Old 08-10-2019, 11:40 AM   #1
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
On the road repair ingenuity
So, I'm a half-competent backyard mechanic and repair person. I can do most mechanical and minor electrical repairs myself. I also pride myself on finding innovative ways to repair broken things... but I have to say I was out-performed on this one.
I noticed that the sewer pipe support strap had rusted through and broken at some point, probably before I even bought the coach, but I only noticed it recently.
So I went to the hardware store and bought a 10' role of galvenized pipe strap, assembled the couple of tools I thought I'd need, raised the van enough to get a creeper under it, and found that the factory had apparently used a TON of Dicor or some other sealant to seal the rust in on the bolt holding the broken strap... no worries... dug it all out and replaced the strap without drama. HOWEVER, while I was under the van I also noticed the vibration-strap on the generator's exhaust pipe. It too had apparently broken at some time in antiquity, which isn't unusual.
I've replaced a couple of those over the years... but what WAS unusual was the "temporary" repair that had been done... again perhaps in antiquity. They'd used wire ties to tie the exhaust pipe back to the support strap. I've seen wire, and galvenized pipe strap (like I used) but using a dozen wire ties was a new one. Innovative as well, and to my surprise, none of them seemed to have been singed at all. So I have to hand it to whoever did it, it was certainly an out-of-the-box idea that stood the test of time!
As I don't have a spare exhaust hangar, and can't get one until after I'm back from this next trip, I too jury-rigged a new hangar strap using standard 3/4" galvanized pipe strap. It'll hold until I can get a new hangar ordered.
Anyway, this was so innovative, I just had to share it.
ID:	349006   Click image for larger version
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 08-10-2019, 02:46 PM   #2
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
85MH325 - that wire-tie fix is about as wonky of a fix I have ever seen. I would guess it wasnt meant to be permanent because stainless steel tie-wraps or same galva straps you used would've been better. But I agree, resourceful fix maybe that's all they had on the road.
PS: I do carry lots of super long plastic & stainless steel wire ties and extra 15A orange extension cords which can be cut to act as excellent padded ties. Then I can still re-use the remnant by connecting new plug on it. I ought to carry some of the galva strap rolls I have at home.
I also carry a dozen of these bike rack straps I have from home. They are strong and are made for extended exposure to UV. It took years for my friend to have one break after daily exposure to desert sun
ID:	349020   Click image for larger version
Alex AVI is online now   Reply With Quote
Old 08-10-2019, 05:01 PM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Where does one get those straps?
Dept of “OverKill”
GMFL is online now   Reply With Quote
Old 08-10-2019, 05:11 PM   #4
Alex AVI's Avatar
GMFL - I got mine from my local bike shop but any place that carries bike racks. I have seen them in Amazon, REI, Performance Bikes, even eBay online. Different manufacturers Thule, Yakima, etc. have different designs & lengths, so just need to figure out which one you like better & how long you want. Personally, I would get the longest coz you can cut them down.That's usually 14-17" for the longest I have seen coz they only made to strap bicycle tubes or handlebars. They work & sized like thick rubber bungee cords with adjustable attachment points.
Works well , last long time, and dont need to read instructions on how to use
Old 08-11-2019, 05:31 AM   #5
Paradigm shift:
I am increasingly using wire ties on those elements of the van which do not require nuts and bolts.
It partly goes back to the issue of the entire universe of automotive mechanics being calibrated to male hands, which are, by published references, almost twice the strength of female hands (I think I griped about that on the Maintenance thread, with data).
For instance, I had to remove the protective cover over the propane regulator before leaving Houston, to check the spec. It was held on with two small nuts and bolts, and you can guess how that worked out: LB_3 ended up removing it for me, because I detest struggling where I should not have to struggle due to poor ergonomics. Pet peeve.
I put the protective cover back on myself, but with small wire ties rather than new nuts and bolts. In that application, there's just no need. When the cover eventually must be removed again, I've got wire cutters in my fancy tool kit, and I will just snip them off, no hassle.
Old 08-11-2019, 05:52 AM   #6
Lily&Me's Avatar
Normal , Illinois
Good job there, 85MH325!
The crank part in my drivers side door failed the day I set out in June, and when the guy took the door apart to replace it he found it held together with zip ties from a precious fail.
Zip ties and duct tape...essential items for on-the-road emergencies.
Maggie
Old 08-11-2019, 09:37 AM   #7
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Paradigm shift:
Quite frankly, I use a bazillion wire ties on things as well... where it's merely a matter of holding something together, and neither aesthetics nor brute bolt-down force are at issue.
I thought that putting flammable materials in a supporting structure in contact with a hot exhaust pipe was just a little flaky. I mean, it's fine if it's a temporary repair and you're just trying to get it home, YOU know about it, and YOU don't run YOUR genset until it's properly repaired, but this was an OLD repair... and I've got a number of hours on the genset now with zip-ties holding the exhaust pipe! Amazingly, none of them were melted or even singed.
Old 08-11-2019, 09:39 AM   #8
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Maggie
In my early years, it was baling wire. Then "safety wire" (as it was known in the Navy) and duct tape. NOW it's zip ties and various colors of duct tape! BTW, I know now from personal experience that white duct tape will extend the life of a $100 Penguin AC cover at least four years after it begins cracking. The experiment continues, I'm sure, but on a B-Van I sold in June... so I can't follow it any longer.
Old 08-11-2019, 09:59 AM   #9
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
My dad still uses waxed nylon string to tie wires and misc. things together. Learned that back in the day before zip ties.
Streamracer is offline   Reply With Quote
Old 08-11-2019, 10:05 AM   #10
2007 22' International CCD
Also known as lacing cord. Came in various colors, usually waxed, and either round or flat.
Somewhat of a lost technique, but I have a big spool of waxed lacing cord in flat and black, and still remember how to use it.
Nothing quite so tidy and neat as a well-laced wire bundle. (Or quite so hard to take apart, repair or modify, and then re-lace it!)
Tie-wraps are very quick, but not as tidy, and the little lock thingie is a bunch fatter than a lacing cord with proper knots in it.
Old 08-11-2019, 08:20 PM   #11
2004 22' Safari
Albuquerque , New Mexico
Maggie
I would add bailing wire to your list of invaluable repair materials.
Silver.Sanctuary is offline   Reply With Quote
Old 08-11-2019, 09:00 PM   #12
2012 Avenue Coach
Corpus Christi , Texas
Duct tape has previously been mentioned. But I'd like to add that it helps if it is of heavy duty variety, especially when it come to tear strength and adhesive bond.
Gorilla tape got us home when the windshield rubber decided to detach on the driver's side (at 70 mph), and once more when the leading edge of a tank heater pad decided to let go (caught it on camp pre-departure check when it had just started).
Permanently fixed both items when we got home, but not because the Gorilla tape had failed.
rowiebowie is online now   Reply With Quote
Old 08-12-2019, 07:55 PM   #13
Alex AVI's Avatar
ROWIEBOWOE - I can understand aesthetic reason for fixing up the windshield even though Gorilla did not fail. But why fix the heater pad when Gorilla did better job than OEM adhesive? My OEM adhesive on grey tank heater pad started peeling off on 2 months after we bought AI. Used 3M 10lb. clear doublesided while in campground, still stuck on there, I leaving it be
Old 08-13-2019, 06:30 AM   #14
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Interesting repair #2 Sewer hose storage tube
So, since I bought my '04 T1N Interstate, I've only dumped the tanks twice. The coach came with a new hose with fittings including a back-fill, back-flush device that actually works better than I'd expected. However, the whole apparatus was, of course, way too large to fit the OEM hose compartment.
The hose compartment is the door-in-the-sidewall with a tube behind it, not the PVC chassis hang-under.
So, as I'm planning a trip and need all the storage compartments inside for cargo, I decided to put a standard dump hose in the compartment and leave the fancy flush-thingy in the shed. I put the hose in the compartment and it went in as designed for a couple of feet, and then promptly just snaked onto the driveway! I crawled under the van to find that the aluminum dryer vent hose tube that normally holds the sewer dump hose had just rotted; a large hole opened and the tube just fell out, end first.
Fortunately, I still had the rear tires on leveling blocks from crawling under it to replace the strapping on the sewage dump tube and the generator exaust, so that was a step I didn't need to do.
The door assembly is removed with ten screws. There's a metal strap that holds the tube up to the chassis. The old tube just disintegrated as I pulled it out. It has a plastic cap on the far end, held to the tube by three pop rivets. At the door end, the tube was held to the door assembly by four pop rivets and duct tape.
It was a straight-forward replacement job that took about an hour start to finish. The only catch is that the tube snakes around the shower pan drain and some wiring, and doesn't make a straight-shot into the undercarriage. The strap has to be loosened to get the new tube in without damage. Once in, however, the sewer hose slid right in!
And so now, the sewer hose storage dilemma is resolved and I have a couple of cubic feet of in-cabin storage back as well. The fancy back-flush hose assembly can live in the shed until I need to clean the tank again.
Emergency on the Road- Brake Repair Ray Eklund Brakes & Brake Controllers 80 11-25-2018 07:17 PM
On the Road Repair SeymourAC On The Road... 5 11-21-2017 06:02 AM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
On the road repair gaylejoe On The Road... 5 06-05-2008 08:17 AM
