Old 02-12-2013, 05:45 PM   #43
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I've experienced about the same results, consequently I try to drive about 60-65. Going 70 really starts knocking the mpg down.
Old 09-02-2013, 10:58 AM   #44
Trying to Retire
MILATV's Avatar
Decatur , Illinois
18.5 - 19 mpg at 65MPH
16.5 - 17 mpg at 70MPH
Around 13 MPG when running around town (30-45 mph)
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 09-02-2013, 11:38 AM   #45
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Qualifier most driving in Midwest is VERY flat.
Mike
Old 09-11-2013, 06:05 PM   #46
Jeff64's Avatar
2014 Interstate Ext. Coach
Springfield , Missouri
Smile
Originally Posted by russ240 View Post
Glad to hear the Onan tech was not alarmed by this! I just bought my Honda EU3000is on Saturday. I've got my hitch basket as well (went with a Rola cargo basket part no. 59502, much stouter than the others I have seen), also just ordered their light kit that adds tail lights on the back of the basket, plugs into the trailer light plug. I'm going to add a generator plug to the rear of the Sprinter back by the trailer hitch so I can us this on the roll without having the plug hanging off of the side. I just need to fab up some brackets to bolt the generator into the basket. I ordered a couple of high security cable locks to run through the generators handles and the gas cans and around the hitch to keep anyone from walking off with everything. Drove home from the Honda equipement dealer with the generator strapped into the basket. Having the backup camera to keep an eye on everthing back there is very reassuring!
Great mind think alike! I'm in the process of doing exactly the same thing, I'm going to tie into the electrical junction box and run conduit over to the hitch and use a similar plug to the factory one, I also have an enclosed trailor that I suspect one could hardy hear a honda 3000 running in.
Jeff
Jeff64 is offline   Reply With Quote
Old 09-11-2013, 09:59 PM   #47
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Jeff
Probably not a good idea to run one in an enclosed trailer. It would eventually choke itself trying to breathe its own exhaust. Not to mention choking you when you open the trailer at your destination.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-11-2013, 11:08 PM   #48
Jeff64's Avatar
This trailor has sidewall vents and roof vents, I may have to vent the exhaust outside, I'll just need to expeiment a little, probably wont work well in high temperatures. I'm mostly thinking of this scenerio for remote camp locations where a door could be left open.
Old 09-12-2013, 07:10 AM   #49
norman , Oklahoma
I should advise that while I have successfully used the Honda while "on the roll" there were a couple of issues. At first I had a LOT of problems with the generator dying when I hit the brakes. I finally figured out that it I clocked it in the opposite direction the problem when away (I think it is a fuel starvation issue). I have not used it this year and it's sitting in storage so I'll have to go look at it and report back on which side needed to be the "front" to prevent stalling under braking.
The second problem is that when the generator is running with the roof top air on, and then I start the Interstate's motor, the roof top a/c shuts off momentarily which then puts the generator into overload. In order to get it back up and running I have to shut off the a/c, shut off the generator, restart the generator and then turn the a/c back on. The only solution I found to that one was to keep the coach engine running whenever I have the roof top air running off of the Honda.
Even with these annoying quirks I'm still very happy to have my gas powered setup!
russ240 is offline   Reply With Quote
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 05:23 AM
Onan Microlite 2500 LP problems willbrackman Generators & Solar Power 4 07-12-2011 12:01 PM
1991 LY Onan generator Jon Hrabe Land Yacht/Legacy Motorhomes 4 05-23-2011 07:49 AM
