Old 12-06-2017, 07:59 AM   #29
2017 Interstate Grand Tour Ext
Madison , WISCONSIN
Originally Posted by toskeysam View Post
Interesting....my Sprinter dealer said they could not align my AI......”We don’t know what specs to use.” Frankly sounded like a “blow off “ to me. Everything else they have done is top notch. Hmmmmm
As I mentioned in an earlier post, the service tech fully understood the issue with converted sprinter vans and the alignment issue. Our MB dealer is quite large and has a whole separate service department for just Sprinter vans.
I got the color printout as described in another post here.
They took it and test drove it (ten miles). It sure seems to ride even more smoothly -- but probably just my imagination.
So even tough it drove smoothly, it showed no wear on the tires (10,000 miles), ran straight (as I perceived it) the printout showed that it was not truly in alignment. I am glad that I had this done, and done as soon as I got it. Thanks to Protagonist and others who encouraged me to do it.
sheakev is offline   Reply With Quote
Old 12-06-2017, 04:39 PM   #30
2013 Interstate Coach
Raymond , Iowa
I was not able to get mine aligned at the Iowa City MB dealer nor several other MB shops. Apparently they cannot hook onto the Aluminum rims (or would not try for fear of scratching the rims). I was able to get alignment checked at a tire shop - they used a gadget to hook into the tire treads. Alignment checked out OK per what I wanted (nearly 0) but was off from the MB specs. I wanted 0 based upon posts here and on the Sprinter forum.
Titus is offline   Reply With Quote
Old 12-07-2017, 01:33 AM   #31
Loma Mar , California
It is my understanding that not all Mercedes-Benz dealership are Sprinter dealers.
Sprinter servicing dealers are often found closer to populated areas (more customers).
Sprinters are sold as utility vehicles filling narrow niches in the overall utility vehicle market. The new small sized vans should help to expand sales.
I have found that smaller more rural MBZ dealerships that are Sprinter dealers often provide the best service.
A Sprinter dealer should be able to do alignments, after all they are a factory authorized Sprinter facility.
I do know that there are Mercedes-Benz dealerships that will service Sprinter vans but are not Sprinter dealer. They have access to all the same parts, service bulletins , etc. But they might not have all the special tools, training and experience that a Sprinter dealership would have.
But ..... Wheel balancing: I have found that this is a problem with Mercedes Sprinter dealerships. They have been unprepared to balance the aluminum Alcoa wheels (standard on Airstream Interstates) because their service departments don't have the adapter for their wheel balancer machines.
I would expect that due to the popularity of these wheels, every dealer will have the wheel adapter soon.
Haasman
Haasman is offline   Reply With Quote
Old 12-07-2017, 05:33 AM   #32
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
In my area, MB of Baton Rouge (65 miles away) is a Sprinter dealer. MB of New Orleans (2 miles away) is not. The reason they're not (I asked them why) is that they do not have a service bay large enough to handle a Sprinter van. It takes a huge service area to install a lift capable of handling a van that is almost 25 feet long and almost 10 feet tall.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-07-2017, 07:51 AM   #33
toskeysam's Avatar
Townsend , Tennessee
My MB dealer is a Sprinter dealer. Mercedes Benz of Knoxville, Tn.
They built a huge addition to Service the Sprinters. They took me on a tour just as they opened this wing. The only thing they have declined to perform is an alignment. They do have a working relationship with the local Airstream dealer, so AI is no surprise to them. While there for Service I have seen Winnebagos, Roadtreks, and Leisure Travel vans in there for work. My service writer did give me a recommendation for a local shop they use for alignments.....apparently they don’t do them at all, but gonna ask why next time.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 12-07-2017, 07:58 AM   #34
Raymond , Iowa
PS
The 0 I refer to above is camber. Toe was at the spec.
Old 12-08-2017, 05:02 AM   #35
sthrngary's Avatar
2017 25' Flying Cloud
2018 Tommy Bahama Interstate
Miramar Beach , Florida
Ok, all fully equipped Mercedes-Benz Sprinter dealers can and do provide alignments. Some of the dealers choose not to invest in the alignment machine either initially or at all. They are very expensive and used less frequently than the car alignment machines. This is a dealer choice for their investment in there sprinter shop. My advice is to call Mercedes-Benz directly and find the closest Mercedes-Benz sprinter shop that does computerized alignments.
Gary and Tami T., The “RV Advocate”
Proud new owner of a 2018 Airstream Interstate Grand Tour Tommy Bahama
Previously owned a 2017 Airstream Flying Cloud 25 ft.
sthrngary is offline   Reply With Quote
Now here's an axle upgrade... bbandeddie Axles 1 10-05-2017 03:46 PM
Fan stopped, now Dometic fridge stopped-what now? BWright2016 General Repair Forum 10 08-27-2017 01:14 PM
22FB bed is now 78" long instead of 84" (2017) ohmman 2005 and newer - Bambi all models 6 12-06-2016 06:01 PM
Necessary to upgrade Parallax 8355 on 2017 International? interstateflyer Batteries, Univolts, Converters & Inverters 21 10-06-2016 06:42 PM
What size tv does my 16 bambi have thinking of upgrade starcraft Nu-Tone Appliances & Central Vac System 0 02-01-2012 07:17 PM
