Old 08-16-2013, 04:31 PM   #1
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Odds & ends storage
While I had just thrown stuff loose under the side seats, decided that some things could work their way down into hard-to-reach areas. So here's my solution.
Nice for loose stuff and bedding.
ID:	193372   Click image for larger version
Old 08-17-2013, 08:38 AM   #2
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
Good idea. I may have to try that.
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 08-17-2013, 09:52 AM   #3
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
I can't quite tell from the pics and maybe this would not apply to a twin bed Interstate, but can you tell us a little about what you actually did/built here?
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 08-17-2013, 10:38 PM   #4
73shark's Avatar
By using cardboard and trial and error, I determined the maximum size of the flat bottom piece (1/4" luan plywood) that would go in without taking the seat off the frame. The side pieces are 1 X 2 firring strips. After working the completed unit through the opening, I attached the front edge of it to the vertical piece that was already installed by Airstream that was behind the door. It rests on the top of the wheelhouse. I may add another set of firring strips to the top edge now that it's installed to give it more depth if we decide to put small items in there.
I don't know if it would work on the twin bed model though.
Sent with AquaMail for Android
AquaMail: English: About - Aqua Mail
Old 08-18-2013, 09:59 AM   #5
kaylorsan's Avatar
2012 Interstate Coach
Los Gatos , California
Nice solution.
I did something similar, but not as nice looking. I bought some 'pick and pull' foam ( a sheet of packing foam that is perforated; you pick out pieces to form the shape that you want) and filled in the tight spaces around the wheel well. It keeps small parts from getting down there. On one top side of the wheel well, I store the airstream and other manuals in their 'tote bag'. On the other side, I store cutting boards and a collapsible strainer.
Behind the front access doors on the wheel wells, I store a number of those plastic organizer cases. One is an extensive 1st aid kit. One is part of my repair kit (zip ties, adhesives, hardware, etc). I also have a zip bag with computer cables, adaptors, etc). I also store some vinyl cleaner and kitchen counter cleaner there. I had to move back the flimsy divider closer to the wheel well to fit everything, but I'm surprised how much I can fit in the wheel well compartments from the top and front access ports.
I have a 2012 Interstate EXT Lounge version.
kaylorsan is offline   Reply With Quote
Old 08-24-2013, 08:43 PM   #6
Trying to Retire
MILATV's Avatar
Decatur , Illinois
My 2014 has plastic storage trays here, did you remove those to make more room?
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 08-24-2013, 10:03 PM   #7
Boxster1971's Avatar
Fulton , Maryland
The storage trays must be an improvement on the 2014 model. On my 2013 the space under the side seats around the wheel wells is very limited. I plan to also expand this storage area myself.
- - Mike
Old 08-25-2013, 05:47 AM   #8
Figment of My Imagination
Protagonist's Avatar
I don't bother with trays or anything. I just store my power cords on the passenger side under the seat, and my hoses on the driver's side under the seat. Those items aren't small enough to get lost in the nooks and crannies, and they're flexible enough to conform to the shape of the available space.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-25-2013, 07:14 AM   #9
norman , Oklahoma
That's good to know. I might like to order a pair from Airstream. Are you happy with them? Can you provide a pic?
russ240 is offline   Reply With Quote
Old 08-25-2013, 07:33 AM   #10
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Here are pics from 2014 Int Ext - underside of jumps seat over wheel well, you can see it will fit 24 cans of dog food at about 5" depth, so easily store a case of soda or your favorite drink in each side.
Odd that they left a full 2" between bottom of tray and wheel well. Similar to the wasted little cubby hole under the front passenger seat.
I wish they understood how useful even the smallest little cubby hole is for storage.
ID:	194079   Click image for larger version
Mike
Old 08-25-2013, 07:41 AM   #11
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Here is photo of tray removed.
Tray is 22" wide x 15.5" long x 4" deep outside dimensions. ( there is 1.5" more useable depth due to seat frame)
Lip is .75" all the way around.
ID:	194082   Click image for larger version
Mike
Old 08-25-2013, 08:08 AM   #12
73shark's Avatar
Note that the opening is bigger than the 2011s is.
Old 08-25-2013, 08:17 AM   #13
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Opening is 14.5 x 21 on the 2014 with trays.
Mike
Old 08-25-2013, 08:24 AM   #14
Trying to Retire
MILATV's Avatar
Decatur , Illinois
I think so, frustrated by the waste of 2" below the tray ( 600 cubic inches) but they are easy to load, and great place for the dog food on one side, trash bags, tinfoil and kitchen stuff on the other.
My power cords are in the lower storage area in the rear. (Not best since I have to unload to get to them, I'm working on that.
This 7 day trek is my first outing and as always - trial by fire is the best teacher.
Mike
