appreciate some perspective from others.
THANKS
Marks71 is offline   Reply With Quote
Old 07-12-2016, 05:27 AM   #45
Lily&Me's Avatar
Normal , Illinois
The shaking/vibration you feel on your steering wheel could be from your road surface.
We have always gotten our tires rotated every 5-6,000 miles....10.000 miles is too long, and you will get irregular wear from what I am told.
Our last few sets have been Firestones, and you can go into any Firestone dealer, anywhere in the country, and they will rotate and balance them for free.
Maggie
Lily&Me is online now   Reply With Quote
Old 07-12-2016, 05:40 AM   #46
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Tire rotation is a much easier task on T1N Interstates like yours where all four rims match, in comparison to the NCV3 Interstates that have three different rims for six tires. (According to the Sprinter manual, the spare is never in the rotation).
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-12-2016, 08:27 AM   #47
Lake Mary , Florida
Marks71, this is your balance problem.
I swapped my front tires to Michelins once I bought my van, and I forced them to redo the balance several times until it's perfect.
Alcoa rims require special attention with balance, and some guys simply do it wrong. It has a big opening and require a big conus adapter which will fit between the balancing rod and your rim to hold it straight, otherwise the result will be shown 00 on the balanvce machine's screen, with wrong weights on the rim.
Go get to re-balanced it right.
Old 07-12-2016, 08:37 AM   #48
Chicago , Illinois
Old 07-12-2016, 08:27 PM   #49
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Rotating does not eliminate the cause of irregular wear, it merely hides it by wearing the tires evenly. My fronts had mildly excessive outer rib wear and they're now on the back and the wear pattern is almost down to catch the outer rib. These Continentals seem to wear like steel. And ride like that.
Old 07-12-2016, 11:12 PM   #50
Lake Mary , Florida
True!
Old 11-28-2016, 08:02 AM   #51
2015 Interstate Grand Tour
kirkwood , Missouri
Twin mattresses
[QUOTE=GloryBound;1731539]On the Twin we replaced the factory mattresses with custom ones from Handcrafted Mattress Company. A separate 15" piece goes in the middle. This was not a cheap upgrade but it's a real bed. We leave the bed together all the time and use two plastic bins for increased storage.
Did you sell the twin mattresses? We just bought a grand tour EXT and want to remove the whole entire rear bed and convert to twins.
epicdetour is offline   Reply With Quote
Old 11-29-2016, 12:20 PM   #52
2018 30' Classic
Rock Hall , Maryland
Twin beds
Yes we still have the original mattresses. We are in Maryland. Let me know what you'd like to do?
GloryBound is offline   Reply With Quote
First trip in our new 2015 Interstate Grand Tour LizabethLane Sprinter and B-van Forum 40 10-29-2014 02:06 PM
touchup 1 year later LI Pets Cleaning, Stripping & Polishing 0 04-27-2014 08:18 AM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
Univolt stop running and start later brunoffrance Electrical - Systems, Generators, Batteries & Solar 6 07-04-2003 12:33 PM
