Originally Posted by Titus
I have read the manual for the Magnum but still do not understand. I do not see how/where you change the Battery Saver mode from ON to OFF. I have upgraded from the MR ME remote to the RE RC remote. Both remotes have a Power Saver feature that limits the time that the LCD backlight is on, but I see nothing about Battery Saver. It appears that Battery Saver ON is better for the coach batteries, but can cause problems with the chassis battery. OFF is just the opposite - good for the chassis batteries but bad for the coach batteries - correct? Or does this problem only occur in certain modes of the ACR, and not with the BIM?
I also have the ME RC control. From the RC manual:
"SETUP: 09 Final Charge – The Final Charge stage setting is the stage
to which the charger will transition after the absorption stage has
finished—as set in the 03 Absorb Time menu.
Default setting: Final = Multi
Range: Multi, Float, Silent (Rebulk)
Note: If “CC/CV Controlled” displays on this menu’s screen, you will not be
able to adjust the settings as “CC/CV” has been selected as the battery type
from the 04 Battery Type menu.
Set Final Charge = Multi – The Multi setting (or “Multi-Stage”),
transitions from the Absorption stage to Float. Once in Float stage for 4
hours with no DC load on the batteries, the charger enters the Full Charge
stage (i.e., Battery Saver mode). In Full Charge mode, the charger
automatically stops charging but is still on and actively monitoring the
battery voltage. The charger remains in the Full Charge stage until the
battery voltage drops below 12.7 VDC for 12-volt batteries, 25.4 VDC
for 24-volt batteries, and 50.8 VDC for 48-volt batteries—at which time
it returns to the Float stage. These battery voltages are the fully charged
voltages of a battery at rest. The charger continues to cycle between
Float and Full Charge as long as incoming AC is available.
Info: When Multi is selected and the charger goes to Full Charge
mode, if another charge source (such as PV or wind) is charging the
batteries above the fully charged voltage, the charger will remain
in the Full Charge stage.
Why should I use Multi-Stage? Multi is the most commonly used charge
mode. It is suitable for most applications and will assure a full charge to
the batteries, without overcharging. If there is another alternate charge
source charging the batteries, such as PV, wind or hydro, then Multi mode
will use the inverter/charger to complete a full charge. The inverter/charger
will transition to Full Charge mode and the alternate charge source will then
maintain the battery voltage. If the alternate source is unable to maintain the voltage, the charger will enter Float mode for another four hour period. The Full Charge feature in the Multi mode also helps reduce water consumption in flooded batteries when they are left in the charge mode for extended periods, such as in a backup power application.
Set Final Charge Stage = Float – The Float stage is a maintenance
charge mode that maintains a constant voltage—while delivering up
to the maximum rated current of the charger in order to power any
DC loads connected to the batteries. Most 3-stage chargers fi nish the
charge mode in Float and remain in Float as long as an AC source is
available on the input of the charger. The fl oat voltage is determined
by the battery type selected in the 04 Battery Type menu. Unlike Multi
mode, in Float mode there is no Full Charge feature.
Why should I use the Float Charge Stage? Float mode is typically used
when the charger is the only charge source connected to the batteries.
This mode will maintain the batteries at the fl oat voltage. If using fl ooded
batteries and the charger is in fl oat for an extended period, the water level
should be checked every two to three weeks for proper levels.
Set Final Charge Stage = Silent – Silent mode stops charging once it
transitions from Absorb mode to ‘Silent’. Once the charger enters Silent
mode the battery voltage is continuously monitored. If the batteries fall
to the Rebulk value, the charger restarts the Bulk Charge mode and
then transitions to Absorb Charge mode. After the Absorb Charge mode, the charger again transitions to Silent mode. This silent to rebulk
to absorb and back to silent cycle will continue as long as it is required.
ReBulk – When Silent is selected, you must also set the DC voltage
set-point where the charger restarts the Bulk Charge mode. This setting
should be at the lowest DC volts you want the batteries to fall before
starting a new bulk charge. Typically, the lowest DC volts the batteries
are allowed to fall is 12.0 to 12.2 VDC (12-volt systems), 24.0 to
24.4 VDC (24-volt systems), and 48.0 to 48.8 VDC (48-volt systems)
respectively.
Default setting: Rebulk = 12.0V (for
12v inverter)
Ranges: 12.0-16.0 VDC (12v), 24.0-32.0 VDC (24v), 48.0-64.0 VDC (48v)
Why should I use the Silent Stage? Silent mode is typically used when
an alternate charge source is available and able to fully charge or fi nish the
charge cycle after the Absorb stage. A major difference between Multi mode
and Silent mode is that the Silent mode returns to Bulk mode instead of Float
mode. In Silent mode you can also adjust the Rebulk set-point in order to
allow the alternate charge source to provide more of the battery charging."
