Old 06-17-2015, 11:10 AM   #1
2014 Interstate Ext. Coach
Miami Beach , Florida
Optimal Tire pressure for 2014 Interstate?
Can someone let me know the optimal PSI for the two front and four back tires on my interstate? My RV dealer and Mercedes shop have said different numbers.
ATE123 is offline   Reply With Quote
Old 06-17-2015, 11:52 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
61 psi all around is what the Sprinter owner's manual says, and that's what I use on mine.
Cats and ultraleather Airstream upholstery don't mix!
Old 06-17-2015, 11:55 AM   #3
Thanks- that is what my RV place said, but my interstate is at Mercedes and they wanted to do 47 in front and 70 in back!
Old 06-17-2015, 12:30 PM   #4
UKDUDE's Avatar
Sedona , Arizona
If you're a nit-picker, the correct way to set your tire pressures is by weighing each of the axles when you're fully loaded, and then refer to the load/pressure tables from your tire manufacturer.
Here's a link to a write-up with some detailed instructions:
http://www.thefitrv.com/rv-tips/how-...re-in-your-rv/
But I think most of us stick to the Airstream recommendation of 61 all round. And of course that is a generalization for everyone.
Old 06-17-2015, 04:24 PM   #5
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
That dealer is giving you the numbers for a 4-wheel 2500 Sprinter. Check your MB Owners Manual for 3500 Sprinter with GCWR of 11,030 and heavy duty axles front and rear it says 61 psi all around. That is where Airstream gets 61 psi number for the Interstate. UKDUDE has the most correct answer, which is what I've done. Had my van weighed and after consulting the Michelin tire chart It said I could run at 50 psi with my weight. But I set mine to 55 psi all around for a little margin. It does ride smoother than when I had the tires set to 61 psi. After 20,000+ miles the tires are wearing properly.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 06-17-2015, 05:58 PM   #6
Thanks, Mike. Good feedback all around.
Old 06-20-2015, 07:40 PM   #7
2014 25' International
2010 22' Interstate
Carol Stream , Illinois
I've been using the 61lbs for all tires. For safety, comfort and tire ware for the Interstate 3500. Mercedes has their mechanics put in 61 all around. FYI
John Millner is offline   Reply With Quote
Old 06-23-2015, 03:56 PM   #8
2015 Interstate Ext. Coach
Chicago , Illinois
btw ... on a 2015 AI Grand Tour : does anyone know if there's a low tire pressure warning on the instrument panel? My manual says there should be one, but I have followed the instructions and fooled around a lot with the buttons on the steering wheel, and can't come up with one.
Marks71 is offline   Reply With Quote
Old 06-23-2015, 05:57 PM   #9
UKDUDE's Avatar
Sedona , Arizona
It's a Mercedes option not installed on the Sprinters upfitted by Airstream.
Old 06-23-2015, 07:19 PM   #10
Fulton , Maryland
No - Mercedes dos not offer tire pressure monitor system on 3500 Sprinters because they are not required by U.S. DOT.
"FMVSS No. 138 requires new passenger cars, multi-purpose passenger vehicles, trucks, and buses with a gross vehicle weight rating (GVWR) of 4,536 kg (10,000 pounds) or less, except those with dual wheels on an axle, to be equipped with a TPMS to alert the driver when one or more of the vehicle's tires, up to a total of all four tires, is significantly under-inflated."
http://www.nhtsa.gov/cars/rules/ruli...nalrule.6.html
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 06-23-2015, 07:38 PM   #11
Chicago , Illinois
Ok thanks
Old 06-23-2015, 08:44 PM   #12
UKDUDE's Avatar
Sedona , Arizona
Federal Motor Vehicle Safety Standards; TPMS; Controls and Displays. Final Rule.
- - Mike
You're right - and I stand corrected!
Old 06-24-2015, 07:35 AM   #13
Flemington , New Jersey
Well.....there is a TPMS system in the Interstate.
Its called ESP.
When one of the tires pressure is low enough (or higher - after extended downhill braking for example) and consequently one tire has a different diameter than the rest, the ESP senses it and throws the 'ESP - Visit Workshop' warning and sometimes even a check engine light followed by reduced power.
Find the offending tire (usually the last one you check), air up, use the scan gauge to reset the check engine light if need be and be on your merry way.
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 06-24-2015, 07:39 AM   #14
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Any idea on what the pressure differential is before it will throw a code?
Old 06-24-2015, 07:55 AM   #15
Never kept notes but it seems to be 2-5 psi. Oddly enough, when I was checking the pressure for a trip this week, both fronts were at 52 and the rears were at 72. The van did not throw any ESP codes thus I think the ESP is more concerned with sensing the diameter (wheel speed) at each corner using the ABS wheel speed sensors. SO if one corner or opposing corners is off, then a code is thrown. In more automated German vehicles the ABS system controls stability (wheel speed) in corners by varying brake pressure at the wheel.
The only idea that comes to mind why I had such a large pressure differential front to rear is that I had the front tires spin balanced last week and the shop may have had to lower the front pressures for more grip on their machine, then forgot to air up after.
Mario
2013 Interstate
Old 06-24-2015, 09:57 AM   #16
73shark's Avatar
Curious as to why 72 psi in the rears.
Old 06-24-2015, 01:10 PM   #17
Fulton , Maryland
The ESP never sensed my flat inside dual. I ran it flat for at least 20-30 miles with no indications. I discovered it at a rest stop while doing a tire check. Since then I added a TPMS unit from TST.
- - Mike
- - Mike
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 09:19 AM
Installing Tire Pressure Monitor System in Airsream Interstate jerhofer Sprinter and B-van Forum 18 02-15-2015 11:18 AM
pump configuration for optimal pressure on city water 72streamline Fresh Water Systems 5 02-18-2014 01:58 AM
Optimal position for black and gray tank when dumping Woosch Waste Systems, Tanks & Totes 2 10-26-2012 08:23 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
