Old 06-24-2015, 07:55 AM   #15
2013 Interstate Coach
Flemington , New Jersey
Never kept notes but it seems to be 2-5 psi. Oddly enough, when I was checking the pressure for a trip this week, both fronts were at 52 and the rears were at 72. The van did not throw any ESP codes thus I think the ESP is more concerned with sensing the diameter (wheel speed) at each corner using the ABS wheel speed sensors. SO if one corner or opposing corners is off, then a code is thrown. In more automated German vehicles the ABS system controls stability (wheel speed) in corners by varying brake pressure at the wheel.
The only idea that comes to mind why I had such a large pressure differential front to rear is that I had the front tires spin balanced last week and the shop may have had to lower the front pressures for more grip on their machine, then forgot to air up after.
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 06-24-2015, 09:57 AM   #16
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Curious as to why 72 psi in the rears.
Old 06-24-2015, 01:10 PM   #17
Boxster1971's Avatar
Fulton , Maryland
The ESP never sensed my flat inside dual. I ran it flat for at least 20-30 miles with no indications. I discovered it at a rest stop while doing a tire check. Since then I added a TPMS unit from TST.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Installing Tire Pressure Monitor System in Airsream Interstate jerhofer Sprinter and B-van Forum 18 02-15-2015 11:18 AM
pump configuration for optimal pressure on city water 72streamline Fresh Water Systems 5 02-18-2014 01:58 AM
Optimal position for black and gray tank when dumping Woosch Waste Systems, Tanks & Totes 2 10-26-2012 08:23 PM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
