Old 08-18-2012, 07:40 PM   #1
yeziad's Avatar
2013 Interstate Coach
Saint Louis , Missouri
Non-stop beeping sound
This is my first post, just joined, took delivery yesterday on a 2013 Interstate Twin, drove 383 miles (from a dealer near Jackson Center), beeping sound (appears to be coming from outdoor electric step area) did not stop except when engine was shut off. It beeps while engine is running and house battery is turned to the OFF position. I checked many things i.e. seat belts, doors, awning, step...Frustrated... Any ideas?
yeziad is offline   Reply With Quote
Old 08-18-2012, 07:43 PM   #2
SpikeC's Avatar
1958 26' Overlander
Portland , Oregon
Call the dealer?
SpikeC is offline   Reply With Quote
Old 08-18-2012, 08:12 PM   #3
1988 32' Excella
Robbinsville , New Jersey
Did the step retract?
Old 08-18-2012, 08:29 PM   #4
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
batteries bad
We have a trailer, but the first thing I would go looking for is the carbon monoxide detector or maybe a propane gas detector that might be located near the floor.
Smoke alarms are usually on the ceiling.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 08-18-2012, 11:22 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Welcome to the forum.
The two things that beep like that on mine are the awning not fully retracted (at least the computer didn't think so due to a misadjusted limit switch) and the step is not retracted w/ the engine running.
Old 08-19-2012, 09:05 AM   #6
Usagi's Avatar
Waldorf , Maryland
We had a similar problem (although I think it stopped if the engine was off). Check the position of the step lock switch. If I remember correctly there is a secret secret combination of steps you have to do to reset. Something like turn the engine off, then turn the switch off, then turn the engine back on.
In our case we had accidentally switched the step lock to on. (flipping on and off all the unmarked switches!)
But, in researching the issue on the Internet, I think it is a common issue...and sometimes the sliding door is not making good contact with the step sensor.
Not entirely helpful, I know...but maybe gives you some things to try...good luck!
Usagi is offline   Reply With Quote
Old 08-19-2012, 09:11 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
There are two things that make the step retract, if everything works as it should:
1 - You start the engine. There is an electrical solenoid switch for the motor that extends and retracts the step, which is powered off the main battery, not the house batteries. When you turn the ignition to "Start" that interrupts power to the solenoid switch and forces the motor to retract the step. Just turning the key to "On" doesn't do it, you have to turn it all the way to "Start";
2 - You fully close the sliding side door. There is a limit switch on the door. When the door is closed, this opens the circuit and triggers the motor to retract the step. When you open the door, this closes the circuit and triggers the step to extend.
There is an alarm on the step itself, so that when the engine is running and the step is in any position other than fully retracted, it will beep.
However, there is also a step lock switch. The step lock switch is wired in parallel to the limit switch. When the switch is in the "On" position, once the step extends, it stays extended until you start the engine, even if the sliding door closes. Starting the engine overrides the step lock. At least it's supposed to. Only use the step lock when you're boondocking and you don't want to waste electricity for powering the step in and out every time you go in and out of the van. Note that the step lock will NOT lock the step in the retracted position, only in the extended position.
Also, down near the bottom of the sliding side door, beside that little storage cubbyhole under the seat, there is a "step extend" switch. The only time this switch does you any good is if you open the side door while the engine is running (step stays retracted) and then turn off the engine. Since the side door is already open when the engine is shut off, the step doesn't automatically extend when you shut off the engine, so you use this switch to extend it.
When I had a problem with my step, it was traced back to two things working together: The step lock was on, and the limit switch on the side door needed to be adjusted. What was happening with mine was that somehow the step was working backwards, opening when I closed the sliding side door, and staying open when I opened the side door. However, my step always retracted when I started the engine, and in fact that was the ONLY way I could get it to retract.
Turns out my step lock switch was wired so that the "Off" position is up, completely opposite of all of the light switches and tank heater switch in the same location, where "Off" is down. Not knowing that, I had my step lock on all the time. Once I figured that out, and got the dealer to shim the limit switch into the correct position, I've had no more trouble ever since. I don't know if everybody's is wired that way, or if my step lock is the only one wired backwards.
Your problem is different, since your step is staying extended (at least partially) with the engine running.
One thing I nioticed on my step, when I was trying to troubleshoot the problem without an owner's manual for the step, there is a small hydraulic fill line with a cap on the end, coming out of the back of the step pan underneath the van. If the line is not held vertical, a bit of light machine oil (about the consistency of brake fluid) will leak out if the end cap is loosened. This hydraulic fill line is loose, nothing to hold it in place. If this line fell behind your step inside the step pan, it could be blocking the step from retracting fully. You'll have to find it by feel (preferably with the step extended), but be careful not to dislodge the end cap.
For any other cause, you're probably looking at an electrical problem.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-19-2012, 10:14 AM   #8
A smoke alarm or detector that is battery operated, is the likely cause of that beeping.
They are usually located just inside the entrance door.
Old 08-19-2012, 10:15 AM   #9
It could also be a "LPG" leak detector that's battery operated.
Old 08-19-2012, 04:00 PM   #10
BL1996's Avatar
Fort Smith , Arkansas
Run the awning out the back fully. Fixed mine.
BL1996 is offline   Reply With Quote
Old 08-19-2012, 05:04 PM   #11
Actually, in an Interstate class B van they're located in back. LPG detector at the driver's side wheelwell, smoke/CO detector on the passenger side ceiling near the electrical panel locker.
I had a problem with my LPG detector beeping during my first outing. One beep per minute. Turns out it was a fault indicator, and the fix was to simply unplug the shore power cable, shut off the house batteries, wait a minute, and reconnect.
WBCCI #1105
TAC LA-4
Old 08-19-2012, 07:16 PM   #12
yeziad's Avatar
Thanks for all the suggestions. Step works fine, I found the step extend switch beside the little storage cubby under the seat, hold switch for step works fine... tried extending the awning again, started the engine, beeping sound disappeared. I drove the unit about 7 miles and beeping started up again, this time it beeped for maybe 15 seconds then stopped, then I got home. The LP propane detector on this 2013 twin model is located on the passenger floor cabinet under the bed. The salesman at the Airstream dealer (at the time of delivery) unplugged the chassis battery (the quick disconnect cable located underneath the driver's side dash) and reconnected it. Maybe something needs resetting? I will give the dealer a call in the morning. Thanks again for all the responses.
Old 08-21-2012, 04:04 PM   #13
Brentsouth's Avatar
Houston , Texas
Let us know what it was. When that happened with mine...I had stopped retracting the awning when it "looked" fully retracted. Held the button just a bit longer and the beeping stopped.
Brentsouth is offline   Reply With Quote
Old 08-21-2012, 08:44 PM   #14
yeziad's Avatar
Called the dealer regarding the beeping and I was told it could be a defective sensor for the awning, salesman suggested I FULLY extend awning and retract, just got back from another ride and happy to report "no beeping" whoopee. Kind of makes me afraid to use the awning.
What's up with the fresh water drain plug. I had to use a 26mm socket to loosen the plug. Seems like AS could've installed something a little less cumbersome (a handle of some kind would be nice). I would like to modify that. Anybody got any ideas?
