Old 07-23-2019, 01:04 PM   #1
Newport Beach , California
On trip - need help with key/ignition issue
Hello,
Just drive from California to Florida in my 2018 interstate airstream, and have this strange intermittent issue that has me a bit freaked out.
4 times on the trip so far, when I put the key in the ignition, it is not detected, no dash lights come on and the ignition switch remains locked.
No amount of wiggling the key or steering wheel helps. Each time, after trying everything I can think of, it magically starts to work again - I put the key in and it is detected and lights come on and ignition is unlocked.
Twice this has happened at the diesel pump, and I sat there like a dummy trying to get it to work for 20 min.
At first I thought maybe the steering wheel column was locked, but that is not the issue.
Second I thought maybe my key battery was low, so I swapped out with my brand new fob that hadnít been used and I still have the issue.
Right now, Iím staying in the RV at a campground and donít have time to go to a Mercedes sprinter dealer.
I am planning to head up the east coast and stay a week in the pinehurst, NC area, where I will have time to go.
Iíve read where some people on this forum have a similar problem, but not quite the same. If I have some ideas from the community, maybe I can call ahead to Mercedes and be better prepared with the service so our trip isnít so disrupted.
Iím afraid one of these times it just wonít magically start working after 20 min.
Thanks!
AirstreamGT is offline   Reply With Quote
Old 07-23-2019, 01:15 PM   #2
Long Island , New York
Originally Posted by AirstreamGT View Post
. . . maybe I can call ahead to Mercedes and be better prepared with the service so our trip isn’t so disrupted.
I would start calling Mercedes, Airstream, and your dealer to schedule one or more appointments ASAP.
No need to wait until you have it figured out IMO.
I’m afraid one of these times it just won’t magically start working after 20 min.
Exactly!
Sooner or later a Mercedes dealer/mechanic will have to trouble-shoot this. They will plug you in and get an instant diagnosis hopefully. Are you still under warranty?
Good luck,
Peter
PS -- See Airstream reply in next post.
Old 07-23-2019, 01:17 PM   #3
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hello,
Thanks!
Hi AirstreamGT,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 07-23-2019, 01:41 PM   #4
Thanks, just sent my contact info and VIN.
If anyone has ideas in the meantime, please let me know. I do not want to interrupt our vacation (much) if I can help it.
Old 07-23-2019, 01:55 PM   #5
2017 Interstate Lounge Ext
Cols , Ohio
Possibly the chassis battery connection
Hello,
Check the chassis battery, and chassis battery connections including the red quick disconnect above the accelerator pedal under the dash.
Hopefully that helps.
AlexP is offline   Reply With Quote
Old 07-23-2019, 02:24 PM   #6
Thanks for the help. I’m away from the airstream for a few hours (Disney). When I get back, I’ll investigate.
Old 07-23-2019, 02:32 PM   #7
There is probably a Mercedes dealer within 5 miles of Disney. Your warranty should support a mobile technician to check this out, rather than run the risk of you becoming disabled on the road.
Don’t be shy!
Old 07-23-2019, 05:50 PM   #8
Found this issue while looking things over
I looked under and found a wire harness dragging on the ground. It appears the white wire is severed, and dangling. The wires originally terminate inside that piece of rubber that is glued to the battery box (assuming this is the battery box). When I found it, both sides of the rubber had fallen down from the plastic box (great design!)
Interestingly, I just checked my key and it works in the ignition. I expect these issues may be related, but the broken white wire is not triggering the issue, at least only intermittently.
I expect this issue (white wire) is an airstream issue and not MBZ.
ID:	347419   Click image for larger version
Old 07-24-2019, 07:37 AM   #9
went under in daylight this morning, and that is a holding tank (not sure which one) and that is likely the heating element that is damaged (the tank is 26 gallon, which doesn't align with anything directly in the specs (either black or grey). Maybe debris on the drive over, but it appears the glue is not going to hold up well. It keeps wanting to fall down. Will need to get that fixed, but definitely no concern with freezing temps at the moment.
Alex P, what specifically should I be looking for with the chasis battery and the red disconnects?
Old 07-24-2019, 07:54 AM   #10
I'm expecting a call back from the service advisor this morning.... They seem busy (I can imagine) here in Orlando.
Old 07-24-2019, 08:39 AM   #11
Talked to MBZ. They think it’s something in the ignition system that is failing. No traveling techs, so likely bringing it in tomorrow am.
Old 07-24-2019, 12:48 PM   #12
Cols , Ohio
Check to make sure all connections are connected and secure. When chassis battery (under driverís seat) is dead or disconnected the key will not turn in the ignition.
Old 07-25-2019, 08:07 AM   #13
At MBZ service getting diagnostic test done. Will report what they find.
Old 07-25-2019, 09:57 AM   #14
Ok, they did the diagnostic and found faults associated with the PSM. They also found it needed an update, so they updated and the faults cleared. Also had a CID update done.
Now for the bad news, the side view cameras no longer work. Had to come back and tech is looking at it. Likely the PSM software update messed with the airstream integration to the rear view camera. Has anyone had this happen?
Laser cut ignition (key) switch tool. RBonney Classic Motorhomes 5 08-20-2016 06:39 AM
Part number for Argosy MH ignition key blank? martin300662 Argosy Motorhomes 8 07-31-2015 11:22 AM
Lost ignition key, best solution? SteelyDan Classic Motorhomes 8 10-24-2012 07:21 PM
Are you feeling like Sherlock? Strange ignition issue, need advice scottf3334 Mechanics Corner - Engines, Transmission & More... 15 08-28-2009 08:45 PM
Key Stuck In Ignition doorgunner Mechanics Corner - Engines, Transmission & More... 26 11-12-2006 07:17 PM
